PC III Fuel +/- Meter Question - Wrist Twisters
post #1 of 40 Old 10-13-2008, 07:49 PM Thread Starter
boogerface
mikochu's Avatar
Hey folks,
I installed a Power Commander III USB on my 919 last week and I noticed the Fuel +/- LED meter on the box doesn't hit the top LED when at full throttle. I hooked my laptop to it and the software says it's getting 100% throttle. Does anyone else have this problem? The PC III bootup sequence shows the LED works, but it doesn't light up during normal operation...
Thanks
Michael Reyes
mikochu is offline
post #2 of 40 Old 10-13-2008, 08:36 PM
Clear your throttle position to be sure but mine does not go to the top either. It kind of bounces back & forth between the 2nd & third I think.
Bryce919er is offline
post #3 of 40 Old 10-14-2008, 08:51 AM
hey miko, are ya gonna play with the accelerator pump feature... it can do some interesting things!
post #4 of 40 Old 10-14-2008, 04:48 PM Thread Starter
boogerface
mikochu's Avatar
I haven't had a chance to play with it much. I was a little confused with the values, so I disabled it.
Michael Reyes
mikochu is offline
post #5 of 40 Old 10-14-2008, 07:35 PM
okay ... i am still toyin with it... if i tear sumfin up i'll let ya know so you don't use the same settin...lol
post #6 of 40 Old 10-14-2008, 07:50 PM Thread Starter
boogerface
mikochu's Avatar
I'm an advocate of squeezing out power with a good ratio to mpg... I'm still testing out my first tank of gas with the "Two Brothers Full Exhaust" map.
Michael Reyes
mikochu is offline
post #7 of 40 Old 10-14-2008, 08:02 PM
Ok, this is off topic but I just tried to brush that damn bug off my screen Bryce!
post #8 of 40 Old 10-14-2008, 08:05 PM Thread Starter
boogerface
mikochu's Avatar
You're not alone. It gets me every time, too...
Michael Reyes
mikochu is offline
post #9 of 40 Old 10-14-2008, 08:08 PM
Tirone??
Gotsteam's Avatar
Darn thing got me quite a few times. lol
2006 Honda 919
States visited on my 919
Gotsteam is offline
post #10 of 40 Old 10-14-2008, 08:18 PM
post #11 of 40 Old 10-14-2008, 08:22 PM
post #12 of 40 Old 10-14-2008, 09:23 PM
post #13 of 40 Old 10-14-2008, 11:09 PM
Go'n So slow I'm stopped
xrmikey's Avatar
The light limit is normal. It is stopping right where it should.
As long as your laptop says 100%, your good.
Try 85% sensitivity 5% richer, 20 revs. see how you like it.
xrmikey is offline
post #14 of 40 Old 10-14-2008, 11:15 PM
with which map??? i am using the power commander 004 map.. and i have a single side exhaust.. need... more.... power.... help....me
post #15 of 40 Old 10-14-2008, 11:41 PM
xrmikey's Avatar
Any map.
The accelerator feature is separate from the map itself.
It won't change as you change maps.
FYI, I like the Erion honda map(Attachment 8099).
I have a custom map for my bike, but I do like to play with this one.
This is mine if you would like to try it. Attachment 8100
xrmikey is offline
post #16 of 40 Old 10-15-2008, 07:28 AM
post #17 of 40 Old 10-17-2008, 12:59 PM Thread Starter
boogerface
mikochu's Avatar
After a tank of gas, I can easily say the M112-004 map (Two Brothers Full Exhaust) and Accelerator Pump off gave me an extra 3 mpg...with a potential of 5-6 mpg. Stock, I normally got 43mpg with the 900rr exhaust. With the PC III and M112-004 map, I got 46 mpg even with a bit more "spirited" acceleration testing, hence the potential 5-6 mpg gain.
I'm going to try to xrmikey's recommendations...exciting!
Michael Reyes
mikochu is offline
post #18 of 40 Old 10-18-2008, 06:14 PM Thread Starter
boogerface
mikochu's Avatar
I set up with xrmikey's accelerator pump settings and map. I love it. xrmikey, what was your focus with this map? Compared to the Two Brothers map I was using, xrmikey's map keeps the power coming all the way to redline. It's a fantastic upgrade. Two thumbs up.
Michael Reyes
mikochu is offline
post #19 of 40 Old 10-18-2008, 07:32 PM
i agree i put that map in my pc3 and used the 80 5 20 settings and i like it.. i put the 17t back on.. and now i am waiting for mike to tell me how he likes the 17/43 setup if he will ever get around to doing it.......
post #20 of 40 Old 10-18-2008, 07:41 PM
i am a advocate of squeeezing every ounce of power honda screwed us out of on this otherwise perfect motorcycle... it needs 160 to the ground...ok i will settle for 155
post #21 of 40 Old 10-18-2008, 08:00 PM Thread Starter
boogerface
mikochu's Avatar
I have a 15/45t setup right now. I have the 17t sitting and I'm stilling waiting on the AFAM 43t sprocket. Dan Kyle didn't have any in stock, so they drop-shipped one directly from their distributor. I hope to get it sometime this week.
I don't wheelie, but with the 15/45t setup, it feels like there is wheelie potential even in third gear...WHAT?
Michael Reyes
mikochu is offline
post #22 of 40 Old 10-18-2008, 09:17 PM
xrmikey's Avatar
The focus was to get a straight line 13:1 ratio out the pipes.
