Trailering, Tie Down Question - Wrist Twisters
post #1 of 13 Old 09-17-2006, 06:28 AM Thread Starter
MuscleCar Nut
67GTONUT's Avatar
Question Trailering, Tie Down Question
Hey guys,
This might seem really stupid, but humor me( or bust my balls whatever).
Of course no issues with securing front of bike to trailer, my question is the rear of the bike.
I usually will secure using the rear pass pegs on past bikes I have had, but of course, they are usually nicelt part of the rear subframe......
On the 919, the rear pegs are part of the rear sets, and dont seem as strong to secure the bike. When I trailered it home, I did use the rear pegs, but was only able to put light tension on them before I could see them flex. And with NO accessable rear subframe to grab onto........
Where do you guys secure the rear of your 919's to the trailer?
Troy
67 Pontiac GTO
2003 Triumph Speedmaster
67GTONUT is offline
post #2 of 13 Old 09-17-2006, 06:39 AM
TrackXperience Pusher!
Jayfooey's Avatar
I just go around the rear tire
Jayfooey is offline
post #3 of 13 Old 09-17-2006, 07:03 AM
That's right!!
skipman's Avatar
^^^^ me too.
skipman is offline
post #4 of 13 Old 09-17-2006, 07:23 AM
Nick's Avatar
I never use straps on the rear.
Aren't you on the SVRider forum?
Nick is offline
post #5 of 13 Old 09-17-2006, 07:35 AM
mk919's Avatar
Another for going around the rear tire. My reasoning is just to keep the rear end from moving side to side. Obviously tie the front down real good and compress the forks when tightening.
mk919 is offline
post #6 of 13 Old 09-17-2006, 07:38 AM Thread Starter
MuscleCar Nut
67GTONUT's Avatar
OK, so I wasnt crazy for thinkin that
Troy
67 Pontiac GTO
67GTONUT is offline
post #7 of 13 Old 09-17-2006, 07:39 AM Thread Starter
MuscleCar Nut
67GTONUT's Avatar
Yep, moderator there still........
Troy
67 Pontiac GTO
67GTONUT is offline
post #8 of 13 Old 09-17-2006, 10:56 AM
I took the pass peg heel guards off the day I got the 919. That leaves a nice big hole to put a tie down hook thru. No flex.
post #9 of 13 Old 09-17-2006, 02:13 PM
Wazoo919's Avatar
I pull front down hard as I can and also I wrap the tie down around the rear pegs then hooks back to the strap.
05' 919
Wazoo919 is offline
post #10 of 13 Old 09-17-2006, 04:32 PM
INFIDEL
Rob919's Avatar
The 919 is light enough, that with a wheel chock up front, I don't tie the rear down at all; however, using a strap around the rear tire seems a good idea.
Rob919 is offline
post #11 of 13 Old 09-17-2006, 04:38 PM
On the right set I hook the strap on that horizontal slit, and on the left I feed the strap through the V portion right by the front peg and then attach both hooks to the truck. Haven't had a single problem.
post #12 of 13 Old 09-18-2006, 10:38 AM
Unbannable
Super Sneaky Steve's Avatar
67GTONUT helped me out deciding between the SV and the CB. I got to test ride an SV and it wasn't as good as I thought it would be. The 919 doesn't dissapoint!
Super Sneaky Steve is offline
post #13 of 13 Old 09-18-2006, 11:04 AM
Exhausted
TuonoR6's Avatar
Don't compress the forks too much or you can damage fork seals. I would not use a canyon dancer with tube bars as it has a tendency to turn the bars. Use some soft ties on the triples. I use the subframe with soft ties this is also with a cradle type wheel chock. You petty much just need to tie down the rear with those.
TuonoR6 is offline
