removing stock horn - Wrist Twisters
post #1 of 8 Old 11-19-2014, 07:16 PM Thread Starter
ewmin3m's Avatar
First mod - remove and upgrade horn
Now I was really excited about installing my first custom thing but it turns out I can't even remove the bloody horn.
How do I go about opening the two clamps that are connected to the horn?
I hope I can open them without having to replace anything.
I purchased the PIAA horns because supposedly they are "plug and play", yet I cant remove the stock horn...
I guess I have to start somewhere
Thanks in advance!
ewmin3m is offline
post #2 of 8 Old 11-20-2014, 07:06 AM
Open them? They don't open, just pull straight off.
post #3 of 8 Old 11-20-2014, 07:19 AM
Thanks in advance!
The wire terminals are spade connectors .... they push onto two small flat pins on the back of the horn .... just give them a pull and they should slide right off.
There is also alwasy a chance a previous owner has messed with the wiring or added another style connection .... if you have any other issues just take a pic and we can walk you through it.
post #4 of 8 Old 11-20-2014, 09:15 AM Thread Starter
ewmin3m's Avatar
Sweet thanks a lot Ian.
I didn't want to pull on it excessively because I was afraid that something would break. But i'll apply a bit more force, maybe it's just a bit stuck.
Thanks,
CJ
ewmin3m is offline
post #5 of 8 Old 11-20-2014, 10:29 AM
No worries man. Good luck with it.
post #6 of 8 Old 11-20-2014, 10:55 AM Thread Starter
ewmin3m's Avatar
Indeed, it took a bit of force to unplug the 2 wires from the stock. I would assume its all the grime and such but I was successful. The PIAA horns are loud as hell...
Yay my first successful mod !!
ewmin3m is offline
post #7 of 8 Old 11-20-2014, 11:04 AM
crimedog's Avatar
Pretty soon you'll be saying "oh God I hope this is the last mod that I make!"
08 DR-Z400SM
WFOATT
crimedog is offline
post #8 of 8 Old 11-20-2014, 11:11 AM Thread Starter
ewmin3m's Avatar
If only I had my own garage I would go crazy but I don't . So I'll keep it simple and easy for now. Mostly cosmetic.
ewmin3m is offline
