Tire break in - Wrist Twisters
post #1 of 16 Old 05-19-2006, 07:54 AM
tomvan72
Guest
Posts: n/a
Tire break in
Best way of scuffing new tires or at
least each persons personal way?
post #2 of 16 Old 05-19-2006, 08:25 AM
BockHawk's Avatar
Ride! I do about 100 miles on them and try to do a little weaving back and forth to rub them in. That works pretty well for rear tires. For the front I use some hard braking.
2002 919 40,000 miles
BockHawk is offline
post #3 of 16 Old 05-19-2006, 08:39 AM
tomvan72
Guest
Posts: n/a
What about the edges? In my hood all roads are twisty. So the basic scuffing happens. What happens when you get into the "still fresh" areas on the sides? You are definately putting latteral forces on them at this point. Just go a little at a time or something? I want to go to Deals on Monday and I will have to put on some new shoes.
post #4 of 16 Old 05-19-2006, 08:42 AM
I go out & put mis. on 'em. ...gradually each corner lean a little more, push 'em a little harder.
h ryder is offline
post #5 of 16 Old 05-19-2006, 08:46 AM
tomvan72
Guest
Posts: n/a
When are you leaving for Deals?
post #6 of 16 Old 05-19-2006, 08:47 AM
Not to fret my friend... I just put on a set of metz racetec's & only got to put 30mis. on 'em. So I will be taking it easy @ the Gap till they are scuff'd in. I'm guessing Gap should actually be a good place for scuffing... not too fast, just nice slow corners to scuff up at ones confidence.
h ryder is offline
post #7 of 16 Old 05-19-2006, 08:49 AM
tomvan72
Guest
Posts: n/a
Well, when are you going?
post #8 of 16 Old 05-19-2006, 08:53 AM
I usually clean my tires with a degreaser before going out on new rubber. I use the bug scrubber sponge, and something like dish soap. Then dry with the leaf blower. I have no idea if it helps or not, but it gives me peace of mind.
post #9 of 16 Old 05-19-2006, 09:06 AM
tomvan72
Guest
Posts: n/a
That sounds good. I have done something similar with Michelin tires on my road bicycle.
post #10 of 16 Old 05-19-2006, 09:08 AM
planning to leave tonite, Mulford & I taking turns driving, & be there mid/late morrow morning.
h ryder is offline
post #11 of 16 Old 05-19-2006, 09:26 AM
tomvan72
Guest
Posts: n/a
Go like the wind. Fart.
post #12 of 16 Old 05-19-2006, 09:42 AM
Dawn and a scrub brush before you even mount the tires. Then I scrub and weave progressively getting farther and farther over. Within a 100 miles they're scrubbed and ready to go.
NewRedRider is offline
post #13 of 16 Old 05-19-2006, 09:54 AM
"Whose ABBA ZABBA?"
I fall over, and over, and over.
General George S. Patton
post #14 of 16 Old 05-20-2006, 09:56 PM
Put on new tires & ride like normal. It slides once to the left & then once to the right & then they are fine...
post #15 of 16 Old 05-20-2006, 10:28 PM
how profound...but also true
blackbetty is offline
post #16 of 16 Old 05-21-2006, 01:30 PM
Removed User 1
Guest
Posts: n/a
You can try a belt sander and 3 wire brushes, I would never do it though...
I on the other hand did slow figure eights in an empty parking lot.
