Powdercoating - Wrist Twisters
post #1 of 30 Old 03-11-2012, 06:24 PM Thread Starter
devondunit's Avatar
Powdercoating
I would just like to extend my powder coating service to anyone interested; I built a powder coating oven and have done about 20 parts on my bike as well as a few for my friends. Everything has turned out awesome and the high temp powder I used on my muffler and engine has suffered nothing from the heat. Powder coat is much stronger and heat resistant than paint as well as more chemical proof. I will charge according to the part size. Located in Columbus, oh. and will do most business via ups/usps. For a quote just post me a pic or Email me at [email protected].
devondunit is offline
post #2 of 30 Old 03-11-2012, 09:14 PM
TEXAN
MF1VE's Avatar
Good work on the Halloween paint. I do powder coating at home (not for profit, no competition here) but my oven is too small for a swingarm.
MF1VE is offline
post #3 of 30 Old 03-11-2012, 09:17 PM Thread Starter
devondunit's Avatar
Thanks, I built one large enough to do swing arm but would like to make enough doing it for others to build an even larger setup.
post #4 of 30 Old 03-11-2012, 09:19 PM
Ginger-prick
EatDirtFartDust's Avatar
I'm going to get a hold of you at the end of this riding season. I know that's a long way off, but I don't want any down time.
2007 Honda 919.
EatDirtFartDust is offline
post #5 of 30 Old 03-11-2012, 09:21 PM Thread Starter
devondunit's Avatar
Totally understandable, that's why I just finished mine; I wanted it done before it got too warm for a complete tear-down. What are you wanting coated?
post #6 of 30 Old 03-11-2012, 09:23 PM
Hastatus Prior
TheBeeDeeGee's Avatar
I may be getting in touch at the end of this summer as well for the swing arm.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #7 of 30 Old 03-11-2012, 09:32 PM
or just buy my swing arm, have me drop ship it to devon for powdercoat, then he ship it to you and all you have to do is swap out swingarms, with minimal down time.
post #8 of 30 Old 03-11-2012, 09:32 PM
Ginger-prick
Swingarm, grab handle, side cover triangles, rearsets, fuel fill cover, Anything else I can really.
Is it possible to powdercoat the lower forks, or the fork mounts?
2007 Honda 919.
post #9 of 30 Old 03-11-2012, 09:33 PM
lower forks yes, but you'll have to completely disassemble them in order to do so. as for fork mounts, you mean the triples? you can do the top triple easily. you would be better off spray painting the lower triple if you dont want to deal with bearing removal, etc.
post #10 of 30 Old 03-12-2012, 03:17 AM
I spray painted both lower triple and front forks. MUCH easier than doing a powdercoat job and they both look great.
post #11 of 30 Old 03-12-2012, 04:33 AM Thread Starter
devondunit's Avatar
Im sure The spray paint looks good but isn't as durable a powder, speaking from experience; I've used enamels and laquers. Their ok but don't stand the test of time and wear like powder.
post #12 of 30 Old 03-12-2012, 02:41 PM
Correct, I never doubted that. But are you aware of the time it takes to remove a lower triple, just to have it powdercoated for $20?
And disassembling the forks as well, and making sure that powder doesn't get inside them; also a dozen hours of work in that and re-assembly.
Just depends on how much work you're willing to put into them to get the powdercoat. Almost everything removable on my bike is powdercoated, but those two were just too much work.
post #13 of 30 Old 03-12-2012, 02:47 PM
I'd like to see you powdercoat the whole motor.
post #14 of 30 Old 03-12-2012, 02:48 PM
, it would be easier to buy the one's down south and have them shipped up.
