Road bumps and throttle fluctuation - Wrist Twisters
post #1 of 11 Old 11-03-2008, 03:26 AM Thread Starter
Still running my new 919 in but wonder if others have this problem. When riding on uneven or choppy roads the suspension bounces the bike a bit resulting in the throttle hand speeding up or slowing down the engine speed as a result of the bouncing around. Coming off a bike with carbs I find the throttle very sensitive to small adjustments from the right wrist. I am a lightweight and part of the problem is getting the suspension settings set soft enough to smooth out some of the road uneveness.
On a different note,comparing the 07 models from USA to here in Australia, my bike is a burnt orange colour with a black engine. This appears different to your colours.
PhilS is offline
post #2 of 11 Old 11-03-2008, 04:08 AM
Same complaint. I've tried easing my grip and that doesn't seem to help. The one thing that made it a little better is the use of a Crampbuster. It's definitely not the smoothest FI bike available.
Post up some pics of your bike. I'd like to see that color combo.
post #3 of 11 Old 11-03-2008, 04:38 AM
Heath's Avatar
Same problem here. I found two fixes to my riding position to help this.
1. Relax your right hand a wrist a bit when on rough rodes.
2. Hand/wrist position. Look at your right wrist, palm down. Bring the wrist up and back toward you. use this type of hand position when riding, it limits the movement to open the throttle and smoothes out your thottle response.
Hope that helps.
Heath is offline
post #4 of 11 Old 11-03-2008, 05:44 AM
I like yellow bikes
Janet the jet's Avatar
I used to only really notice it in town, in the lower gears. I used to find that a partial solution was often to run it one gear higher. The bike's plenty flexible enough to take it, and that smoothed it out quite a lot. But relaxation also helps, as others have said.
Janet the jet
Janet the jet is offline
post #5 of 11 Old 11-03-2008, 06:19 AM
Curmudgeon
semi_gray's Avatar
Great suggestions so far
One more:
I hear ya about the suspension settings. I upgraded to an f4i fork early on and the settings WAY too stiff for the first season. The next spring, I set the "sack" on them and dialed the dampening way back on compression and this helped immensely.
Short of a fork upgrade, perhaps a lighter oil and maybe even lighter springs would help a lot.
semi_gray is offline
post #6 of 11 Old 11-03-2008, 09:55 AM
Have you tried holding it WFO
iyaoyas98 is offline
post #7 of 11 Old 11-03-2008, 09:58 AM
On my '04 919 I did not notice this problem. I had a K&N filter, flapper mod, and PC III, but I'm not sure if any of those changes would have anything to do with the smoothness. I also had a guy at the track help me set up my suspension for my weight.
I have not done any of the mods listed above to my '07 919 yet and I constantly notice the issue you mention on rougher roads at slower speeds - but only at slower speeds.
I will do the K&N and flapper mod this week, and hopefully find time to install the PAIRs plates and the PC III as well. Hopefully that will make a difference.
post #8 of 11 Old 11-03-2008, 11:04 AM
This is a common complaint, primarily from new owners. The first thing I noticed when I started riding my '02 was the sensitivity of the throttle just off closed transitions, but it was not an issue with me -- in fact, it made matching revs for downshifts a breeze: the tiniest amount of throttle does the trick.
One thing I have done for years, other than relaxing my hand, may help you with this -- always rest your right index finger on top of the brake lever. It gives you brain a reference for where your hand / wrist is that is much more accurate than just the wrist alone, and lets you preload your hand to help keep it in one position. The only thing you have to be careful about is to not pull on the lever accidentally, activating the brake light and possibly dragging the brakes. I think as you acclimate to the bike the sensitivity will become less of an issue, and in fact you will probably come to appreciate the most responsive twist grip in the entire motorcycle world!
robtharalson is online now
post #9 of 11 Old 11-03-2008, 11:08 AM
+1 for upshifting.
If you see a bumpy road coming, just go up a gear or two below 2k rpm's and it will be much less responsive.
PilotRPI is offline
post #10 of 11 Old 11-03-2008, 05:15 PM
PHOBMAN's Avatar
I always ride with two fingers on the brake lever, it steadies the hand and you're right there if in trouble!
PHOBMAN is offline
post #11 of 11 Old 11-03-2008, 08:21 PM Thread Starter
Smile
Thanks for all the suggestions. I have got the suspension about where I want it.
Went for a ride this morning and tried relaxing the right arm and wrist and hand, and kept the wrist higher and straighter and it did make a difference.
PhilS is offline
