Running Rough?? - Wrist Twisters
post #1 of 3 Old 09-03-2007, 03:03 PM Thread Starter
Veteran Donation
Running Rough??
My 9er takes to running rough.Sometimes to the point it doesn't want to start.First time it happened I had to take it to the factory to get it right.But now I know why(and where) it is.It's a bad ground under the gas tank.I've got 54,000+ and ride in everything I've had to clean it only 3-4 times.This last time I took a pict to share.I also remembered to put a bit of di-grease on it,did the pos and neg on the batt also.
Feel free to reword and move this if needed
tvetree is offline
post #2 of 3 Old 09-03-2007, 03:08 PM
Resident Viper Driver
919jockey's Avatar
I guess the obvious question is have you tried replacing the ground wire yet? (not trying to be a wise ass here)
919jockey is offline
post #3 of 3 Old 09-03-2007, 03:15 PM Thread Starter
Veteran Donation
Haven't replaced anything yet just cleaning the contact points(the rings and frame) does the trick.Hopfully using the grease this time will have it last longer.
tvetree is offline
