Strange *&#$%! Noise - Wrist Twisters
post #1 of 23 Old 01-07-2007, 07:00 PM Thread Starter
Question Strange *&#$%! Noise
I wonder if any of you have heard a buzzing noise at around 4000- 5000 rpm. It just started recently and I can't find it - It's officially driving me nuts. I've been in and out of the headlight bucket a bunch and have sealed that up pretty good. Almost sounds like two pieces of sheet metal buzzing together directly under the tank.
Idea....
raamhammer is offline
post #2 of 23 Old 01-07-2007, 07:09 PM
fat guy on a little bike
kingbrian24's Avatar
yes..... but my buzzing is the clutch lever for the most part among the rest of the bike....
kingbrian24 is offline
post #3 of 23 Old 01-07-2007, 07:12 PM
Go'n So slow I'm stopped
xrmikey's Avatar
Idea....
Just a thought. Look under the engine & see if your lower, rear, exhaust support is broken. I had a buzz noise & that was it. The pipe mount was vibrating against the frame bracket.
xrmikey is offline
post #4 of 23 Old 01-07-2007, 07:17 PM
xrmikey's Avatar
Had that too . But only at idle without my hands on the grips. While riding, I always have a finger on each lever. New levers fixed that. Ha!
xrmikey is offline
post #5 of 23 Old 01-07-2007, 07:26 PM Thread Starter
That is something I have not checked - thanks XR I'll take a look.
I generally ride w/ my hands on the leavers so I'm sure it isn't those but thanks kingbrian
post #6 of 23 Old 01-07-2007, 07:59 PM
Duckin' for cover..
SoCal919's Avatar
I vaguely recall reading a post about the horn being loose and buzzing at that rpm. It may have also included the radiator shroud. Check those out.
SoCal919 is offline
post #7 of 23 Old 01-07-2007, 08:01 PM
xrmikey's Avatar
What Horn....?
xrmikey is offline
post #8 of 23 Old 01-07-2007, 09:51 PM
I have the same buzz of death. My headlight bucket is a rediculous mess of insulation foam and electrical tape, that think couldn't rattle if it's life depended on it. I have also lifted the tank and put insulation foam all over the top, and sides of the frame tube to no avail. After this, I have come to the conlcusion that it is the cooling fan, I plan to mess around and try to fix it but it might be unfixable, I know this because of this thread: on Hornet's Nest
motorwerks919 is offline
post #9 of 23 Old 01-08-2007, 06:03 AM
earplugs
post #10 of 23 Old 01-08-2007, 06:43 AM
Duckin' for cover..
SoCal919's Avatar
I think that was the thread I was thinking of, . Not the horn but the cooling fan. Hope that helps.
SoCal919 is offline
post #11 of 23 Old 01-08-2007, 06:58 AM
libertine
jlux21's Avatar
Wrist Twisters Event Attendance Wrist Twisters Event Attendance Donation Donation
It is called a Hornet.
jlux21 is offline
post #12 of 23 Old 01-08-2007, 08:03 AM
get louder pipes and do the flapper mod. You won't here any buzzing after that
MichaelRM is offline
post #13 of 23 Old 01-08-2007, 08:17 PM Thread Starter
You know - I tried the flapper mod and heard/felt no difference Is this mod an urban legend or am I missing something. Does anyone have any data?
post #14 of 23 Old 01-08-2007, 08:51 PM
Honda Addict
razorbike's Avatar
Dr. Razor prescribes Satos. 2mg.
razorbike is offline
post #15 of 23 Old 01-09-2007, 02:46 AM
i remember someone having a buzzing sound under the tank a long time ago it turned out to be the ground cable that goes from the tank to the frame was in a bad spot and vibrating.
typhoonblue919 is offline
post #16 of 23 Old 01-24-2007, 06:30 AM Thread Starter
I've been off the bike a lot lately so finely just had time to go through it again looking for this buzz. I think I found it, one of the rubber bumpers on the side cover was gone and metal upon hard plastic buzzing ensued. I'm pretty sure it was the culprit but will know more this weekend
post #17 of 23 Old 01-24-2007, 09:40 AM
Reese's Pieces...
reese919's Avatar
Here's a different thought... Do you have a keyring for your bike or just the key itself? I had a buzzing that drove me muts for a while until I realised that it was the key for my heltmet lock buzzing against the handlebars. :shrug: Just a thought.
reese919 is offline
post #18 of 23 Old 01-24-2007, 12:08 PM
I did the flapper mod as well and neither felt nor heard any difference at all. Not sure what it's 'supposed' to do, but since it didn't change anything I just left it that way. Maybe someday it'll surprise me and do something when I least expect it
Ok, back on topic now...
post #19 of 23 Old 01-24-2007, 12:36 PM
Are you talking about the gray side cover or the black plastic one?
post #20 of 23 Old 01-24-2007, 12:41 PM
My headlight was contributing to the buzzing noise until on of the mechanics at my shop put plastic washers on the mounting bracket. That really reduced the noise, but the bike just has some extra vibration in those rpm ranges. You should see my flyscreen shake..........
ybnrml8932 is offline
post #21 of 23 Old 01-24-2007, 01:54 PM
Corner speed sets u free
streakin919's Avatar
mine was coming from the chrome headlight rim. I put some foam rubber between it and the bucket, cleared it right up.
streakin919 is offline
post #22 of 23 Old 01-24-2007, 08:03 PM Thread Starter
It was the plastic one, the bumper missing is the one tucked back underneath the tank, at the front of the side cover. If I wasn't so lazy I'd go out and shoot a photo
post #23 of 23 Old 01-24-2007, 09:15 PM
Thats alright, thanks, I am going to check mine when the temp in my garage gets reasonable again, probably 2 months before that happens.
