Shaving cream = NO FOG !!! - Wrist Twisters
post #1 of 29 Old 10-23-2008, 09:23 PM Thread Starter
Hippie Tinkerer
mntnceguy's Avatar
I read a post in a thread here recently, don't remember which one, about this shaving cream trick to keep your visor from fogging. I truelly thought it was a joke, but being the curious and sometimes gullable type, I tried it tonight. AND OMG....it works!!! At least it did tonight, but its only like 40's out right now. I'll see how it does on my way to work tomorrow morning when its a bit colder. If it still works, it'll be a life saver for me for sure. I've been riding to work lately unable to see much, unless I lift the shield a bit, which practically freeze drys my eyeballs in a hurry! I thought the post was a joke, but now I feel like I'm the only one who didn't know about this trick So now I gotta ask....are there any other tricks like this one???
And BTW...THANK YOU GUYS !!! This site has been a wealth of info for me, saved me time and money, and taught me things I didn't even know I needed or wanted to know....ya'll ROCK!!!
Build List in Spoiler
SOLD SOLD SOLD
When Sold:
599 Headlight
Koso Gauges DB-02r
GiPro gear indicator
Givi Crash bars
Seargent seat w/ gel insert
Dyna Beads for tire balancing
Piaa horns 400 & 500 hertz
Tech-Spec custom tank Pads
Napoleon bar end mirrors
SW-Motech center stand
Shorai Battery
Hydraulic rear brake switch
Powdercoated: 22+ parts
etc, etc,
mntnceguy is offline
post #2 of 29 Old 10-23-2008, 09:27 PM
I will have to try this. Because my Sparx helmet visors don't have any anti-fog treatment applied during manufacturing. Just spray it on and wipe it clean?
post #3 of 29 Old 10-23-2008, 09:28 PM
I like that. I may have to try it. I use my SCUBA mask anti-fog. Have used spit in a pinch. Works well.
Men's shaving cream is a great exfoliant also. Seriously, a plastic surgeon friend of mind has all his female patient use mens shaving cream all over their face prior to bedtime and in the morning as and exfoliant. He tells all his "peel" patients to avoid soap for a few weeks and wash with shaving cream.
RC51_CBRXX is offline
post #4 of 29 Old 10-23-2008, 09:35 PM
You can also use shaving cream for your bathroom mirrors, so they are not foggy when you get out of the shower!
2526 is offline
post #5 of 29 Old 10-23-2008, 09:40 PM Thread Starter
Hippie Tinkerer
mntnceguy's Avatar
Smear and Clear
Just smear it on, leave it for awhile, and rinse it off, then dry. I forgot I did it the first coat and left it on for like 45mins, but it rinsed right off. I used warm water to rinse, then dried with a towel, went outside....and NO fog....whatsoever.....even when I tried to fog it up. So just for good measure I brought it inside and applied another coat... Anyway, like I said, I'll update tomorrow after I go for the really cold ride to work in the morning
SOLD SOLD SOLD
When Sold:
599 Headlight
Koso Gauges DB-02r
Givi Crash bars
Shorai Battery
etc, etc,
post #6 of 29 Old 10-23-2008, 09:42 PM
(oYo)
2000TJ's Avatar
Shaving cream works great for removing camo face paint when coming out of the field as well.
2000TJ is offline
post #7 of 29 Old 10-23-2008, 09:43 PM
if you wear glasses don't forget to give them the shaving cream treatment too, otherwise you will have foggy glasses inside your no fog visor.
2526 is offline
post #8 of 29 Old 10-23-2008, 09:45 PM
Now I have to go buy shaving cream. Haven't used that stuff in years. I dry shave my face.
post #9 of 29 Old 10-23-2008, 09:47 PM
boogerface
mikochu's Avatar
Wonder if this will work with any shaving cream...I use Aveeno for my sensitive skin :P
Michael Reyes
mikochu is offline
post #10 of 29 Old 10-23-2008, 09:48 PM
Yes! and you can also use it to clean your guns and jewelry and it works like wd-40 on squeaky hinges and stuff.
2526 is offline
post #11 of 29 Old 10-23-2008, 10:10 PM Thread Starter
Hippie Tinkerer
mntnceguy's Avatar
Hot water works best!
Ok, update sort of...Hot water seems to have the best effects. I tried it with cold water rinse, and it fogs right up, but hot water rinse and no fog at all
SOLD SOLD SOLD
When Sold:
599 Headlight
Koso Gauges DB-02r
Givi Crash bars
Shorai Battery
etc, etc,
post #12 of 29 Old 10-23-2008, 10:20 PM
ok this is b.s. i tried the shaving cream thing... i put my helmet on and mary filled it up... that shiiit burned my eyes i couldnt see anything! it got up my nose... and it is gonna take a month to get my shoei cleaned out... gee thanx guys........
just kidding... the honda polish in the spray can works really good also...
post #13 of 29 Old 10-24-2008, 06:45 AM
hawkeze's Avatar
Bar soap works also. Just slightly wet fingers, rub on soap bar then on visor and wipe with dry cloth.
hawkeze is offline
post #14 of 29 Old 10-24-2008, 08:53 AM
Were not talking about what cream you use to shave your butt!
