Sealing washer? - Wrist Twisters
post #1 of 18 Old 09-09-2006, 08:04 PM Thread Starter
Sealing washer?
Does the 06' 919 have a sealing washer on the oilpan drain plug? The reason I asked is because when I changed my oil(at 400 miles) the drain plug had no sealing washer that I can remember, but I recently got the service manual and it stated to make sure the sealing washer was in good shape or you had to replace it.
mrjason is offline
post #2 of 18 Old 09-09-2006, 08:05 PM Thread Starter
Oh and by the way, I now have 850 miles and the bike is not leaking any oil.
mrjason is offline
post #3 of 18 Old 09-09-2006, 08:54 PM
Yes, there is a sealing washer.
I don't use one though, I have went through several oil changes and 14,000 miles without one and have never had a drop of oil anywhere.
motorwerks919 is offline
post #4 of 18 Old 09-10-2006, 02:46 AM
Ken
Community Admin
Ken's Avatar
Thos darn little crush washers always seem to end up in the bottom of the oil pan. They're cheap enough though so I have some replacements on hand. I got kinda lucky - many of the parts from the ST13 (like oil fiters) are the same for the 9'er.
Ken is offline
post #5 of 18 Old 09-10-2006, 03:19 AM
Looks like what we have here are 2 options:
a) Leave the crush washer out and run the risk of a oil leak or maybe over tighten the drain plug and crack the oil pan threads
b) Use the recommended crush washer and have peace of mind.
post #6 of 18 Old 09-10-2006, 04:13 AM
Mine seemed to end up flattened so tight against the bolt that, unless looking very closely, you cannot tell they are two different parts. And yes, it was torqued, not elbow click checked. You can tell they are two different metals, but the washer doesn't want to separate from the bolt. I thought I had lost mine until noticing this.
post #7 of 18 Old 09-10-2006, 04:49 PM
Mine might very well be the same way. I have never inspected the drain plug too closely, I always thought my washer fell into the pan or was already gone from my bike when I got it. So I might still have one, not sure.
post #8 of 18 Old 09-10-2006, 06:21 PM
Wazoo919's Avatar
I would use a crush ring. Just for not over tighting and doing damage to the oil pan. They are cheap.
05' 919
Wazoo919 is offline
post #9 of 18 Old 09-10-2006, 09:25 PM
DropBear 9
Guest
Posts: n/a
Am I the only one that finds it alarming that folk are saying the crush washer ends up in the bottom of the oil pan????
I think perhaps it might fall down into the belly pan (if one is fitted) but not up into the sump.
Sorry Ken, couldn't resist!
Anyway I'll always use a new washer, though usually it's not a new crush washer but more often than not a new fibre washer a tthe very least.
These seal well and don't require a gorilla grip on the socket wrench to stop the drips!
post #10 of 18 Old 09-11-2006, 02:03 PM
By oil pan, we mean the pan we are draining the old oil into.
post #11 of 18 Old 09-11-2006, 06:41 PM
DropBear 9
Guest
Posts: n/a
Ah.. Geez I can be stoopid sometimes!
In my defence I hadn't had my "morning" coffee yet..
Not much of a defence I know but....
post #12 of 18 Old 09-11-2006, 09:09 PM
Don't worry, we should have called it a drain pan anyway.
So I changed my oil today and looked at my drain plug and there is no washer or anything hopefully it'll be alright.
post #13 of 18 Old 09-11-2006, 10:41 PM
DropBear 9
Guest
Posts: n/a
There is that too I suppose!
Just for sh.ts and giggles, have you checked to see if the old washer is still stuck to the bottom of the motor?
If it were me, I'd be making sure it's not, and then getting a fibre washer for the "plug".
Ideally a new crush washer, but I've always found fibres to do the job well enough. Plus they're generally easier to find and cheap etc.
I'd expect to see a bit of dripping otherwise. just don't go nuts overtightening the plug to to compensate for the lack of washer if you do get any drips.
post #14 of 18 Old 09-12-2006, 04:47 AM
Am I the only one that notices the deformed 12 mm drain plug washer?
Item #15 in the photo is a soft aluminum 12 mm sealing washer that Honda has been using forever.
post #15 of 18 Old 09-12-2006, 05:45 AM
Wazoo919's Avatar
whats the real name? My dealer that I get them from call them crush rings.
05' 919
Wazoo919 is offline
post #16 of 18 Old 09-12-2006, 05:57 AM
No, that's was what my earlier post was about. That is the washer. It is different from the plug. You can also erase all doubt by using a magnet. The plug is metallic, the washer is not.
post #17 of 18 Old 09-12-2006, 10:19 AM
Yes I did look at the bottom of the motor and felt around and there was nothing.
Well I guess I do have one afterall. Thanks I'll sleep easy now:001_smile:.
post #18 of 18 Old 09-12-2006, 09:57 PM
DropBear 9
Guest
Posts: n/a
errmm.. looks that way! with respects to Hondjim for mentioning it in the first place.
Not sure there is a real name other than sealing washer, but any self respecting workshop mech or parts monkey should know what crush washer or crush ring means anyway. But it's a fair question for non mechanics.
Well I guess I do have one afterall. Thanks I'll sleep easy now.
Only after you've removed that useless squashed bit of metal and replaced it with a new one.
