Spark plug change or not? - Wrist Twisters
post #1 of 19 Old 09-17-2008, 10:43 AM Thread Starter
Hey everyone. I'm coming up on the 8k mile mark which means spark plug changing. I've read thru some past threads and the general consensus seems to be it's not really needed that early. Is this correct?
Thanks,
Cris P.
s2cmpugh is offline
post #2 of 19 Old 09-17-2008, 12:01 PM
i honestly dont think they need to be changed at 8k... but i have been wrong before... is it running good?? dont fix it.. if its running rough?? the price of a set of plugs aint that much..
post #3 of 19 Old 09-17-2008, 12:18 PM
Hey barton, your avitar is AWSOME!
Professional
post #4 of 19 Old 09-17-2008, 12:35 PM
why thank you sir
post #5 of 19 Old 09-17-2008, 01:57 PM
I'm at about 17,000 miles and am going to change my plugs. The previous (original) owner said he had not changed them so I'm going to do it this week.
post #6 of 19 Old 09-17-2008, 02:57 PM
Get some of semi-gray's block off plates and change the plugs when you install them.
post #7 of 19 Old 09-17-2008, 03:36 PM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
I did the first change at 16K and have yet to do the second with 35K on the clock.
Doc
ST-DocLizard1 is offline
post #8 of 19 Old 09-17-2008, 05:04 PM
robtharalson replaced his after 47,224 miles.
post #9 of 19 Old 09-17-2008, 08:27 PM
I replaced my plugs at 18,000 miles and added Block of Plates from semi grey. I would say that the plugs still have a good bit of life left in them and I put them in a box to possible use at a later date if I can't afford to replace plugs, but they are not that expensive so i doubt that will happen.
I'd say don't worry about the plugs unless you are adding the block off plates or just really want to do some work to your bike.
post #10 of 19 Old 09-17-2008, 08:29 PM
i have a question???? what are block off plates?? and what do they do??
post #11 of 19 Old 09-17-2008, 08:48 PM
I have a question for you.....Do you know what the Flapper mod is? The block off plates are basically finishing up the Flapper mod and get rid of a bunch of vacuum hoses and cleans up the engine up by your spark plugs. They also help backfiring.
Block off plates are the chrome things on the engine right behind the spark plugs wire. Examine what they look like and then go look at your engine.
post #12 of 19 Old 09-18-2008, 09:09 AM
ohhhhh thats a block off plate... ok..
post #13 of 19 Old 09-18-2008, 09:34 PM
BrokeRecord
I changed mine at 15,000 and could have waited much longer.
brokerecord is offline
post #14 of 19 Old 09-19-2008, 03:40 AM
Changed mine at 8K...prob didnt need it. I put in Iridiums, so not planning to change again for a long time.
post #15 of 19 Old 09-19-2008, 05:48 AM Thread Starter
Well it sounds like I shouldn't worry too much about changing them now. On long highway trips I'll average around 50+ mpg when holding a constant speed, so I'm assuming everything is running good.
Maybe I'll do them when I get around to it and the block off plates.
s2cmpugh is offline
post #16 of 19 Old 09-19-2008, 06:09 AM
DaveCB919F4
Fastbackdlm's Avatar
Just run the recommended NGKs. Accept no substitutes. I've run other brands in my hondas over the years and the NGKs work best.
Fastbackdlm is offline
post #17 of 19 Old 09-19-2008, 12:26 PM
Shoot to stop
beardking's Avatar
If you bike is bone stock, do you get any benefits from installing the block off plates?
beardking is offline
post #18 of 19 Old 09-19-2008, 12:31 PM
You will notice small differences if you are in tune with the bike. Take a good ride and then do the flapper and block offs and then take another ride over the same route and you should be able to tell the difference. I highly recommend them.
My friend complained that his bike did not seem like it had enough air while we were riding aggressively. I disconnected the flapper and before we were out of the neighborhood he commented that the bike was much better. He just ordered the Pair block off plates.
post #19 of 19 Old 09-19-2008, 12:36 PM
Shoot to stop
beardking's Avatar
Where should someone order the plates? I remember reading that someone on here was selling them, but can't find it again.
