question about gearing - Wrist Twisters
post #1 of 10 Old 09-29-2008, 08:50 PM Thread Starter
ok i know most of you guys are really smart so here is my question.. i have been curious why i havent shown a increase in milage since installing a 17t front sprocket.. with the larger front sprocket i would in fact travel further than the odometer read when i had the 16 tooth front.. right?? if so what would be the percentage assuming the odometer was correct with the 16.. now i have a 17 i still show about 130 miles when the gas light comes on but did i drive further than 130??
post #2 of 10 Old 09-29-2008, 09:55 PM
The gearing change from 16 to 17 is different by about 6.2%
All assuming the ODO is correct at 16/43, 130 miles on the ODO at 17/43 is actually 138 miles.
If you drive with stock gearing from a starting point until the odo turns 130 miles, stop on the side of the road & change to 17/43, reset the trip, turn around & go back to where you started from, the odo would read 121.9 miles.
Bryce919er is offline
post #3 of 10 Old 09-29-2008, 11:33 PM
why are you wasting your time with the 17t sprocket? It's all about the 15t sprocket. I was riding with a friend on his 919 16/43t setup and me with a 15/45t setup and we both filed up at the same time and after about 150 miles of out trip we filled up again and I used .159 gallons less than him. It isn't about the sprocket as much as it is about being smooth.
post #4 of 10 Old 09-30-2008, 06:56 AM
assuming your old odometer reading was correct, you could take your mileage with the 17 tooth sprocket and multiply by 17 then divide by 16 to get the actual mileage.
timbo813 is offline
post #5 of 10 Old 09-30-2008, 07:12 AM Thread Starter
cause i drive interstate 99% of the time and it buzzes like a mother with a 15t at the normal 80-100 cruising speed i drive...
post #6 of 10 Old 09-30-2008, 07:13 AM Thread Starter
thank you i knew someone would know the proper % ... appreciate the info
post #7 of 10 Old 09-30-2008, 06:59 PM
Veteran Donation
Another thought...With my 17 frt I noticed that it took a bit more twist/gas to get the same results as the 16 did,so I was using more gas/throttle to get the 919 moving,to get around traffic.pretty much anywhere where I was not cruising.
However it killed the slight vibe at 65-70 and smoothed first gear lunge.I use 17/44 (+1 front and rear) with a 520 chain works perfect for Me.
tvetree is offline
post #8 of 10 Old 10-01-2008, 03:40 AM
Franklin McGillacutty
riquefied919's Avatar
+1 I'm running 16/45 more fun. I bought it to have fun not fuel econ.
riquefied919 is offline
post #9 of 10 Old 10-01-2008, 05:31 AM
+1 Riquefield919
post #10 of 10 Old 10-01-2008, 08:32 AM Thread Starter
i have stock rear 17t front.. its fun as hell.. i was just curious about the percentage the sprocket changed things.. i check milage every tank not because i am worried about it but because its something i allways have done.. i ride the living "poop" out of my bike .. i beat it like it owes me money.. i guess the questions i ask are the same reason i learn to speak other launguages.. i just wanna know ..lol
