Rebound damping - Wrist Twisters
post #1 of 8 Old 10-24-2014, 02:18 PM Thread Starter
Rebound damping
I am aware of what rebound damping is. I am just curious as to how the adjuster physically works on a stock rear shock. Is the piston stem hollow? If so, it's position on the bottom of the shock would require it to be double bored, a fluid passage in and back out for return. Seems a lot of work for a bottom mounted adjustment that could have gone somewhere else on the shock. Just curious.
cooper714 is offline
post #2 of 8 Old 10-24-2014, 04:36 PM
Total Awards: 17
bottom of the shock is the easiest way to place the adjuster. Thing of your front fork but mounted upside down. (Not to be confused with USD forks, which have its cartridge mounted the same way as conventional forks, the same side up)
Obviously shock stem is hollow with the rebound needle inside which restricts/ de-restricts bypass port of the valve. Stock adjuster simply pushes the needle up and down with adjuster's conical shape. Unlike Ohlins shock that actually has precise clicker adjuster. Both doing the same thing - closing or opening the bypass port.
zaq123 is offline
post #3 of 8 Old 10-24-2014, 06:03 PM Thread Starter
Many thanks, I was able to put that much together. It just makes little design sense. The stem couldn't just be hollow as rebound damping in the rear shock would require shock oil to be pushed past the adjuster without restriction (that would be compression damping) and return the oil under restriction at the return stroke. Seems that would require reservoir space or two channels in the shock stem. There would be little left of the shock stem, given it's outside diameter, with two bore holes down it's inside, and why? The reservoir is on top, why not control it there. It is a curiosity. If I could remove the screw, all the shock oil would be expelled in a pressurized rush? Unloaded the adjuster doesn't seem to have enough tension to be under pressure.
post #4 of 8 Old 10-24-2014, 06:25 PM
Total Awards: 17
you got it all wrong. Stock adjuster is simply pushes the needle up or down the stem with its conical shape. Compression circuit has nothing to do with rebound. It's valve is located near reservoir, hence its on top of the shock. This pic should help.
zaq123 is offline
post #5 of 8 Old 10-24-2014, 06:50 PM Thread Starter
Bottle?
Yep, I am missing the obvious.
Pic is a no show.
Thanks for taking the time to make this clear to me.
post #6 of 8 Old 10-24-2014, 06:51 PM
Total Awards: 17
Bottle? Yep, I am missing the obvious. Pic is a no show. Thanks for taking the time to make this clear to me.
lol. I meant needle. Attachment 85106
zaq123 is offline
post #7 of 8 Old 10-24-2014, 06:55 PM Thread Starter
Perfectly clear now. I was picturing fluid movement, the movable rod idea did not occur to me. Very helpful.
post #8 of 8 Old 10-25-2014, 05:26 AM
Total Awards: 17
that's not exactly your 919 shock though. 919 shock is a little less complex and somewhat primitive. For example: remote reservoir is pretty much useless on OEM unit. It has a reverse bladder design which is still a mystery.
zaq123 is offline
