PAIR removal question - Wrist Twisters
post #1 of 7 Old 05-17-2006, 11:49 AM Thread Starter
For those of you that did the PAIR removal mod on your 919 (or RC51), what did you use to cap the pair inlet holes and where did you get them from? I did it last year and used some plastic furniture sliders, but I do not like them. They are a pain in the a$$ to get on because they don't stretch and they keep cracking after repeated heating/cooling cycles. I am tired of removing my tank and I need something that is going to hold up for my long trip coming up. Any help is appreciated. Thanks.
blackbetty is offline
post #2 of 7 Old 05-17-2006, 01:43 PM
I got some alum. plate, traced old covers, cut, drill for bolt holes & wa-lah... pair valve covers. Doesn't look the greatest, but who's gonna see 'em?
h ryder is offline
post #3 of 7 Old 05-19-2006, 12:23 AM
Church of the Holy Smoke
MotoCycho's Avatar
Please explain what the advantage here would be? What exactly does the PAIR valve do? I thought I read somewhere is scavenges air to the exhaust when the engine is decelerating and throttle is snapped closed? More info please!
- Rev. CYCHO -
MotoCycho is offline
post #4 of 7 Old 05-19-2006, 06:09 AM
BockHawk's Avatar
Nail on the head cycho. The PAIR system is designed to burn off unburnt fuel in the exhaust by sending air into the exhaust. This can cause popping, or, in my case, flames. Removing it has no performance gain at all, you just lose a few ounces of emission controls. Oh, BTW, that's all it's there for, emissions. The greenies are at fault for this one.
2002 919 40,000 miles
BockHawk is offline
post #5 of 7 Old 05-19-2006, 07:06 AM Thread Starter
nuff sed...
post #6 of 7 Old 09-22-2006, 01:18 PM
Me, thas who.
tpirman's Avatar
BOTM
Is there a write-up for the PAIR removal anywhere? I searched but can't seem to find anything... I like shaving weight.
tpirman is offline
post #7 of 7 Old 09-22-2006, 02:08 PM
MotoCycho's Avatar
I talked a little bit about it HERE. (11th post down)
It's fairly straight forward. Either cap the holes or make block-off plates. Your choice. If you make the block off plates for the 919 you can use the reed valve inserts as the seals.. you just have to remove the small screws for flat block-off plates to work. You will see when you get it off. It's nicer to use the block-off plates because it cleans up the top of your engine and allows easier access to the pesky spark plugs.
- Rev. CYCHO -
