Terrible Neutral to 1st shifts - Wrist Twisters
post #1 of 12 Old 05-06-2006, 07:08 PM Thread Starter
My bike sounds like it is going to spread tranny pieces all over when going from neutral to 1st. Is this the nature of this machine?--IE start bike in neutral, downshift to 1st-CLUNK, ride-downshift through all gears then to neutral, stretch, go back into gear--CRUNCH. I am not reving it before hand either. 5700 miles with GN4 since new.
Bryce919er is offline
post #2 of 12 Old 05-06-2006, 07:13 PM
chain tension. driveline lash can make it really clunky and clattery
typhoonblue919 is offline
post #3 of 12 Old 05-06-2006, 07:45 PM
cyclerider105
Guest
Posts: n/a
Try changing your oil?
post #4 of 12 Old 05-06-2006, 07:55 PM Thread Starter
Oil is fresh, I will take a look at the chain tension.
post #5 of 12 Old 05-06-2006, 09:14 PM
"Whose ABBA ZABBA?"
My ZX10R, my 929 and my Superhawk all did that. Bugged the crap out of me until I stopped carring about it.
General George S. Patton
post #6 of 12 Old 05-07-2006, 06:03 AM
The Clunk you hear has been a trait with motorcycle engines for decades. As long as it is a CLUNK and not a grind don't worry about it.
post #7 of 12 Old 05-07-2006, 06:48 AM
I've noticed this on both the Honda street bikes that I've owned. My Magna did it really bad. Shifting was fine and it didn't grind, it was just a "clunk" when going to first. The 919 does it but not as badly as my Magna. I don't remember either of the Suzuki's (Katana, SV650) that I've owned doing it. I figured it's just a Honda thing.
amchev is offline
post #8 of 12 Old 05-07-2006, 01:31 PM
Veteran Donation
Downshift all the way down to first Before you stop...Then click up into neutral .The clunk will still be there but not as bad.
tvetree is offline
post #9 of 12 Old 05-07-2006, 03:51 PM Thread Starter
I always do and said so in my post. It still does it.
post #10 of 12 Old 05-07-2006, 05:48 PM
Veteran Donation
Yep,I just skimmed it...Sorry
Check out the other Downshifting Issue thread
tvetree is offline
post #11 of 12 Old 05-08-2006, 07:48 AM
Motorcycle transmissions have the pairs of gears always in engagement (constant mesh), and use a sliding dog between the pairs of gears that locks each pair of gears onto the output shaft. The output shaft is spinning at around 500rpm when at a stop so the clunk you hear are the gears engaging the output shaft and metal to metal enagagement at 500rpm resounds in your "thunk"
(God I hope I'm right on this one )
Someone please vindicate this for me, it's been a lonnnggggg w/e.
dadogs is offline
post #12 of 12 Old 05-10-2006, 09:19 AM
When I first got my 919 the previous owner had turned the idle up a bit higher than I like it. The extra revs did produce a rather abrupt clunk when dropped into gear. Once I set the idle back down to reasonable levels the clunk and lurch pretty much mellowed out. I suspect the idle had been turned up to compensate a newer rider from stalling the engine due to the lack of flywheel effect. I like the more mellow engagement of the slower idle.
coffeecat is offline
