Sato Rearsets 919 install - Wrist Twisters
post #1 of 13 Old 10-05-2006, 10:52 AM
motoxer101
Guest
Posts: n/a
Any advice on m saturday project? I am installing Sato rearsets on the 919...my only concern...brake light switch. Anyone know if this is "plug and play"?
Thanks
post #2 of 13 Old 10-05-2006, 11:07 AM
Plug n' play. You might want to add a drop or two of blue threadlocker [Loctite 242] to the mounting bolts that secure the Sato's to the bike.
post #3 of 13 Old 10-05-2006, 12:06 PM
motoxer101
Guest
Posts: n/a
Cool, red Loctite right? thats what Sato recomended. Did your brake light switch plug right into the stock Honda wiring or did you have to cut and install new connectors? Thanks, R
post #4 of 13 Old 10-05-2006, 01:11 PM
Church of the Holy Smoke
MotoCycho's Avatar
The plug is the same, although I still have not installed mine. Blue or red Loctite.. either will do. The red is rated for higher temps. The Blue is more for screws that come out and get put back often.. it stays on the threads and therefore doesn't need to be reapplied every time. It just creates resistance so it would back out. FYI: use something cuz the bolts will come out. Ask me how I know
- Rev. CYCHO -
MotoCycho is offline
post #5 of 13 Old 10-05-2006, 01:32 PM
The use of red Loctite might reqiuire heat if you need to remove any bolts.
I prefer the blue, never had a piece of hardware loosen up on me.
post #6 of 13 Old 10-05-2006, 07:31 PM
TrackXperience Pusher!
Jayfooey's Avatar
before you run out and buy some loctite, if I remember correctly, my Sato rear sets came with a little tube of blue loctite...
Jayfooey is offline
post #7 of 13 Old 10-05-2006, 11:53 PM
Corner speed sets u free
streakin919's Avatar
Dayum, i love those rear sets... ones of these days.
streakin919 is offline
post #8 of 13 Old 10-08-2006, 09:38 PM
Heavy Metal
ratdog's Avatar
Go Blue !!
and yeah, they are sweet
wasn't sure if i was gonna like them cause the ergos of the 919 are tight enuff as is...happily, they fit just fine
i have yet to pick up the stuff needed to connect the rear brake light switch...hardly use it neway
ratdog is offline
post #9 of 13 Old 10-09-2006, 02:00 PM
motoxer101
Guest
Posts: n/a
Got them on this weekend...as well as the Jardine Fender eliminator...I will log on tonight and post pics. Sato's are incredible!!!
post #10 of 13 Old 10-09-2006, 03:59 PM
Ken
Community Admin
Ken's Avatar
Aside from increased lean angle ability, what is the advantage of adding rear sets?
2009 Honda Goldwing
Ken is offline
post #11 of 13 Old 10-09-2006, 04:26 PM
MotoCycho's Avatar
um... they are bad a$$ed in every way conceivable. Sheesh!
Just look at 'em:
- Rev. CYCHO -
post #12 of 13 Old 10-09-2006, 04:28 PM
Heavy Metal
ratdog's Avatar
look here for some thoughts on the benefits of becoming a Sato-man
ratdog is offline
post #13 of 13 Old 10-09-2006, 06:52 PM
motoxer101
Guest
Posts: n/a
agreed...less vibration, less weight, more precise shifting.....in my opinion, anywhere your body touches the bike is a good place to upgrade....it is your direct connection to the bike. Grips, bars, rearseats, and seats are great places to spend dough on your bike.
