Rear Shocks??? - Wrist Twisters
post #1 of 8 Old 04-12-2009, 09:36 AM Thread Starter
Rear Shocks???
If I go for it, I'll probably go for a Penske (I have had really good luck with them for price versus performance). However, I'm wondering whether or not people have figured out a direct swap from another bike that is proven to work (I have heard the F3, but also heard it doesn't make a "huge" difference). What about rears from other makes? When I got my Penske for my 10, somebody wanted my stock shock for their SV650 (apparently it works really well for that swap).
Thoughts???
sike is offline
post #2 of 8 Old 04-12-2009, 09:54 AM
How many 919 rear shock threads do we need???
post #3 of 8 Old 04-12-2009, 10:04 AM Thread Starter
The problem I have is that that thread really doesn't "go" anywhere. It appears there is one person happy with the F3 swap, one that says it screws up the geometry. There aren't any other swaps mentioned. It does mention the Ohlins option. So, it still leaves me wondering. However, you are probably right in the end......
sike is offline
post #4 of 8 Old 04-12-2009, 10:21 AM
Originally Posted by Lordduckhunter
I tried the F3 Shock on my own 919 back in the day and found the extra length to be an annoying change to the geometry of the bike and the ride compliance didn't really improve either I also had a 65 series tire installed around that time too so that also would have affected the results to some degree. Stock shocks are just crap period and I'm pretty sure the one off the F3 is designed around a rising rate linkage which really throws off the spring rate when used on a bike that doesn't have one like the 919.
LDH will tell it like it is with no BS.
post #5 of 8 Old 04-12-2009, 10:28 AM Thread Starter
Yes and No. I believe that he is right from his perspective. However, what I have found from my friends who are fast racers and/or champions, their perspective is skewed. That is, they are asking things from a bike that most people never will. So, they frequently don't really know how a bike will perform below that level. This isn't in any way meant as a disrespect, but an observation.
sike is offline
post #6 of 8 Old 04-12-2009, 12:27 PM
3dcycle's Avatar
could we get a suspention offical thread, keep all this good info in one place? kinda like the exhaust stink offical thread. i think that would help out, maybe even a sticky, that way there is only 1
3dcycle is offline
post #7 of 8 Old 04-12-2009, 12:27 PM
3dcycle's Avatar
oh and as far as other shocks that fit, i dunno
3dcycle is offline
post #8 of 8 Old 04-12-2009, 06:14 PM
tpoppa's Avatar
I agree with part of this statement:
The 65 series rear would definitly have some impact on the geometry. The F3 shock is 5 mm longer than the stock 919 shock, I really don't see that 5mm significantly changing the geometry with a 180/55/17 tire. Many people lower the forks by 10mm...if you used an F3 shock you would just need to change the forks to 5mm lower than stock...the geometry would be the same except that the ride height would be 5mm higher.
The part about the rising rate linkage is what concerns me. The F3 shock just wasn't designed for the 919. The F3's adjustability may make it acceptable for certain weights of riders. I have access to a F3 shock, I may throw it on to see how it feels. I know that SV650 riders have good results with ZX10 & ZX636 shocks.
A Penske or Ohlins that was designed for the 919 will obviously give the best results, it just depends how much you are willing to spend.
tpoppa is offline
