so i'm thinking about buying this... - Wrist Twisters
post #1 of 10 Old 04-30-2010, 08:54 AM Thread Starter
rider
- Your Shopping Cart - Indysuperbikes
any comments?
s10hornet is offline
post #2 of 10 Old 04-30-2010, 09:02 AM
Cool! An empty shopping cart, that's gonna be pricey.
dadogs is offline
post #3 of 10 Old 04-30-2010, 09:05 AM
post #4 of 10 Old 04-30-2010, 09:06 AM
Do it, you only live once.
Do they have a payment plan?
PAULIBIKER is offline
post #5 of 10 Old 04-30-2010, 09:14 AM Thread Starter
rider
post #6 of 10 Old 04-30-2010, 09:32 AM
If you can get it for $248, I say go for it.
post #7 of 10 Old 04-30-2010, 10:07 AM
Ballaholic
hornet919's Avatar
thats pretty cheap for a full exhaust i wish there was away to adapt a header onto the 919 y pipe. the underseat exhaust really makes the bike. looks like crap w/o it
hornet919 is offline
post #8 of 10 Old 04-30-2010, 10:57 AM
Hippie Tinkerer
mntnceguy's Avatar
Read the listing better...the $248 is only for the can, not full exhaust...they don't even sell the full system anymore, or it would be in the drop down menu...
Build List in Spoiler
SOLD SOLD SOLD
When Sold:
599 Headlight
Koso Gauges DB-02r
GiPro gear indicator
Givi Crash bars
Seargent seat w/ gel insert
Dyna Beads for tire balancing
Piaa horns 400 & 500 hertz
Tech-Spec custom tank Pads
Napoleon bar end mirrors
SW-Motech center stand
Shorai Battery
Hydraulic rear brake switch
Powdercoated: 22+ parts
etc, etc,
mntnceguy is offline
post #9 of 10 Old 05-01-2010, 07:18 PM
Gets censored
brian is offline
post #10 of 10 Old 05-01-2010, 08:40 PM
So, you're a human...
adamjayp's Avatar
Full Exhaust System: Taper header tube, large primary header, 4 into 2 into 1 style, and duplex crossover are features you will find on our Yoshimura Full system. They increase low and mid range torque while allowing maximum gain in high end horsepower.
That's kinda ambiguous there, since it says "bolt on exhaust" then the picture shows all the parts including the header, then this in the description. That price is weird too, it seems too low for a full system, and too high for a slip on can. I'd call and ask them first. The drop down appears to describe which cans you can get the system with, or it could be like mntnceguy said and it's JUST a can. Either way, I'd make sure.
adamjayp is offline
