power comander - Wrist Twisters
post #1 of 30 Old 12-08-2008, 11:15 AM Thread Starter
power comander
im going to change the stock cans would i need a power comander as well also does any one have any advice wich cans to get i was thinking of miv , scorpion,arkapovik but i have heard about exust mounting braking with aftermarket cans put on
9 toes is offline
post #2 of 30 Old 12-08-2008, 01:27 PM
CB900 Hornet
Sturmmann's Avatar
You don't neccessarily need a PCIII. It's only for fine tuning your setup or having the flexibility of various maps. Though it has only done good to anyone who already has it installed.
As of now, the only two company still making cans for the 9'ner that replaces the oem y-pipes are Leo Vince and Termignoni. All other exhaust setups are slipons.
Where did you hear exhaust mounts breaking? My Satos' mounting tab didn't even crack when I crashed at 25mph.
Sturmmann is offline
post #3 of 30 Old 12-08-2008, 01:33 PM
McCrimmon's Avatar
You can never go wrong with SATO's...Quality and performance are Top Notch
2008 Yamaha FZ1-Street
2005 Honda CBR 600rr-Track
McCrimmon is offline
post #4 of 30 Old 12-08-2008, 01:35 PM
maryland mike just changed his exhaust out for a single sided one.. and the dyno man said he didnt need a pc3...
i have a single sided exhaust and a pc3..
i don't know.
post #5 of 30 Old 12-08-2008, 05:02 PM
i don't know.
Seems like even if you dont' need one, like Sturmman said anyone may benefit if you want to try different set-ups....like maps for power and others for better fuel efficiency. If you do get one and there is no map available for your specific setup that someone else has done you would have to go to a tuning center and get a custom map made with your bike on the dyno. The guy I went to charges $275 to make a custom map, so it would have been another almost $600 for a PC3 and a custom map. I just paid him $50 to evaluate how my bike was running by monitoring the air fuel ratio, at some points from idle to wide open. Lucky for my wallet...I didn't need one.
You may want to see what existing maps are available for the exhausts you are considering so you will know your options are.
Good luck!
post #6 of 30 Old 12-08-2008, 05:14 PM
McCrimmon's Avatar
If you have a PCIII USB you can download any map available right off of the PC site. You will notice a difference with it...ie; smooth throttle response, smooth power delivery and in alot of cases, better fuel economy as it fine tunes all power ranges
post #7 of 30 Old 12-08-2008, 05:20 PM
Broken exhaust mounts have been reported since the original 900 Hornet went into production. It has happened with stock and aftermarket cans. Lots of speculation as to why but never a definitive conclusive answer.
post #8 of 30 Old 12-08-2008, 07:05 PM
it was elves... rotten little cookie makin elves!!
post #9 of 30 Old 12-09-2008, 09:57 AM
The Powercommander is a good idea even if you have the stock exhausts. It gives you better throttle response & a more linear power delivery throughout the rev range.
If JetBlast doesn't mind I can hook you guys up with some killer Holiday Sale Prices on the Sato stuff and Powercommanders. If I am breaking the rules then just delete this post.
post #10 of 30 Old 12-09-2008, 11:22 PM
djmell762's Avatar
what's this about deals?
djmell762 is offline
post #11 of 30 Old 12-10-2008, 12:02 PM
Shoot to stop
beardking's Avatar
Yeah, what's this you say about deals? I'm still holding out hope that I'll get a Christmas bonus this year.
beardking is offline
post #12 of 30 Old 12-10-2008, 12:12 PM
PM Sent
post #13 of 30 Old 12-10-2008, 12:15 PM
McCrimmon's Avatar
+1 Picked up my set up through you guys there Mike and the price was great...Beat any other deal I could find at the time
post #14 of 30 Old 12-11-2008, 11:12 AM
Yoshi's
fastenoft is offline
post #15 of 30 Old 12-11-2008, 08:59 PM
PHOBMAN's Avatar
Howd'ya get 9 toes? crash the bike?
PHOBMAN is offline
post #16 of 30 Old 12-12-2008, 07:48 AM
Unbannable
Super Sneaky Steve's Avatar
Do you want cheap chinese electronics running the brain of your bike or something Honda engineered?
PCIII's will take a dump the stock one almost never will.
Super Sneaky Steve is offline
post #17 of 30 Old 12-12-2008, 09:55 AM
First off what Honda engineered is a 3D mapping that is designed to appease the EPA and force your bike to burn fuel in a manner that limits emissions & noise rather than burining fuel for optimal combustion and power.
Second, I've got PCIII's on every single fuel injected bike I have now or have ever owned. That makes 6 in the garage right this second and I've never had one fail.
I've sold literally thousands of them and I can think of maybe 3 that have ever actually failed. Almost every call I have had about a PCIII that won't work has turned out to be problems with the installation and not the Powercommander itself. It only takes a modicum of mechanical knowledge to install one, but some people are just devoid of that...
