Rear pre-load? - Wrist Twisters
post #1 of 9 Old 12-12-2006, 10:43 AM
Richr8
Guest
Posts: n/a
Rear pre-load?
How do you guy's adjust the rear pre-load? Special tool, or just bump it around with whatever?
I do not have a service maual yet, sorry ofr the d question. I know I had special spanners for my other bikes.
post #2 of 9 Old 12-12-2006, 10:50 AM
Tired of Tirone
jeffspeak's Avatar
Hey,
Check under your seat.
I have a special spanner included in the factory "tool" kit.
jeffspeak is offline
post #3 of 9 Old 12-12-2006, 11:51 AM
Unbannable
Super Sneaky Steve's Avatar
I had one allen wrench in my tool kit. That is all. I'd like to know the answer to this question as well. I'm tempted to get a big screw driver and a mallet, but it may be better to just get the tool. What do you guys think?
Super Sneaky Steve is offline
post #4 of 9 Old 12-12-2006, 12:08 PM
Even with the factory tool it can be an effort in frustration. A cheater on the factory tool usually helps since the handle is so short, but it's hard to get it to budge even then. A well placed and carefully smacked screwdriver seems to start rotation better, and the tool can finish the job after that. But if you don't have the tool I don't think I would purchase it. I've have before, and would do again, the whole job with a screwdriver. (at your own risk)
post #5 of 9 Old 12-12-2006, 02:19 PM
I did it on my 919 with the tool & remembering it going easy--I had one side cover off. I can't remember if I did this on the 919 but I usually use one hand for the tool then twist as hard as I can on the spring with my other hand & it goes fine.
Bryce919er is offline
post #6 of 9 Old 12-12-2006, 02:54 PM
Nick's Avatar
Motionpro makes a spanner wrench that will work.
For stuborn ones I ground down the end of a cheap flathead screwdriver to make it blunt. Works pretty good.
Nick is offline
post #7 of 9 Old 12-12-2006, 03:17 PM
Curmudgeon
semi_gray's Avatar
A little light oil on the "ramps" helps too.
semi_gray is offline
post #8 of 9 Old 12-12-2006, 06:58 PM
Veteran Extraordinary Ride
Bought a spanner at the local honda shop for 6$, was hard to turn but it worked fine.
ad919 is offline
post #9 of 9 Old 12-13-2006, 07:13 PM
Richr8
Guest
Posts: n/a
Thaks gang. Think I'll give the $6 spanner a try first. The shop is on the way home.
