trackday - Wrist Twisters
post #1 of 5 Old 11-07-2010, 12:04 AM Thread Starter
trackday
Ran off to the track after scoring some decent used track gear. Apparently a bright helmet and a bright suit makes a difference. Getting better with the body positioning, knee is finally dragging before the pegs. Now if I could just go faster...
Comfy 32 degrees out today .Must be getting cold out there now... Hehe
honda ng gingsa is offline
post #2 of 5 Old 11-07-2010, 08:08 AM
It's below the freezing mark in the morning pretty much every day now.
No snow yet.
post #3 of 5 Old 11-07-2010, 08:14 AM
Do you have any kind of prep work or inspection for track days ?
Also you were talking 32C correct?
post #4 of 5 Old 11-07-2010, 08:36 AM
arctic954's Avatar
Most tracks have a basic tech inspection.
Depends on the organization at your track......if your racing, the rules for prep will be more stringent....
Typical trackdays will usually require a full suit, gloves, boots, and a current helmet. Most tracks require safty wiring of the oil filter, oil drain plug/filler, and coolant cap.....most also require you to not use a standard coolant. (water wetter or engine ice). Front/rear lights are usually unplugged and taped....with the kickstand either zip tied or removed.
arctic954 is offline
post #5 of 5 Old 11-07-2010, 02:41 PM Thread Starter
If it's a trackday organized thru a racing organization/association, yes. The upside of having to tape over lights etc. is having flagmen/marshals, and a first aid tent. Most times me and a few buddies chip-in to rent the track for a few hours. In the latter the case we police ourselves, run-what-you-brung and clean up after yourselves...Some one has to be the designated driver incase theres a crash or make a coffee run!
