PCIII Problem - Wrist Twisters
post #1 of 8 Old 09-15-2009, 08:47 PM Thread Starter
PCIII Problem
Okay so I just installed the PCIII, everything is working except my headlight. What did I do wrong?
jacadkin is offline
post #2 of 8 Old 09-15-2009, 11:18 PM
CB900
rockdog32's Avatar
Does the headlight come on with the high beam flash button?
rockdog32 is offline
post #3 of 8 Old 09-16-2009, 12:37 AM
woodyeee's Avatar
Obvious question i know.......but is the bulb ok?
woodyeee is offline
post #4 of 8 Old 09-16-2009, 08:01 AM Thread Starter
Bulb is fine, I took everything apart again and checked all the connections. Headlight works now. High beam did not work either when nothing was working. After I got it working again it went off once more, but I turned the bike off and restarted it and the headlight came back on and has been on since. Which connector for the PCIII has something to do with the headlight? The headlight is the only light on the bike that has had any issue.
jacadkin is offline
post #5 of 8 Old 09-16-2009, 01:32 PM
Church of the Holy Smoke
MotoCycho's Avatar
That is a weird one. AFAIK the headlight on the 919 doesn't even use a relay like on most other bikes/cars. The hot lead comes right up thru the left switch pod and down to the headlight lamp. I think it makes a round thru the right switch pod as well? Might even go thru the key switch.. would need to break out the schematic to verify that. The headlight comes on with just the key, bike not even running. I would say your headlight intermittent outage is unrelated directly to the PC3 install.. possibly a result of indirect contact during the process.. but there just isn't a direct link between the two. Perhaps you have a loose wire by the fuse holder? or corrosion on the fuse/holder? Look there. I'd bet if you mess with the wiring some more you can reproduce the headlight outage.
- Rev. CYCHO -
MotoCycho is offline
post #6 of 8 Old 09-16-2009, 02:11 PM Thread Starter
Weird observation. Most of the time since the install the headlight comes on just fine when I turn the key. A couple of times it hasn't though, and comes on when I actually start it. It stays on while riding and everything. This just seems strange!
jacadkin is offline
post #7 of 8 Old 09-16-2009, 02:42 PM
MotoCycho's Avatar
We talking about a Honda 919, right?
- Rev. CYCHO -
post #8 of 8 Old 09-16-2009, 02:52 PM Thread Starter
Yes, we're talking about a 919
jacadkin is offline
