replacement turn signals for fender eliminator? - Wrist Twisters
post #1 of 18 Old 10-19-2014, 10:57 AM Thread Starter
I was looking at the bike and it appears the PO used a fender eliminator kit, but I don't see the blinkers.. . Nor is there any connectors hanging out of the tail. Who makes (led prefered) good quality/bright turn signals that should bolt on to the license plate? Ideally with stock connectors that I can plug in.
Thanks
Offline is offline
post #2 of 18 Old 10-19-2014, 11:06 AM
Customled
post #3 of 18 Old 10-19-2014, 11:53 AM
Does it have the integrated tail light/turn signals?
garyb900 is offline
post #4 of 18 Old 10-19-2014, 12:10 PM Thread Starter
ugh.. looks like the PO already installed customLED .. time to call the company i guess as they are not blinking (and to check connectors later today)
Offline is offline
post #5 of 18 Old 10-19-2014, 12:14 PM
rpcraft's Avatar
I figured as much. Turn your blinkers on and see if it is working. If not you might need to install ballasts or replace the oem flasher module with one that is for LED blinkers. You can get one from Autozone for about 15 bucks but it's generic and might require some new connectors.
Rob C
2002 DL1000 V-Strom
rpcraft is offline
post #6 of 18 Old 10-19-2014, 12:18 PM Thread Starter
they don't blink.. well they maybe are kind of flickering a little bit...
so where is the relay located? under the seat I hope?
Offline is offline
post #7 of 18 Old 10-19-2014, 12:38 PM
rpcraft's Avatar
I couldn't say. I am sure it is probably back by the brain under the seat. When I did mine I did the ballasts. I have regrets about that. If I had know how easy the LED flasher mod was in comparison (and how much cleaner it can be I would have done it ages ago. I sold my 919 otherwise I'd have figured it out, but alas, selling my 919 brings about other regrets, lol. I'm sure one of the other fellas will pipe up and say where it pretty soon.
Rob C
2002 DL1000 V-Strom
rpcraft is offline
post #8 of 18 Old 10-19-2014, 12:39 PM
rpcraft's Avatar
Found a youtube video..
Rob C
2002 DL1000 V-Strom
rpcraft is offline
post #9 of 18 Old 10-19-2014, 12:40 PM
rpcraft's Avatar
It has some details of a plug in module if you look in the video description.
Rob C
2002 DL1000 V-Strom
rpcraft is offline
post #10 of 18 Old 10-19-2014, 03:35 PM
Yeah... That's not a CUSTOMled unit. It's the cheap shitty ClearAlt. unit. Toss it and buy the CUSTOMled unit. You can also do some led turn signals such as rizomas.
Pvster is online now
post #11 of 18 Old 10-19-2014, 08:02 PM Thread Starter
good to know.. I'll cancel my 'cancel the order' email then and go with the customLED
Offline is offline
post #12 of 18 Old 10-19-2014, 09:03 PM
Will fly for food.
filipinoaviator's Avatar
Here's my super cheap solution-
https://www.wristtwisters.com/forums/...tml#post685121
1965 PA-30 Twin Comanche
1985 Kawasaki GPZ900r
1999 Honda CBR1100XX
2005 Honda ST1300
2006 KLX250s
filipinoaviator is offline
post #13 of 18 Old 10-20-2014, 06:12 AM
If the light was installed correctly it should still work fine with the LED tail light, it'll just flash very rapidly becuase of the decreased load on the circuit. I would say the problem here is a bad wiring job by the PO.
post #14 of 18 Old 10-20-2014, 06:41 AM
I would just recheck all the wiring ..... you can pull the board off and bench test it with any 12v battery and a set of leads.
If only the signal light circuit is faulty I would keep the board as for your tali/running light and then installa set of small aftermarket turn signal lights.
post #15 of 18 Old 10-20-2014, 02:26 PM Thread Starter
since I can't confirm who made the board.. I'm just ordering a new customLED.. I would rather it be as bright as possible and have the assistance of support if needed.
ordered their relay as well so maybe thats the only problem.. ill know here in a week when the parts get in
Offline is offline
post #16 of 18 Old 10-20-2014, 03:43 PM
Good choice! You won't be disappointed!
post #17 of 18 Old 10-20-2014, 07:38 PM
+1000 to that. There's a point where you can't fix crap, and those old brand boards were crap.
CustomLED all the way!
post #18 of 18 Old 10-28-2014, 03:23 PM Thread Starter
CustomLED arrived.. and installed.. fkn sweet.. everything works now. yay!
https://imgflip.com/gif/dkmfo
Offline is offline