Does Aveeno work good on dingleberrys? Cause this new paper we use just rolls up and makes more, it kind of like a tampon for my butt now!
Ripper is offline
post #15 of 29 Old 10-24-2008, 09:33 AM
I wonder what kind of corrosive effects it might have on the plastic? Any chemists out there??
I started shaving in the shower when I was a teenager with one of those fogless mirrors because my hair is so course. Those mirrors only seem to work for a couple of months. I don't remember now where I heard about the effects of shaving cream on mirrors, but once the fogless mirror started fogging slightly, I started using shaving cream on it. It seemed to me the shaving cream was accelerating the rate of deterioration of the antifogging properties of the mirror. Some reaction with whatever substance is applied to the mirror to keep it fog free I presume.
Makes me wonder what, if any, long term effects it might have on your shield.
919VQ is offline
post #16 of 29 Old 10-24-2008, 10:21 AM
Wookie
ragdoll's Avatar
RC90 has been putting his excess KY Jelly on his visors for years.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #17 of 29 Old 10-24-2008, 10:26 AM
never heard of such a thing as "excess KY Jelly"?
Ripper is offline
post #18 of 29 Old 10-24-2008, 11:00 AM
Wookie
ragdoll's Avatar
Neither has he... that's just my take on it.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #19 of 29 Old 10-24-2008, 11:00 AM
(oYo)
2000TJ's Avatar
Friction is important.... that's all I've got to say.
2000TJ is offline
post #20 of 29 Old 10-24-2008, 11:00 AM
Unbannable
Super Sneaky Steve's Avatar
Another good thing to do is put some rain-X on the front of your shield. Bugs don't stick and if you get caught in the rain you can still see.
Super Sneaky Steve is offline
post #21 of 29 Old 10-24-2008, 11:40 AM
Tonight we ride
Nemo's Avatar
The best thing I've found for fog is one of those Respro Foggy half masks (sold at Cycle Gear and in the Aerostich catalog, around $24). It velcros into your helmet and prevents your breath from fogging up the shield, and I never have to worry about applying spit, shaving cream, dish soap, or anything else to my face shield. Good stuff.
Nemo is offline
post #22 of 29 Old 10-24-2008, 11:55 AM
Tirone is the Cool Dude
Timmy S's Avatar
Nemo,
Does the respro foggy touch your nose or face? I do find that when the anti fog nose guard in my shoei touches my face it is an irritant. It looks to me that the respro kind of bends over your nose to me. Let me know. Thanks
Tim
Timmy S is offline
post #23 of 29 Old 10-24-2008, 12:40 PM
Tonight we ride
Nemo's Avatar
Yes--the top of the mask goes over your nose, and has a clip to hold it on. Here's a pic (not me, some random internet reviewer wearing one in his helmet)
If the contact bothers you, better to stick with no-fog shields and shaving cream or saliva. I kind of like the extra warmth and that Darth Vader feeling.
Nemo is offline
post #24 of 29 Old 10-24-2008, 07:18 PM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
Liquid dishwashing soap works for me.
Doc
ST-DocLizard1 is offline
post #25 of 29 Old 10-24-2008, 07:31 PM Thread Starter
Hippie Tinkerer
mntnceguy's Avatar
Update...if anyone needs one
Well....not bad...definatly better than spit or the rainx nofog stuff....but still not perfect. I had very little fog on the 32 degree morning ride today, but still had some. I was kinda wondering about the long term effects on my shield as well. Looks like I'll be trying one of those Respro things, thanks for the tip!
SOLD SOLD SOLD
When Sold:
599 Headlight
Koso Gauges DB-02r
Givi Crash bars
Shorai Battery
etc, etc,
post #26 of 29 Old 10-25-2008, 11:54 AM
me too
post #27 of 29 Old 10-25-2008, 01:22 PM
So, you're a human...
adamjayp's Avatar
+1 for the dish soap. I use it in my army goggles, and on my old AGV helmet... and my glasses before I had laser eye surgery. Most of the "anti-fog" stuff is just a thin layer of soap anyway, so just use dish soap or shaving cream. Since dish soap is a "mild soap" you can feel free to use it on your visor, since they (at least the ones I've seen) say to clean with soapy water on the instructions sheet. Remember not to use dish soap to wash your bike though, or if you do polish and wax right away, since dish soap is designed to break down grease and oil, it will strip your wax right off, and six months later - since you parked it in your mom's backyard - you'll have an oxidized mess to clean up. Be safe.
adamjayp is offline
post #28 of 29 Old 10-25-2008, 01:32 PM
I've heard of diluting baby shampoo and using it for anti fog, but I haven't heard of the shaving cream. Maybe I'll try my mug style shaving soap...
geckohunt is offline
post #29 of 29 Old 10-26-2008, 01:35 AM
bike n00b
Shaving cream is basically whipped soap so you don't need to worry about it corroding your plastics. It also is good on carpets for mild stains... I LOVE daytime television! You learn the most pointless stuff....
alinosa is offline
