pic request - seat latch - Wrist Twisters
post #1 of 5 Old 05-16-2015, 06:24 PM Thread Starter
CKutz_GO's Avatar
Well the niner must not have been too happy with me after some bumpy ride off road today. It appears to have tried to eject me.
The latest in the niners self mutilation. I got home and the seat came right off. It appears the screw holding the latch in came out and this is what I'm left with.
Could someone show me how this thing goes together n if it is missing anything?
CKutz_GO is offline
post #2 of 5 Old 05-16-2015, 06:35 PM
hope this helps. No idea if mine was reassembled correctly. When chasing a mystery rattle years ago, I found the culprit to be the latch and its bolt floating. A dab of loctite and years later it's still in place.
post #3 of 5 Old 05-16-2015, 07:23 PM
Stutz's Avatar
Stutz is offline
post #4 of 5 Old 05-16-2015, 07:37 PM Thread Starter
CKutz_GO's Avatar
i didn't think schematics would show it that wall. but the pic and that should help.. seems like i just need a bolt and to figure out how to get in there to get the thing back together.
Thanks guys
CKutz_GO is offline
post #5 of 5 Old 05-17-2015, 02:58 PM Thread Starter
CKutz_GO's Avatar
In case anyone else runs into this, so long as you still have the spring, you just have to stick the two pieces back together, jimmy it through the bracket, and bolt it back on. it should line right back up with the arm on the lock mechanism on it's own. i had a m6 x1.00 x 16mm bolt on hand that worked. i put a washer down cause it look the the previous bolt was flanged. and used loctite this time haha
CKutz_GO is offline
