Rear spring color - Wrist Twisters
post #1 of 11 Old 02-23-2010, 11:10 AM Thread Starter
BlackRig's Avatar
Rear spring color
Any way to change the color of the stock rear spring?
It's the only thing on my bike that's red and I just wanted to look at some options.
I'm thinking plasti did (the stuff made for the handles of tools) or maybe a tough but flexible rubber coating of some kind. The plasti dip would probably be expensive cause I would need a gallon or two to totally dip the spring. Plus, I would have to tear off all the old rubber coating.
Any ideas?
BlackRig is offline
post #2 of 11 Old 02-23-2010, 11:17 AM
Ballaholic
hornet919's Avatar
i vote food coloring
hornet919 is offline
post #3 of 11 Old 02-23-2010, 11:22 AM
check out mdtoneys project, he did his rear spring
https://wristtwisters.com/naked-bikes...ns-slowly.html
post #4 of 11 Old 02-23-2010, 11:51 AM
not cro-magnon
Relic11's Avatar
Spray bomb?
Relic11 is offline
post #5 of 11 Old 02-23-2010, 12:08 PM
powdercoat would be the most durable method
Superduke
R1200GS
XR650L
post #6 of 11 Old 02-23-2010, 12:34 PM Thread Starter
BlackRig's Avatar
Do you think powder coat would allow for the flex of the spring and still not flake off?
BlackRig is offline
post #7 of 11 Old 02-23-2010, 12:36 PM Thread Starter
BlackRig's Avatar
Originally Posted by Relic11 View Post
Spray bomb?
That thought crossed my mind. Especially with rhino liner.
BlackRig is offline
post #8 of 11 Old 02-23-2010, 12:41 PM
Yes, they powdercoat springs all the time. Here's who I use locally...
Indy Powder Coating
Superduke
R1200GS
XR650L
post #9 of 11 Old 02-23-2010, 02:28 PM
I had mine anodized because mine was a project bike from the beginning and I wanted the spring to match the body color as close as possible. In most light it's a perfect match but in direct sunlight it's noticably off.
I don't know the real price difference between anodizing and powdercoating since a friend did all the stuff on my bike. But it cost more to have the spring removed (and installed again) than it cost for the color.
Powdercoat is pretty durable stuff, I can't imagine you'd have any problem with it.
Post pics when you get it done!
post #10 of 11 Old 02-23-2010, 03:14 PM
Total Awards: 17
might as well change your spring, if you have the spring off and you are under 195lbs or over 215lbs. For another $100 change your front springs(unless you are under 100lbs) and you will be pleasantly surprised.
zaq123 is offline
post #11 of 11 Old 02-23-2010, 03:46 PM
Fat guy on a little bike!
Byrdman's Avatar
Just spray paint it.
I spray painted the hideous purple spring on my Wilbers 15-20,000 miles ago and it still looks good.
Jeff
Byrdman is offline
