rattle when under load - Wrist Twisters
post #1 of 36 Old 08-24-2008, 05:14 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
hello all
my bike is making noises/rattles when under load, okay at a fixed speed.
never did this before only started straight after having heads port & polished , flapper mod , pc111.
does not affect performance at all.
any thoughts would be appreciated.
thanx glenn
GLENN is offline
post #2 of 36 Old 08-24-2008, 05:20 PM
Isn't That Somethin'
need more info like where does it sound like it's coming from? what does it sound like tinny or more dull? can you feel it?
UT VIVANT ALII...SO OTHERS MAY LIVE
jd31goalie is offline
post #3 of 36 Old 08-24-2008, 07:27 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
just went for a spin & rode it to mates work shop, he also took it for a spin to help in description & we found a bolt missing from bottom of radiator near water hose .
problem fixed bike rock solid again.
blip.... machanics.
GLENN is offline
post #4 of 36 Old 08-25-2008, 05:51 AM
there you go, nice job!
post #5 of 36 Old 08-25-2008, 06:19 AM
ajcombs's Avatar
Helping a Member in Need
Originally Posted by GLENN View Post
hello all
thanx glenn
So can't believe no one else on this horNUT place hasn't asked!!
How did the port and polish work out? Are you impressed with the results or can you even tell it was done??
Glad you got the bike noise resolved!
ajcombs is offline
post #6 of 36 Old 08-25-2008, 07:00 AM
Yea, when I read his first post I instantly forgot about the rattle and thought to myself "I wonder how much different it feels with a ported head"?
MMMMM, Power Good!
Ripper is offline
post #7 of 36 Old 08-25-2008, 07:39 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
7 hp hard to tell , but he said he could dial the cams in more for more top end but i will start to lose bottom end , he also said he could try & make a custom map for more hp with the pc111 .
u need nos for a bigger kicks.
also rattle is back
GLENN is offline
post #8 of 36 Old 08-25-2008, 08:22 PM
91_4x4runner's Avatar
Pinging perhaps?
91_4x4runner is offline
post #9 of 36 Old 08-26-2008, 10:25 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
put octane booster in tank , went for a spin & yes the bike was noise free.
machanic told me at the start i will have to run premium he was right.
GLENN is offline
post #10 of 36 Old 08-27-2008, 05:57 AM
I Love Parallel Twins
Naked/SS's Avatar
I don't understand how the port job or flapper mod could cause detonation. Most likely the PC is causing lean conditions? You didn't mill the head so essentially it's the same compression ratio. Either a bad tank of regular gas or the wrong fuel mapping.
As a side note, I've tried all three grades and it seems (seat of pants feel) to run strongest and oddly enough, better gas mileage with regular 87 octane. Wild! I pretty much always get my fuel at a Sunoco station off of I-95 that sells a lot of gas figuring that with the high turn over they will be always have the freshest gasoline.
I have never used Octane Boost before, sometimes I'll pour in a little Stabil if the gas will be in something that sits around for a bit. But this isn't the case for the 919.
JDubya
Harleyville, South Carolina
USA
Naked/SS is offline
post #11 of 36 Old 08-27-2008, 09:31 AM
faster4344's Avatar
dissapointing to hear theat it only gave 7 hp. lol guess well have to wait for the cb1000r
faster4344 is offline
post #12 of 36 Old 08-27-2008, 03:36 PM
Franklin McGillacutty
riquefied919's Avatar
Did the machine shop cut some off the heads?????
riquefied919 is offline
post #13 of 36 Old 08-27-2008, 03:39 PM
How many ponies does the CB1000R have in its Gullet? I'm really not tryin to jack this thread.
post #14 of 36 Old 08-28-2008, 12:38 PM
Tirone??
Gotsteam's Avatar
Hey, Back onto subject of this thread. I have recently had the same rattle when under load. I have been busy with school and work to diagnose it, but after reading about your missing bolt, I went and checked mine. Sure enough. The bolt holding the radiator on the left side, behind the radiator hose is gone. Will sure be nice to be rattle free again! (maybe another lock tight item to add to the list with the bar ends...)
