quick fork spring Q - Wrist Twisters
post #1 of 5 Old 01-27-2010, 02:09 PM Thread Starter
Ballaholic
hornet919's Avatar
quick fork spring Q
yes iv searched and searched, anyone know the stock fork spring rates in an 07?
hornet919 is offline
post #2 of 5 Old 01-27-2010, 02:38 PM
they are variable or dual rate and soft.
I seem to recollect the intial being in the low to mid 0.70s and the high a touch over 0.80s.
Perhaps a range of 0.75 to 0.825, as in kg/mm
Again, they are soft, well, more like mush, and if the forks didn't have so much stiction on them they'd be even "divier" than they are on the brakes.
post #3 of 5 Old 01-27-2010, 03:07 PM Thread Starter
Ballaholic
hornet919's Avatar
im going to get the linear springs, just not sure which rate to get. racetech reccomends .85 and i was just curious as to what the stock rates were. thanks
post #4 of 5 Old 01-27-2010, 04:41 PM
Mr. Mike is running 0.85s in his, along with a late model stock shock and spring, and he is very happy with that setup. I'd be listening to that. Apparently the stock rear is around 930 # /inch. I'm running 0.925 fronts with an 1100 # rear and feel that I have good balance. Which tells me that 0.85s in the front with a late model rear spring sounds right.
So you have one "using it and likes it" and at least one "sounds right" in terms of guidance.
post #5 of 5 Old 01-27-2010, 04:44 PM Thread Starter
Ballaholic
hornet919's Avatar
lol thanks. i just ordered an ohlins, and im not sure im ready to get the race tech valves yet (read: $$$$), but i want to at least get the front sprung right to go with the ohlins
