Project Wreck. Headlight plug missing. . - Wrist Twisters
post #1 of 6 Old 03-19-2009, 07:11 AM Thread Starter
Double G's Avatar
Thanks for all the help with parts, just fitting up the headlight and noticed that the plug for it must of been ripped off the bike, all I have are 3 bare wires, blue, green, white. Is the 3 prong plug the same size as a car? Can someone tell me which wire goes on what plug and I will just make it work . thanks
" I have no complaints, ever, about anything." Steve McQueen
Double G is offline
post #2 of 6 Old 03-19-2009, 07:24 AM
The 919 wiring diagram is always available for reference. Not sure about a car plug working, it is worth looking into.
White = Low beam
Blue = High beam
Green = Ground
post #3 of 6 Old 03-19-2009, 08:09 AM Thread Starter
Double G's Avatar
thanks, looks like blue on the top lead, white on the left, green on the right if you are sitting on the bike. I am looking for female plugs that will fit the male tips on unit now.
Double G is offline
post #4 of 6 Old 03-19-2009, 08:20 AM
Duckin' for cover..
SoCal919's Avatar
On old bikes in low budget days I have used a car headlight on a bike, so I am fairly sure it is the same connector in which case it should be readily available at the junkyard if not the auto parts store.
SoCal919 is offline
post #5 of 6 Old 03-19-2009, 01:04 PM
Prepare 4 surprise attack
Sgt_Mojo's Avatar
If you can't find a plug that fits you can always use male flat connectors on each wire and insert it in your female connector.
Simon
Sgt_Mojo is offline
post #6 of 6 Old 03-19-2009, 01:08 PM
yes it is the same 3 prong as honda cars.. I blew mine last week and used an old bulb from my civic while waiting on a replacement. I also once used a 3 prong from advanced auto for the bike.
