Racetech spring spacer length pre vs post '04 - Wrist Twisters
post #1 of 15 Old 11-22-2010, 09:49 AM Thread Starter
Blue919Guy's Avatar
Hi Guys, I got a smoking deal on a set of '07 forks that I am going to transfer onto my '02 919... But I have Racetech 1kg springs in my '02's forks. I know that they are the same springs used for the later forks, but that the spacers are cut down further. My instructions do not give me the length of the spacers for the later forks- can someone help me out?
Blue919Guy is offline
post #2 of 15 Old 11-22-2010, 11:39 AM
I don't remember a spacer in my forks, maybe thats what that preload adjuster is for eh?
post #3 of 15 Old 11-22-2010, 11:47 AM
I think we have a winner.
There are threads floating around here that discuss using different length cuts of PVC as spacers in the pre-2004 forks as a form of preload adjustment.
post #4 of 15 Old 11-22-2010, 12:00 PM Thread Starter
Blue919Guy's Avatar
https://www.wristtwisters.com/f94/919...sted-4894.html
The first picture in this thread shows what I am talking about; I need the spacer length for max preload with the Racetech springs... Lost my instruction booklet
post #5 of 15 Old 11-22-2010, 02:08 PM
Total Awards: 17
very simple.
07 OEM spring + 07 OEM spacer = your 1kg spring + X mm new spacer.
X mm new spacer = (07 OEM spring + 07 OEM spacer) - your 1kg spring
you do the Math
zaq123 is offline
post #6 of 15 Old 11-22-2010, 02:10 PM
Total Awards: 17
Also don't use PVC if you can, use RT supplied nice aluminum spacers
zaq123 is offline
post #7 of 15 Old 11-22-2010, 03:23 PM
My build notes are as follows based on the instructions :
124 mm
-49 mm
+15 mm preload
= total spacer length of 90 mm, which is what is inside my 05 forks and the chassis guy said I did perfectly.
post #8 of 15 Old 11-22-2010, 07:54 PM Thread Starter
Blue919Guy's Avatar
Thanks Mcromo, exactly what I was looking for. Did you apply the max recomended preload?
post #9 of 15 Old 11-22-2010, 08:09 PM
15 mm is recommended and that's what I used.
post #10 of 15 Old 11-22-2010, 08:55 PM
if you have both sets of forks... and your obviously taking them apart... you should have both sets of respective preload spares, or am i missing something here.
post #11 of 15 Old 11-22-2010, 09:08 PM
Church of the Holy Smoke
MotoCycho's Avatar
Yes. With the Race Tech kit you need to cut new spacers. The same RaceTeck kit is used for both generation forks.. the only difference being the length you cut the spacers.
I am pretty sure I simply matched the complete length of the unloaded OEM spring, all washers and the OEM spacer.. then swapped over and measured the RT spring and washers and cut a spacer to make it the same length. This would allow about the same initial force against the pre-load adjuster when you go to screw the whole thing back together.
Good luck!
- Rev. CYCHO -
MotoCycho is offline
post #12 of 15 Old 11-22-2010, 09:12 PM
Good luck!
AH ok so the spring kit comes with its own "specific to the spring" spacer. Gotcha.
post #13 of 15 Old 11-22-2010, 10:07 PM
No. If you are talking Race Tech springs in a 919, the springs are the same length regardless of rate but the spacers are the same length. It's a linear measure of 15 mm of spring preload that one is after. The spacer length change is a function of the new or old style front end, actually, a function of the difference in the length of the fork cap. 04s and newer use shorter spacers.
post #14 of 15 Old 11-23-2010, 12:40 AM
yes, what im saying is that the RT springs came with their own spacers... you didnt reuse the ones that are originally in the forks.
post #15 of 15 Old 11-23-2010, 07:44 AM
Yes, you are very correct that springs with different free lengths will need different spacer lengths.
