speedo healer and 15t - Wrist Twisters
post #1 of 6 Old 11-22-2008, 03:50 AM Thread Starter
Going to get a speedo healer soon.
With new Pilot Powers, and a 15t front, is 13% correction correct?
post #2 of 6 Old 11-22-2008, 04:22 AM
probably best practice to calibrate regardless of what others have found, just my opinion though
post #3 of 6 Old 11-22-2008, 12:41 PM
91_4x4runner's Avatar
If I were you, I'd find a flat road, borrow a buddies GPS, hold it at speed, and see how far you're off at a few different speeds. Should give you a good idea...
EDIT: Furthermore, if you found said flat road, you could calculate it by timing the mile markers.
91_4x4runner is offline
post #4 of 6 Old 11-23-2008, 06:50 AM Thread Starter
I have a Magellan unit. I don't think it's meant to be on a motorcycle, but I've had it on my 600 before. You can't read it in sunlight. I'll stick the GPS on the 919 to double check. I am really looking for a starting point.
post #5 of 6 Old 11-23-2008, 09:30 AM
What do you need a speedo for?
Let me know how much it is off, I'm going to do the 15T and wonder what a difference it will make. That and the GP exhaust will be a loud nasty mofo!
Ripper is offline
post #6 of 6 Old 11-25-2008, 07:32 AM
DaveCB919F4
Fastbackdlm's Avatar
Go to the drag strip and cruise through the speed trap at 100mph indicated on the speedo. This will give you error %. Several threads have documented the stock error at 8% the speedo-healer corrects for speedo error at 5.5% so if you increase the recommended correction factor by 2.5% it should be real close. I have checked my speedo at the track and going through the traps at 100 indicated results in a measured speed of 98.5. I can live with a 1.5% error.
Fastbackdlm is offline
