Reduce 919 Handlebar Vibes - Wrist Twisters
post #1 of 13 Old 08-27-2014, 10:34 AM Thread Starter
What's the best upgrade to reduce vibration on the 919 handlebars? Renthal Bars or the 17/44 gears? Everything is still stock on my 919 and I'm getting tired of the numb hands! Eventually I would like to do both.
abadley is offline
post #2 of 13 Old 08-27-2014, 10:41 AM
HornetMan's Avatar
Renthal bars first with a set of bar end weights. Far cheaper and it might just be all you need to do. Wait until it's chain replacement time before doing that. I did both (Renthal plus 17/44) as well as Vibranator inserts. Every little bit helps.
"Keep on 9-in"
HornetMan is offline
post #3 of 13 Old 08-27-2014, 11:50 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
NOJ Foam Grip wraps and a set of heavy weight bar ends(throttlemeister in my case).
NOJ Neoprene Grip Wraps 210
Throttlemeister - Home
ST-DocLizard1 is offline
post #4 of 13 Old 08-30-2014, 06:30 AM
redline919's Avatar
Vibranators
redline919 is offline
post #5 of 13 Old 08-30-2014, 07:25 AM
Renthals. I tried gel grips and vibranators. Did not compair to how well the renthals worked. I should have bought them years ago. Renthal road mediums feel like stock position
post #6 of 13 Old 08-30-2014, 07:28 AM
redline919's Avatar
I still get vibes with renthals. The combo of them and Vibranators are your best bet
post #7 of 13 Old 08-30-2014, 09:25 AM
Stutz's Avatar
Stutz is offline
post #8 of 13 Old 08-30-2014, 11:32 AM
The Instigator
Ditch's Avatar
You can start by taking out the bar weights. They just make it worse.
Ditch is offline
post #9 of 13 Old 08-30-2014, 12:52 PM
Originally Posted by Stutz View Post
tbs.
Didn't think this was possible on the 919........
PAULIBIKER is offline
post #10 of 13 Old 08-30-2014, 06:24 PM
Stutz's Avatar
Thought you could?
Stutz is offline
post #11 of 13 Old 08-31-2014, 07:55 PM
Clean the crap out of your chain, and use a dry lube.
jnich77 is offline
post #12 of 13 Old 09-09-2014, 08:57 AM
8Biker6's Avatar
Weird, I never had a problem with the 919 handlebars, but mine had bar ends when i got it. Also wear gloves if you don't. The 919 was find better vibe wise than the bandit 600 i came from.
8Biker6 is offline
post #13 of 13 Old 09-09-2014, 09:03 AM
Thought you could?
You can sync the enrichers but not the throttle bodies, I believe. Which will do nothing for vibes.
Now sync'ing the throttle bodies does make a difference. In fact, it was night and day difference on my SV1000.
