Plexifairing GT for 919 - Wrist Twisters
post #1 of 2 Old 05-28-2012, 05:49 PM Thread Starter
For those who are considering a Plexifaring GT for your 919, be aware that the lower glass "legs" of the shield are intended to tuck behind the turn signals. While this works, it is a tight fit and limits the flexibility of positioning the shield.
To make it work for me, I cut off about 2 inches of these lower legs so that there would no longer be any part of the shield behind the turn signals. This gave me flexibility to tilt the sheild back a few degrees. This allows me to tune the airflow better to my liking. Cutting was easy. Just carefully used a coping saw with a fine blade and then smoothed edge with dremel and a sanding drum.
This shield is pretty big. It cuts such a big hole in the air that it creates a large low pressure area in front of the rider. At 70mph +, this low pressure area was so great that it actually pulls the rider forward!
Doing the cutting and tuning described above allowed me to reduce this low pressure area considerably.
Ralph
RalphLong is offline
post #2 of 2 Old 05-28-2012, 05:57 PM
Pics plz!
