Problem with 919 Odometer/Trip Meter button/switch. - Wrist Twisters
post #1 of 4 Old 06-01-2016, 10:42 AM Thread Starter
This town needs an enema!
LeatherWings's Avatar
The button that switches from Odometer to Trip meter (and resets) doesn't work anymore. It was kind of a progression, as over the years I would sometimes have to press really hard to get it to work. I'm thinking maybe the pressure from routinely pressing down on it over time has just pushed the actuator (or whatever) further down and the button/switch is no longer making contact.
I haven't opened it up yet to see, but I just figured I'd first ask if anybody else has had this problem?
| '02 919 - Batcycle | '00 Suzuki SV650 |
Barbarians at the Gate
facebook.com/batgband
LeatherWings is offline
post #2 of 4 Old 06-01-2016, 11:00 AM
Yup, had this problem. Actuator just gets gummed/stuck over time and/or the rubble piece that pushes the actuator gets stuck in the plastic trim surrounding the actuator. Try wiggling the button a bunch while pushing it down at various angles. This freed it up for me. if that doesnt work, take it a part, clean it up and reassemble. you should be good to go.
post #3 of 4 Old 06-01-2016, 11:03 AM Thread Starter
Ah ha, I will try that. Gracias!
post #4 of 4 Old 06-05-2016, 08:29 PM
Kan110's Avatar
i just solved this problem by swap the another side's button . it should be the HISS switch? and useless for me
04 Honda VTR250 <-Sold
99 Honda 599 <-Sold
04 Yamaha Vino125 <-piston seized
02 Honda 919
12 Honda Pcx150 <-Sold
14 Honda Grom
Ohlins 8.5N/mm Front spring
Wilbers Type 641 Rear shock
Hyperpro RSC Steering damper
MIVV X-CONE exhaust
Nissin 19mm radial master cylinder
Stainless steel Brake line
CBR900 330MM Brake discs
Kan110 is offline
