tappet/cam chain noise - Wrist Twisters
post #1 of 19 Old 09-10-2007, 04:36 AM Thread Starter
Lightbulb tappet/cam chain noise
Hi all ..... after only 800 miles on my 2 day old 919 im hearing a tapping noise , it sounds like its coming from the engine and its more noticable at the lower end of the rpm scale and only at load ( does not exist at idle or even giving it a rev ) only appears when the bike is under load taking off and i can only hear it to about the 3k rev mark ..(everything gets to noisy after that, wind etc) ....... does anyone have any idea what that might be and if i should be thinking about hiting the panic button???? ............ power etc is not affected at all but i dont want to carry on riding the beast if it could damage something...... thanks in advance
rearwheel is offline
post #2 of 19 Old 09-10-2007, 05:39 AM
It's probably the fuel injectors. They make the exact noise you described.
post #3 of 19 Old 09-10-2007, 05:50 AM
No panic button needed. Ride the beast and enjoy!
post #4 of 19 Old 09-10-2007, 05:55 AM Thread Starter
Thanks hondajim ..... never having owned an injected bike i didnt know they made noise...... is that really normal and do they all do it ? cheers
post #5 of 19 Old 09-10-2007, 06:52 AM
Crotchety Rocket
cmelnick's Avatar
Donation Extraordinary Ride
1st of all, welcome. Second, "only" 800 miles on a 2-day old 9er is pretty nice, man! Good to know we have new kiwi friends!
- Stephen Hawking
cmelnick is offline
post #6 of 19 Old 09-10-2007, 09:55 AM
Madmotor's Avatar
My Honda mechanic told me that this sound was a spark knock and not to worry about it. I don't know enough about FI engines and/or timing issues to tell him he was wrong so I just keep riding it.
Madmotor
'06 919
Madmotor is offline
post #7 of 19 Old 09-10-2007, 12:27 PM
Madmotor
'06 919
Tell your mechanic in polite terms, he is full of crap! These 4 stroke motors do not exhibit 'spark knock'. You can run below grade Mexican piss gas in the 919 and it would not knock!
post #8 of 19 Old 09-13-2007, 04:29 PM
Mine just started making this similar noise today. I too thought it was detonation. Just injectors huh. 5700 miles.
Lemonhead is offline
post #9 of 19 Old 09-13-2007, 05:26 PM
My Bad
Pilsner's Avatar
My bet is that your bike has been making that noise all along, you just started noticing it today after reading this thread!
Pilsner is offline
post #10 of 19 Old 09-13-2007, 07:46 PM
Yeah, a little noise in these motors is normal. If you get one of those mechanics' stethoscopes and press it to the injector while the motor is running you'll hear the noise you're describing.
I'm not saying it's not possible for one of these motors to break, but I think it's very, very unlikely for a halfway well-maintained 919 motor to break down.
Speaking of noises, wringing out a 919 on the track will tickle your eardrums - you hear the injector clicks, the intake growl, the exhaust thump, and various other mechanical noises. 10,000 RPM at full throttle is a wonder to behold.
ajohn505 is offline
post #11 of 19 Old 09-14-2007, 06:13 AM
Ok, I won't stress about the noises then. Thanks AJohn.
I have played with the upper end of the rev band. A bit.
Does the niner even know when to stop ?
post #12 of 19 Old 09-14-2007, 09:56 AM
wisco919's Avatar
It lets you know when you can't go any further. It is quite a ways into the red before it hits it's limiter. It does not make much more power beyond the redline though.
wisco919 is offline
post #13 of 19 Old 09-14-2007, 01:14 PM
I was telling Ajohn at the track that an article I read suggested that power falls off after 7 grand. Who writes these things ?
Sidenote, Salesman at a H/D dealer that rode a Super Duke said that the duke fell on its face at 85 mph.
Now back to our regularly scheduled niner lauding
post #14 of 19 Old 09-14-2007, 01:24 PM
wisco919's Avatar
Did you ask if he tried to shift to second gear? The specs for the Duke put it right on par with the 9'er. Max torque probably comes on a little sooner in the revs but it should have no trouble getting beyond 85.
You can test ride one at Corsa Superbikes in Suakville.
wisco919 is offline
post #15 of 19 Old 09-15-2007, 05:52 AM
Hope you guys don’t mind my comment on my situation since we have almost fully tenderized this horse...
Other then the normal sounds that come off the 919, there is a certain situation that occurs with my bike that rasies a bit of a concern for me, and not sure if any of you guys have come across this...
While riding, say for example I am come into a turn, gear down and enter the corner at 50km, and I am in second, as I start to exit the corner and start to roll on the throttle (I am in 2nd gear), I get to a point while I am rolling on the throttle at about the ¾ point (I am pulling away fair aggressively), I start to hear a tapping sounds that does not sound at all like knocking, or normal pinging, it sounds like very high pitch tapping.. It sounds like as if two values are being tapped together as the sound is a very high pitch metallic sound, which concerns me greatly. At this point I will roll back the throttle just a bit and it stops, and I will continue on…
I have tried all grade of gas and it makes no difference...
The mods I have done to the bike are, Sato Exhaust, Flapper only
I assume then this is normal for our 919s???
thanks guys
CB900F2 is offline
post #16 of 19 Old 09-15-2007, 12:22 PM
thanks guys
I think I might have that same noise, is it around 5k-6k rpm? or is it non-rpm dependent? I would describe my noise as more of a buzz, but quite high-pitched like you said. I am completely unconcered by it.
motorwerks919 is offline
post #17 of 19 Old 09-15-2007, 03:59 PM
Found mine today. It was the drive chain screaming: HEY ! A-HOLE ! a LITTLE LUBE PLEASE !!!!
stupid rain.
post #18 of 19 Old 09-16-2007, 07:24 AM
I can hear it start around the 4.5K rpm mark, so yes, it is in that rpm range....
Do you pull back on the throttle when you start to hear it?, or ignor and keep on rolling the throttle on?
CB900F2 is offline
post #19 of 19 Old 09-17-2007, 05:12 PM
I just stay on the throttle, it stops after about 6k I think. I think my noise is just something buzzing, not sure where it is coming from, but I don't think nothing important. If we are talking about the same noise, I wouldn't be worried.