2006 Honda 919
States visited on my 919
Gotsteam is offline
post #15 of 36 Old 08-28-2008, 12:43 PM
bucky's Avatar
NEED CLOSURE ! was head shaved? thinner head gasket? any other changes to require more octane? DYNO CHARTS before and after ?!?
how agressive was the porting, and do you have before and after pix?
naked, the lowest usable octane is what makes the most power and the most efficient combustion. higher octane burns slower.
bucky is offline
post #16 of 36 Old 08-28-2008, 03:59 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
head was shaved ,flowed on the inlets & fully ported on exhaust , valve timing was changed.
went for a 400km ride to the mountains & bike was good, i filled up 98 octane fuel at a 1 horse town & bike started to ping.
so as a rule i will always fill my bike up at a popular service station with higher turn over of fuel. no pics sorry
GLENN is offline
post #17 of 36 Old 08-29-2008, 10:55 AM
bucky's Avatar
torco accelerator is a well respected octane booster. if you don't mind red spark plugs. (it's chemicals stain the porcelain and electrodes)
bucky is offline
post #18 of 36 Old 08-29-2008, 10:57 AM
bucky's Avatar
how was valve timing changed? presumably slotted sprox? cuz it WAS changed by shaving the head too, so i'm wondering if you just reduced/eliminated that cam retardation inherent in shaving the head, or if you did something more bold?
bucky is offline
post #19 of 36 Old 08-30-2008, 11:57 AM
Go'n So slow I'm stopped
xrmikey's Avatar
Sorry, but there is no bolt on the lower left side.
The radiator has only Two mounting bolts one on top & one on the right side.
The left has just a bushing slipped onto a bung.
If you install one on the left, the bolt will rub on the hose itself.
One place a buzz or rattle doe's occur, is from the frame mounted "tie bar" style frame sliders.
Re torque the hardware. The Delron slider will collapse a little & loosen the assembly.
xrmikey is offline
post #20 of 36 Old 08-31-2008, 03:21 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
not sure how he changed timing will ask next time i see him.
GLENN is offline
post #21 of 36 Old 08-31-2008, 03:25 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
thanx mikey i will remove the bolt , i new it was tight i used a dome head bolt for that reason.
GLENN is offline
post #22 of 36 Old 09-01-2008, 09:10 AM
Tirone??
Gotsteam's Avatar
Yes, you are correct. I checked the OEM catalog before installing this bolt to find that there isn't one there. I guess I will have to make sure that the other two bolts are torqued to specs, and hope this resolves this rattle.
Thanks Mikey
2006 Honda 919
Gotsteam is offline
post #23 of 36 Old 12-07-2008, 10:32 AM
soo.... we never really found out... was it worth it getting the heads ported and polished?? did the rattle ever stop?? hows it run now??
post #24 of 36 Old 12-07-2008, 02:11 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
rattle was pinging so i had to use higher octane fuel because i upped the compression.
i got 7hp from head work , bike had 103hp now 110hp hard to tell maybe u get used of it pretty quick, i was looking for about 15hp but didnt want to loose any bottom end.
GLENN is offline
post #25 of 36 Old 12-07-2008, 02:24 PM
so in your opinion was it money well spent??
post #26 of 36 Old 12-07-2008, 08:41 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
no not enough kick.
GLENN is offline
post #27 of 36 Old 12-07-2008, 08:52 PM
This might be a dumb question...but isn't it easier to 'feel' an increase in torque as opposed to HP? I'm sure more of all the above would be great, but (and this is a big, open-ended but) if given a choice, would you try to boost top-end HP or low-end torque?
Everyone feel free to chime in.
post #28 of 36 Old 12-07-2008, 08:55 PM
IMHO i feel the 9er has enough low end... it is starved on the top... i think i would be happy if i could get mine putting about 125 to the ground..
post #29 of 36 Old 12-07-2008, 08:57 PM
hey glenn... do you have a different exhaust on yours... cause it lists the port and polish etc... and it looks like aftermarket cans in the picture.. i was just curious exactly what setup you had..
post #30 of 36 Old 12-07-2008, 08:59 PM
As for all this rattling that started the thread...
I had an issue with my bike rattling around certain revs. I found that 2 of my 4 rubber washers/bushing (whatever they are) were missing from my windscreen. Bought some new ones from Lowe's and the problem magically went away.
post #31 of 36 Old 12-08-2008, 01:51 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
remus revolution.
GLENN is offline
post #32 of 36 Old 12-08-2008, 01:58 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
http://919turbo.com/ this sounds the way to go if i didnt stack my bike i would be doing this.
GLENN is offline
post #33 of 36 Old 12-08-2008, 07:44 PM
nallac's Avatar
That turbo kit would add a heap of fun to the Hornet.
Woohoo 140 hp at wheel on stage 1...
nallac is offline
post #34 of 36 Old 12-08-2008, 08:22 PM
i'm thinkin.. i'm thinkin... gotta find a way to talk mary into letting me spend 2200 bucks on a turbo...
any suggestions??
post #35 of 36 Old 12-09-2008, 02:10 PM Thread Starter
NAKED & IN LUV
GLENN's Avatar
any suggestions??
tell mary things r tight at work and u had to take a pay cut?
GLENN is offline
post #36 of 36 Old 12-09-2008, 02:51 PM
i left the dealership a month ago and now i am self employeed..(which might explain the amount of time spent here) she gets all my money...
need a plan B now
