Removing Battery - Wrist Twisters
post #1 of 6 Old 11-20-2006, 04:34 PM Thread Starter
Removing Battery
Do you guys just slide the battery out then disconnect the wires? Is there enough wire to pull the battery out. On my it seems very tight in the box and I didn't want to pull on it. I'm not sure how else to get to the post to remove the cables.
abadley is offline
post #2 of 6 Old 11-20-2006, 04:40 PM
BockHawk's Avatar
I had to detach the cables to get it out. Even if there is enough slack, you're probably putting a nasty strain on the cables. I wish they had added a 1/2" of cable on both cables.
2002 919 40,000 miles
BockHawk is offline
post #3 of 6 Old 11-20-2006, 04:41 PM Thread Starter
Unless I'm completely blind. I don't see the terminals to disconnect the cables before you can pull the battery out.
abadley is offline
post #4 of 6 Old 11-20-2006, 04:51 PM
BockHawk's Avatar
You'll do it at the battery itself, both terminals should be towards the outside of the bike. I think I misunderstood your original post. I detached the cables from the battery, but I did so with the battery still partially in the tray. Does that make sense?
BockHawk is offline
post #5 of 6 Old 11-20-2006, 07:15 PM
Undue the negative, pull battery out, undue positive. Easier with the seat off but can be done with it on. Hookup is the reverse.
Bryce919er is offline
post #6 of 6 Old 11-25-2006, 01:18 AM
then get a 4 gauge connectey and add 2 inches and a quick disconnect.
2 or 4 guage push and turn quick disconnect available from your local car stereo shop.
scosche or pyramid makes them.
typhoonblue919 is offline