That is more important than max horsepower #'s.
The dyno ratio line was about as straight as the tuner has ever seen.(On my bike. Every bike is a little different).
That translates into what you experienced. Ride ability, smooth throttle response & good all around power.
xrmikey is offline
post #23 of 40 Old 10-19-2008, 06:24 AM
I'm running the stock gearing 15/43 and I'm not too into wheelies either. However, I know that I can pull the front tire off just by cracking open the throttle in 1st and second. Also, when people tick me off and I want to get around them, it will keep the front end floating about a foot off the ground in 1st, 2nd, and 3rd.
post #24 of 40 Old 10-19-2008, 10:43 AM
xrmikey's Avatar
FYI. stock is 16-43
xrmikey is offline
post #25 of 40 Old 10-19-2008, 12:01 PM
damn ... how much you weigh?? and if it is anywhere around the 230 i weigh tell me what map your using on your pc3... mine lifts me in 1st.. and occasionally if i shift juuuuusssstt right it will come up a bit in 2nd... getting the front wheel up in 3rd would involve either a: a curb or b: stray dog or cat....
post #26 of 40 Old 10-19-2008, 07:21 PM
So, you're a human...
adamjayp's Avatar
+1 I'm 240 and I get the same thing... I can pop it up in second if I'm over 4k and running premium. Oh, mine is stock...
adamjayp is offline
post #27 of 40 Old 10-19-2008, 07:41 PM
well.... mine must be screwed up then..... cause mine isn't stock.. exhaust,pc3,etc.... grrrrrr....
post #28 of 40 Old 10-19-2008, 07:43 PM
xrmikey's Avatar
My guess he is in the 150-160 range.
If he is running 15-43 (one down from stock in the front) that would explain it.
But for you guys over 230, there is no map that is gonna make explosive horsepower.
The best a PCIII will make is about 5hp, on a good day, if even that.
They are more for ride ability & proper tuning (maximizing hp from a motor) after doing modifications. But not to Make, Horsepower.
xrmikey is offline
post #29 of 40 Old 10-19-2008, 08:05 PM
well dammit i want more horsepower!!!!
post #30 of 40 Old 10-19-2008, 08:22 PM Thread Starter
boogerface
mikochu's Avatar
xrmikey, thanks again for that map and accelerator pump settings. You've made me a happy man.
Michael Reyes
mikochu is offline
post #31 of 40 Old 10-19-2008, 11:22 PM
xrmikey's Avatar
Glad it works for ya! You are very welcome.
xrmikey is offline
post #32 of 40 Old 10-22-2008, 10:26 PM
ok... i put 17t back in... changed map back to .004 set accel pump to 85% 25 and 20 rpm's..... then i went 2 bars rich low 2 bars mid and 2 bars rich high... the butt dyno says it works... and i should have my new exhaust made hopefully this week.... taking the stock header and bastardizing it into a gp afair.... will post pics as soon as i get it tacked up... hopefully won't "f" up anything beyond repair..lol
post #33 of 40 Old 10-22-2008, 10:39 PM Thread Starter
boogerface
mikochu's Avatar
I'm putting the AFAM 17/43t setup on my bike tomorrow. I'll see how I like it.
barton, btw, what dealership do you work for?
Michael Reyes
mikochu is offline
post #34 of 40 Old 10-22-2008, 10:45 PM
post #35 of 40 Old 10-22-2008, 10:47 PM Thread Starter
boogerface
mikochu's Avatar
rick case honda.. weston,fl
Hah, really? My sister is Melanie... I just ordered front brake pads from her.
Michael Reyes
mikochu is offline
post #36 of 40 Old 10-22-2008, 10:48 PM
no kidding... ask her about brian..
thats me
post #37 of 40 Old 10-23-2008, 07:46 PM Thread Starter
boogerface
mikochu's Avatar
Heh, I can't believe my sister made barton pose for a picture to send me.
(The picture isn't re-sized for effect)
Anyway, I got my package from Dan Kyle. I opened the package to see another SCC Tech sprocket. It was quite comical. I called up Mike Wheeler (Lord Duckhunter) and he was just as bothered as I was. He told the person who ordered the drop-shipment from Drive Systems to make sure it was an AFAM. Oh well, I sent it back and I ordered an OEM 43t from my sister. ...Apparently, no one carries steel AFAM counter sprockets for 3 years now.
Michael Reyes
mikochu is offline
post #38 of 40 Old 10-23-2008, 07:58 PM
xrmikey's Avatar
That's the French for ya.
xrmikey is offline
post #39 of 40 Old 10-23-2008, 08:31 PM
damn that is one ugly dude in that picture.... she hollered at me across the showroom... "HEY BRIAN COME HERE SO I CAN TAKE A PICTURE TO EMAIL MY BROTHER"...... lol.... i like melanie
post #40 of 40 Old 10-24-2008, 06:56 AM
Sorry I haven't checked this thread in a while. I took off the front sprocket cover and it is a 16 tooth. Thanks for the correction.
I weight about 185. I just ride it like I stole it and hand her up wet. Guys who pull out in front of you and almost side swipe you with the boat they are pulling behind their hummer somehow lead to wide open blasts past them. I don't like hanging out around idiots that can't drive.
I had a chance to ride a 919 with Sato's and a PC3. It was definitely more responsive than my bone stock w/flapper mod bike. More powerful? Don't know. Didn't want to wreck a fellow WristTwisters bike.