Third, the PCIII doesn't ruin the brain of anything. It is a piggy back system used to alter the injector dwell time by intercepting & altering the signal from your bikes ECU not replacing it.
post #18 of 30 Old 12-12-2008, 10:42 AM
[QUOTE=Lord Duckhunter;260805]
QUOTE]
I have had at least 5 bikes now with PCIII's and zero problems. Plus, after a custom map, it is amazing how much better the bike runs in all situations. I think I have gotten far more benefit from the daily running improvements than the outright performance, given the percentage of time I use each of those.
sike is offline
post #19 of 30 Old 12-12-2008, 07:57 PM
LDH, good to see you around.
I am running a PCIII USB, Sato gen IIs, & your 2nd rev Sato gen II map. My bike is hard to start. I have to turn the throttle while cranking to get it to start sometimes. This has not always been the case, & seems to happen most when the weather is cold & the bike has been sitting (but has also done it on warm days & after I stop for a Coke & go to start the bike again--engine still warm).
There are many like me on this board & some have removed the PC & say it fixes the problem. I have not tried this, nor do I want to abandon the PCIII.
I soldered my throttle position wire & sealed it up good with heat shrink tubing. I also have not messed with any buttons, dont use the acel pump, & have tried setting my throttle min &max positions.
Any help?
Bryce919er is offline
post #20 of 30 Old 12-12-2008, 08:17 PM
Originally Posted by Bryce919er View Post
Any help?
I'm obviously not LDH, but I can tell you my experience. My Warrior and Busa both had downloaded maps and neither of them had outstanding fuelling (better performance, but some glitches in fuelling). It was kind of a trade-off between the performance and the glitches. My ZX10 and my 919 both have custom maps, and the biggest difference is in the day-to-day running. I highly recommend dyno tuning to everyone. I think there is just too much variation from bike to bike for downloaded maps to "always" work. I'm willing to bet that almost everyone who has their bike dyno tuned by a talented tuner will be amazed by the overall improvement.
Just my experience.
sike is offline
post #21 of 30 Old 12-15-2008, 11:43 AM Thread Starter
difrent bike
9 toes is offline
post #22 of 30 Old 12-16-2008, 10:21 PM
LIVE FOR THE PROCESS
Nesty's Avatar
Originally Posted by sike View Post
... I'm willing to bet that almost everyone who has their bike dyno tuned by a talented tuner will be amazed by the overall improvement.
Just my experience.
Thank you, Sike. I'm on board with the idea of adding PC to my stock 9. Sooooo...now what? I just go to every dyno tuner in So Fla and ask, "Are you talented?...No?...Just mediocre?...Yeah, you do look a little slow, can you recommend someone smarter than you?"
Can you give me a little more to go on? Are there specific guidelines someone should give the tuner? Specifics that someone should look for from the tuner, etc?
Nesty is offline
post #23 of 30 Old 12-16-2008, 10:24 PM
just gimme a call jon.. i have a friend to install the pc3 and i can get you a sweet price on one also... and show you how to install the maps even..
yup i am intelligent and versitile!!
post #24 of 30 Old 12-16-2008, 10:47 PM
Nesty's Avatar
B. you are unbelievable.
The Lord didn't bless me with me too much mental acuity, physical stature, particularly good looks...(insert 30 minutes elapsed time while list of underachievement continues)... but He did surround me with good people!
Nesty is offline
post #25 of 30 Old 12-16-2008, 10:57 PM
If there aren't any good tuners in your area, you can post up your mods and ask folks who have the same mods which downloaded map they are using (that they like). Try each one and see which one your bike responds best to. In all likelihood, there is a good tuner somewhere in South Florida. Try to stop by a trackday and ask folks who is doing the dynotuning in your area. If you find a couple of folks in the fast group all using the same tuner, there is a pretty good chance the person has good skills. The place the successful racers go is a good sign. When you talk to the person (the tuner) they should ask you what you want out of your tune (better day to day, max power, combination or even gas mileage). Also, they can usually explain ad nauseum the details of the map in three dimensions.
Good Luck, Steve
sike is offline
post #26 of 30 Old 12-16-2008, 11:21 PM
Nesty's Avatar
Thank you, Sike. "Ad nauseum". Frickin' perfect.
Nesty is offline
post #27 of 30 Old 12-17-2008, 07:27 AM
post #28 of 30 Old 12-17-2008, 10:12 AM
Tom
Tom's Avatar
Bryce919er,
Is that the same map as the one identified as "919satonew1.map" at Mike's www.919.org website? I have the CF newer version Satos with no other mods, and it starts and runs great.
...seems like when there is a snag, the PC is hard to troubleshoot, and when it's good, it's great...with no intermediate steps...
Tom is offline
post #29 of 30 Old 12-17-2008, 05:57 PM
Originally Posted by Tom View Post
Bryce919er,
No, its the one after thats "refined for smoother shifting."
I have the same engine/intake/ehaust setup as LDH from air intake trumpet to exhaust tip.
Mine used to start fine, still does on rare occation, but usually not.
post #30 of 30 Old 12-17-2008, 06:01 PM
i am running one of the european maps...the 505map... and i am 3 bars rich low 2 rich med 2 high and mine is running like its butts on fire and its hair is catching...
