Spark plugs - Wrist Twisters
post #1 of 28 Old 03-04-2010, 06:46 AM Thread Starter
Kingston's Avatar
Spark plugs
The Honda 919 manual saids to change the plug at 8000 miles. I'm at 10,000 and they look and run good (except #3 plug, couldn’t get it out). My question is, has anyone got more mileage out of their plugs than 8000 miles?
Kingston is offline
post #2 of 28 Old 03-04-2010, 07:00 AM
I've gotten more mileage out of a set of plugs by pulling them out and cleaning them up. I just replace them now (just as much work, less frequency, more cost)
To get #3 out, use the tool kit that comes with the bike. If you didn't get a tool kit, I suggest a swivel attachment or u-joint for your ratchet/socket.
post #3 of 28 Old 03-04-2010, 09:21 AM
Sixty-9er
edgecrusher4444's Avatar
I'm guessing most use NGK plugs but does anyone have an opinion on Autolite Xtreme Sport Iridium plugs? I saw these the other day for about 3 bucks a piece on clearance.
Autolite :: Motorcycles : Small Engine Spark Plugs
"Grip it and Rip it!"
edgecrusher4444 is offline
post #4 of 28 Old 03-04-2010, 10:33 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
I have doubled the interval for plug changes on the 919 without consequence. 16K is just fine by me and I am coming up on another plug change at 48K. I am going to try a set of CR8EHIX-9(Iridium) in my ST1300A next time.
The tool that Honda supplied in the factory kit saved the day for me when changing plugs.
Doc
ST-DocLizard1 is offline
post #5 of 28 Old 03-04-2010, 12:52 PM
id rather run a good quality standard plug like the ones that comes in the bike rather than a cheap iridium.
post #6 of 28 Old 03-04-2010, 01:13 PM
woodyeee's Avatar
I changed mine at 26000 miles and they still ran and looked ok
woodyeee is offline
post #7 of 28 Old 03-04-2010, 02:46 PM
I went to somewhere in the mid 20K range before I changed mine.
post #8 of 28 Old 03-04-2010, 06:37 PM
Check you manual again, my manual says check plugs at 12,000 kms (8,000 miles). Replace at 24,000 (16k miles).
Obviously if they look crap when checking then replace, otherwise good to go.
post #9 of 28 Old 03-04-2010, 06:55 PM
If the engine is not using oil, you are running pump gas, and have factory spec plugs, something is wrong of the plugs are not good for 24 K kms or 16 k miles.
Like the gent said, the manual says check at half distance, not change at half distance.
post #10 of 28 Old 03-04-2010, 10:27 PM
What's a 919?
RoboStraub 919's Avatar
Technically if your gap is correct, no corrosion is present, you can clean them and keep using them for a long time, but...
id rather run a good quality standard plug like the ones that comes in the bike rather than cheap iridium.
Just wondering how you think a metal that is stronger, harder, and can withstand higher temps than standard plugs, cheap?
Slow is smooth, smooth is fast.
RoboStraub 919 is offline
post #11 of 28 Old 03-04-2010, 10:35 PM
if the 919 needed iridium it woulda came with an iridium... there is a reason mr honda used a standard style plug to begin with and ill be stickin with just that as it works like a charm.
post #12 of 28 Old 03-04-2010, 11:52 PM
What's a 919?
Though he died well before the 919, I would say Honda, just like nearly every other manufacturer uses standard plugs, because standard riders don't really care that much about their machines. But for those who want to give our prize possessions every extra goodie they can, even if being minimal improvement, there are parts/accessories that improve on the technology available at the time the bike was made.
With the mentality of; do motorcycles need to be improved from their basic design, you should apply for a job with Harley-Davidson.
It's like Hot Sauce, does pizza need to be splattered with it? No. Does it make it better? Yes.
post #13 of 28 Old 03-05-2010, 02:51 AM
Red Rider
Woody469's Avatar
Anyone tried the E3's? I've been thinking about it!
My blood runs Honda Red......
