Power Madd handguards.... Anyone put these on a 919 yet? - Wrist Twisters
 1Likes
  • 1 Post By DesertIrish
post #1 of 8 Old 11-11-2015, 02:58 PM Thread Starter
So I picked up a set of PowerMadd Stars with the install brackets for my 919, my hands dont like cold weather.
After mounting them on the Renthal bars, they don't quite fit in front of the levers, so they are sitting just above them. Has anyone else put these on and if so what mod did you do to make them fit
DesertIrish is offline
post #2 of 8 Old 11-11-2015, 03:09 PM
No experience with them myself, I've been using a set of barkbuster storms for a couple years now, this are cool looking, kinda batmanish
voodooridr is online now
post #3 of 8 Old 11-11-2015, 05:25 PM
Flip the mounts over.... you have them on upside down. They are supposed to go under the controls.
BTW: I have used hand guards for years, absolutely love them for cold weather riding, especially if its raining. Even better is when you slide a set of "grip muffs" over them, it lets you wear summer gloves when it's wet and cold, as long as you have heated grips.
You can kind of see mine in this pic:
jnich77 is offline
post #4 of 8 Old 11-11-2015, 08:25 PM Thread Starter
Lol, I knew something didn't look right. Thanks for the fix, will swap them over in the morning.
post #5 of 8 Old 11-12-2015, 11:19 AM Thread Starter
ok, I tried to mount them under the bars, didn't work. They hit the bottom of the controls. The problem that I am having is that the mount is not long enough to get in front of the levers.
Any help would be appreciated.
post #6 of 8 Old 11-12-2015, 12:36 PM
Humm...well, mine are specific to the right and left side and they position the hand guards at a slight angle so they clear the levers. Try swapping sides and see if that helps. If not, try another kind. Mine were 19.99 at Cycle gear and they fit great. Although mine hit on the throttle side, it took about 5 seconds on the bench grinder to reshape it to fit.
jnich77 is offline
post #7 of 8 Old 11-12-2015, 12:38 PM
Actually, just looked at your pics again, they need to be swapped from one side to the other, should fix it. Then they will hold the guard out from the levers.
jnich77 is offline
post #8 of 8 Old 11-12-2015, 01:16 PM Thread Starter
Ok, think I have it now. Got them mounted up, though in order for them to up high enough on the throttle side, the throttle cables have some stress on them when turned full left. Tried routing the lower cable below the brake lever, didn't work. I will have to ride it and see how it goes.
jnich77 likes this.