WAY down south....
post #15 of 30 Old 03-12-2012, 02:52 PM
Yeah, but in Minnesota, you cannot register a bike if the VIN and motor number don't match.
post #16 of 30 Old 03-12-2012, 02:53 PM
Need money for parts.
ganktor's Avatar
Really? Actually didn't know that.
that sucks.
ganktor is offline
post #17 of 30 Old 03-12-2012, 03:12 PM Thread Starter
devondunit's Avatar
Yeah I would like to do the forks on my bike as well but it definitely requires a lot of tear down and reassembly, just extending the service to anyone who would like to send me parts they want coated. I'm not trying to open a debate. unless you don't want people to use my service then please kindly refrain from making this thread a debate and steering would-be interested parties away, thanks.
post #18 of 30 Old 03-12-2012, 03:18 PM
WAY down south....
I dare ya
marylandmike is online now
post #19 of 30 Old 03-12-2012, 03:44 PM
If you REALLY want the fork lowers and triples powdercoated instead of painted, it can be done, but as others have pointed out it'll take a couple hours of extra work on your part.
The lower stem bearing will have to be removed and replaced. If you have the tool to do this, it's not a big deal, if not, most bike shops and machine shops can do this for you pretty quickly. They will also have to press a new lower bearing on for you after the triple has been coated.
It'll take an hour or two to remove everything to get the triples off - wheel, fender, brakes, headlight, gauges, handlebars, ignition switch, fork tubes...
The forks will have to be completely disassembled to powdercoat the lowers. If you have a service manual, it's not a big deal to do this yourself - there are also instructional videos all over the internet - just take your time.
I would put in new fork seals if you're pulling the forks apart. I'd give yourself at least an hour to disassemble both forks if you've never done it before. And another hour and a half for re-assembly if it's your first time.
How badly do you want those parts powdercoated? It's not difficult, it just takes some extra time.
post #20 of 30 Old 03-12-2012, 03:54 PM Thread Starter
devondunit's Avatar
Thank you for clarifying, I will probably tackle that project this fall.
post #21 of 30 Old 03-12-2012, 04:14 PM
I can remove the front end off a 919 in about 15 minutes start to finish. Reassembly in roughly the same amount of time. It will take the powdercoater way longer to tape off the clamps and bake them than it will for me to get the parts off & on
I'm all for the orange powdercoat though, just need it to be brighter
post #22 of 30 Old 03-12-2012, 05:13 PM
LDH, you are are, and always will be, the exception to the rule.
And Devondunit, not trying to step on your business. Just giving a heads up to those who want to go through with it. If anything, that info just provides a more seamless customer experience for you and them if they have that knowledge beforehand. Just trying to save some headaches.
"A spoonful of sugar..."
post #23 of 30 Old 03-12-2012, 05:14 PM
I dare ya
*Must resist*
post #24 of 30 Old 03-12-2012, 06:48 PM Thread Starter
devondunit's Avatar
Nice color LDH, I didn't feel like naked bike could pull off the bright orange
post #25 of 30 Old 03-12-2012, 06:58 PM
Wait until you see what I do to my wife's bike with the safety green
post #26 of 30 Old 03-12-2012, 07:02 PM
what you talking about? you aint even done with yours yet you slacker! still got the gold forks to take care of
post #27 of 30 Old 03-12-2012, 08:53 PM Thread Starter
devondunit's Avatar
I was going to go with black and orange on forks
post #28 of 30 Old 03-13-2012, 09:36 AM
I was thinking about having the forks stripped and anodized purple
You can't powdercoat them because the tolerances are too close in the triple clamp and the thickness of the powdercoat will cause them to no longer fit the clamps.
post #29 of 30 Old 03-13-2012, 10:44 AM
+1
Good luck with your powdercoating business! It's great to know there is another WT member than can provide this service. I still have a couple small parts that are painted, but all other black parts have been powdercoated.
I was (hopefully) not deterring anyone from powdercoating, but trying to point out to folks that it's not difficult to take apart the triples or forks, and powdercoating is the preferred method.
And LDH, I really want to see pics of your bike with anodized purple fork & orange swingarm! Your wife's safety-green machine would actually look pretty cool!
post #30 of 30 Old 03-13-2012, 01:08 PM Thread Starter
devondunit's Avatar
I appreciate it, thanks.