2003 Honda 919
2004 Honda 599
1999 Honda XR650L
Woody469 is offline
post #14 of 28 Old 03-05-2010, 07:18 AM Thread Starter
Kingston's Avatar
My owner's manual does say to replace plugs at 8000 miles/12.8Km. Here in Canada, the Honda dealer wants $15 plus tax for these NGK CH9EH-9 plugs. I will be cleaning them and checking the gap.
Kingston is offline
post #15 of 28 Old 03-05-2010, 08:20 AM
I think I changed mine at 24,000 miles. For me, it was a waste of time and money because the bike didn't run any better. The old ones looked fine. Actually, they ended up in a friend's 600.
post #16 of 28 Old 03-05-2010, 09:25 AM
My local stealer quoted me $12.99 for them. I asked him, "for all four, right?" and then walked out when he said no...they can be had at many auto parts stores for less than $5 Napa, Checker, Autozone....
post #17 of 28 Old 03-05-2010, 09:30 AM
I believe that the iridium vs standard plug argument is a butt-dyno issue....I haven't read anything on here yet that definitively states that the iridium plugs improve the engine's performance significantly.
post #18 of 28 Old 03-05-2010, 09:35 AM
so your telling me that The engineers wernt thinking of the necessary plug when making the 919? So that is why they just stuck an iridium plug in my CRF250x cus the figured why not? its a race motor so we gotta put an expensive plug in it even though it doesnt need it? I highly doubt that.
alls im saying is that if the 919 needed special fancy plugs to run properly it woulda come with it... exactly like if it needed 91 octane (like my crf250) they woulda specified 91 and not just the 87 regular.
Now if you find something that says your gonna make more power by going to fancy iridium plugs then hell ya go for it... but i dont think thats the case.
post #19 of 28 Old 03-05-2010, 11:08 AM
What's a 919?
*sigh* this is boring. So now, we're beginning a 'does higher octane burn better' argument? lol I'll just go back to the standard rider analogy.
over...
post #20 of 28 Old 03-05-2010, 11:38 AM
someone completely missed the point i made.
post #21 of 28 Old 03-05-2010, 01:33 PM
Serial Monogamist
Total Awards: 21
FYI. Looks legit to me. Hence, I will try a set at the next plug change on the ST1300. Two Brothers got me a set of four at $35.00 shipped.
Iridium spark plugs by NGK and Denso
I think at the very least you may get more life with less changes. I don't feature going in after plug #3 on the 919 if I don't have to.
Doc
post #22 of 28 Old 03-06-2010, 12:48 PM
Hornet Grandpa!
Doc
I installed them because they last longer, not because they perform better. However, I guess you could say the perform better as the standard plugs age and wear.
O:\General Info\member1804.jpg
support_six is offline
post #23 of 28 Old 03-08-2010, 03:35 PM
the only thing iridium plugs do is last longer .like 200,000 miles in a chevy tahoe.i seen it myself .no performance improvement .
lobo is offline
post #24 of 28 Old 08-05-2011, 01:16 PM
outdoorgb's Avatar
Not sure about the 919...but on both of my Toyota vehicles iridium does make a differnce in life. Camry - owners manual lists 90K using Denso iridium ($12 each), Tacoma - 30K using non-iridium ($3.50 each)...
In all of my rigs I always replace with OEM.
Be Prepared!
outdoorgb is offline
post #25 of 28 Old 08-05-2011, 01:50 PM
curiousmike's Avatar
Replacing plugs seems superfluous; i'll experiment and be the guy who never changes his plugs. I'll let you know what foul thing happens to me.
curiousmike is offline
post #26 of 28 Old 08-05-2011, 01:51 PM
Get it? "foul" thing?
hhahahahahaha
post #27 of 28 Old 08-05-2011, 02:15 PM
hhahahahahaha
yes, you are very 'punny'...
post #28 of 28 Old 08-05-2011, 02:23 PM
outdoorgb's Avatar
What are the signs of a fouled plug(s)?
I remember what it feels like a single cylinder Kawi way back when...but what about a big four cylinder?
Be Prepared!
