Tachometer Confused - Wrist Twisters
post #1 of 16 Old 02-14-2010, 07:47 PM Thread Starter
Not so Rookie Anymore
stiggy8's Avatar
Question Tachometer Confused
My 06 9er has a weak battery (still original). Went to take it for a ride and it wouldn't start. pulled the battery out and then decided to jump it so I could get the ride in before the temps dropped.
So I successfully jumped it with my truck... so far so good. But heres the kicker... The tach decided to do a 360... it rotated all the way around... so now when it I'm reving the engine... the tach tries to rotate clock-wise but hits the stop at the bottom of the rev position. It is also getting hung up with the temp guage needle.
My question... is there a way to get the tach needle back to it's correct location? I'm not sure how it got to where it is... but it had something to do with the jump/battery remove/reinstall as all was fine before the jump. I'm baffled by this one.
Would appreciate any suggestions.
Temecula, CA (So Cal)
06-919
Pass it on.
stiggy8 is offline
post #2 of 16 Old 02-15-2010, 12:12 AM
Have you tried unhooking the battery again to see if the tach resets?
post #3 of 16 Old 02-15-2010, 10:56 AM
you may have fried your tach... jumping a motorcycle battery via car battery is NEVER a good idea. the battery for your bike is 6 volts vs the the car battery is 14 volts.
post #4 of 16 Old 02-15-2010, 11:11 AM
blur
drewvir's Avatar
no it's not
they're both 12v(@12.8v dc)
drewvir is offline
post #5 of 16 Old 02-15-2010, 11:21 AM
Vehicle Abuse Specialist
WheelieTime's Avatar
WheelieTime is offline
post #6 of 16 Old 02-15-2010, 11:23 AM
Right....
Someone else has described this problem. I'll search and try to find the solution.
post #7 of 16 Old 02-15-2010, 11:41 AM
cbr900racer77's Avatar
They are both 12 volts, but car/truck battery is pushing a helluva lot more amps. I've jumped bikes like that before but with very short bursts of cranking.
XX motor in a 900 frame...Come get some.
cbr900racer77 is offline
post #8 of 16 Old 02-15-2010, 03:17 PM
thanks for the correction. old mech gave me this info years ago so i never bothered to check it out.
i stand corrected. i love this forum.
post #9 of 16 Old 02-15-2010, 07:58 PM
The type of gauge used in the instrument cluster is called an "air core", and has no return to zero function. This is why the needle can get stuck on the wrong side of the gauge, and why later models (I think '04 and on) have a key on sweep to pick up the needle. In this case the battery was so depleted it's RTZ function won't work, and the wildly fluxuating voltage while cranking confused the gauge driver into thinking the engine was at redline.
If the needle is pointing straight down (the other "zero" position it has) and has gotten tangled up with the temp needle the only way I can think of to get it back to where it should be is to remove the instrument cluster, dismantle it to get at the needle and returrn it to the zero stop manually. If, however, it's at rest position is to the right of the needle it may be possible to get the needle to move with a strong magnet swept CCW across the meter face to chase it back. If the needle deflects toward the magnet just turn it around to repel instead of attract.
It's doubtful if the tach is "blown", just a bit discombobulated (Precise technical term!)
Oh, replace the battery.
post #10 of 16 Old 02-15-2010, 08:25 PM
Speed Lover
XRCajun's Avatar
Batteries don't push current. The load, (instruments, starter, lights, ect) draw current from the battery as needed. So if the car battery is 12V and the object drawing current from it is indented to operate off of 12V and is functioning properly then it will only draw the amount of current it was intended to draw. So doing short start bursts off of a car battery won't make any difference if all components are good.
XRCajun is offline
post #11 of 16 Old 02-15-2010, 10:12 PM
ya i was just bout to say.... batteries dont push current they just store it.
post #12 of 16 Old 02-15-2010, 10:55 PM Thread Starter
stiggy8's Avatar
Thaks for the info... I had heard that the car-motorcycle jump wasn't the ideal... but figured it shouldn't hurt a more modern bike. It was only connected for about 15 seconds to get her going.
I did disconnect everything prior to my original posting to see if it would do a reset and that didn't help. I'll give the magnet a go per Rob's post. I have a couple of different magnets... strongest being an old computer hard drive platter magnet.
I was thinking about trying to reverse the polarity to the tach to see if I could get the needle to spin opposite direction. Is there any rationalization for that approach?
Really hate to take the tach apart... never seals up as well as at the factory... but do want to get my RPMs back.
Again. Thanks. And yes a battery is on my short list of things to buy. Suggestions on where to purchase would be appreciated as well.
06-919
Pass it on.
stiggy8 is offline
post #13 of 16 Old 06-04-2010, 10:56 PM
oy05's Avatar
Stiggy8
Did't you find a solution - did't anyone find a solution to this problem, mine did't exact the same thing yesterday, only I was driving (I think, did't see it) when it happen't.
So now my needle's are "stock together"...
(My battery is okay, it was dry and hot when it happen't, the watercooler fan startet up at least one time, during the 15 km. when it happen't)
I have removed the fuse to the instrument's in order not to make the problem even worse, until a solution can be thought of..... did't the magnet do any good ? what have you done to fix the problem..............?
In advance thank's for any kind of advice
Hans - DK
oy05 is offline
post #14 of 16 Old 06-05-2010, 11:02 AM
oy05's Avatar
Well hat the meters apart, "forced" the needle back - and apperently everythings okay again..... I wonder what made it happen in the first place ?
Think I will pull the meters apart, and make a stop to the needle, at the end of the red scale, preventing it from happening again....
oy05 is offline
post #15 of 16 Old 06-24-2013, 01:13 AM
Easy fix
I know this is an old thread, but this recently happened to my hornet 900 (919). It seems if the battery gets tired, some circuitry gets confused and the fly up/fly back mechanism operates incorrectly. Somehow, the tacho needle went too far and ended up nearly 1 complete revolution from it's resting position at 0. As a result, it got stuck to the left of the temp gauge.
Taking the clocks off looked difficult to me, so a friendly bike mechanic suggested drilling a small hole in the side black plastic of the tacho. This allowed a thin piece of wire to be inserted and used to gently ease the needle back to the correct side of the temp gauge. Switching the ignition on then put the needle in it's correct place at 0. A blob of black mastic sealant made it waterproof again and you can't see where the hole was. A neat 5 minute job. And of course I replaced the battery first!
pombiker is offline
post #16 of 16 Old 06-24-2013, 10:01 AM Thread Starter
stiggy8's Avatar
Noticed that I never posted back on this issue. I ended up pulling the instrument cluster apart and popped the needle back the other side. Was actually much easier than expected. Just made sure that I kept the area clean/dust free as best I could and got in and out in an hour or so. No problems since. I now have a battery tender and the bike gets connected anytime it has to sit for more than a few days. A cager buddy recommended the tenders and swears by them for all of his vehicles... and he has a 6 car garage full. So no dead batteries since!
06-919
Pass it on.
stiggy8 is offline
