Side Cover Problems...Help - Wrist Twisters
post #1 of 9 Old 01-16-2007, 03:31 PM Thread Starter
Hey guys maybe someone can help me out with the side cover problem that I'm having. The two plastic side covers that are located just under the seat are getting pushed out of the rubber grommet. This happens while riding twisties. When I pull my seat off I have to push them back into the rubber grommet. Any advise on how to fix the problem. Thanks Tony
Mountain Road Madness is offline
post #2 of 9 Old 01-16-2007, 03:38 PM
Church of the Holy Smoke
MotoCycho's Avatar
Yup! I had the same problem. Originally I would make sure that the flat peg thingy was pressed up against the top of the rubber grommet as I tightened the screw. This put tension on the flat peg and helped a bit. Then I found if you actually hold it out of the rubber grommet and slightly higher than the hole while you tighten it, it will have pretty good tension upwards as you can put it back in the hole. Finally I lost one of the rubber grommets. This led me to a far better solution. I replaced the oval shaped rubber grommets with some thicker round ones. As you force them into the holes they take on an oval shape and the opening for the flat peg/tap is a much tighter fit.
Give me a few minutes and I will get some pics posted.
- Rev. CYCHO -
MotoCycho is offline
post #3 of 9 Old 01-16-2007, 03:45 PM Thread Starter
Cool I'll hang out here for the pics. man. Thank you very much.
post #4 of 9 Old 01-16-2007, 04:04 PM
MotoCycho's Avatar
Here ya go.
Right side grommet from under the seat:
(looks like this one will need to be replaced soon.)
Left side with side cover pulled away:
Comparison with the Honda oval grommet on the left:
Sorry, I don't know the actual size of these grommets. I have had them in a bin for years. I'm sure you can fine something comparable at a "Home" or auto parts store.
- Rev. CYCHO -
post #5 of 9 Old 01-16-2007, 04:25 PM Thread Starter
Thats a good deal man. Thank you very much. I'll have to go pick some new ones up. Again thanks man.
post #6 of 9 Old 01-19-2007, 12:55 PM
I'll jump in here real quick - if you ever find the left one missing check your airbox. Mine was gone and found it in there must have been sucked in.
raamhammer is offline
post #7 of 9 Old 01-20-2007, 05:33 AM Thread Starter
Thanks for the heads up man. The air intake is in a good spot to suck that right in there.
post #8 of 9 Old 01-20-2007, 06:03 AM Thread Starter
Little update guys. I took the side covers off of the bike. I drilled a small hole in each tab of the side cover. I reinstalled the covers and installed a small clip pin into each tab. I'll let you guys know how it works. If it works out, I'll post some pictures. Thanks Tony
post #9 of 9 Old 01-21-2007, 12:47 PM
Honda Addict
razorbike's Avatar
That's a pretty damn good idea MRM!
Had the same problem on mine also. Gonna pin 'em ASAP. That along with Cycho's idea with the grommets and they should stay put.
razorbike is offline
