pair plates or richen the mixure? - Wrist Twisters
post #1 of 29 Old 12-21-2009, 08:41 PM Thread Starter
ever since i loaded the two bros map, i've had much better throttle response. but at the expense of insane popping. to the point where its embarrassing since i've got a loud exhaust and it's literally a loud BANG. doesnt appear to run too lean from what i can tell.
should i keep adjusting the fuel mixture or should i make the pair block off plates a high priority?
post #2 of 29 Old 12-21-2009, 09:16 PM
(oYo)
2000TJ's Avatar
The plates are a quick fix and cheap.
2000TJ is offline
post #3 of 29 Old 12-22-2009, 06:08 AM
Put on the plates. I believe the popping comes from the PAIR system dumping combustible gasses into the exhaust where the heat from the exhaust/headers cause it to ignite. Thus...a pop and backfire sound.
I have Satos on mine and Semi_Gray's block-off plates fixed it.
post #4 of 29 Old 12-22-2009, 08:00 AM
If you need convincing, just remove the system and plug the holes on the stock plates. No more popping.
post #5 of 29 Old 12-22-2009, 08:22 AM
GET THE PLATES!!
You'll be glad you did
It's a bit of work to remove the system, but there's a terrific write-up that's floatin' around in here somewhere. Use the search field.
It's a bit of effort but not really all that difficult.
omaha_919 is offline
post #6 of 29 Old 12-22-2009, 02:51 PM
touring919's Avatar
The pair system just puts air into the exhaust. the combustables are already there. They just need more 02 so they burn.
02 919 (RIP)
07 600RR
07 CRF450X
81 XS850
09 Versys
touring919 is offline
post #7 of 29 Old 12-22-2009, 04:47 PM Thread Starter
sounds good guys. i'll look into the plates then! does semi-gray still make them? ive seen the plates on ebay but would rather support a fellow member if possible.
post #8 of 29 Old 12-22-2009, 04:48 PM
Who, me?
ricko2's Avatar
Plates. good. kind of a bitch to install, but worth it.
www.rmbsynthetics.com
ricko2 is offline
post #9 of 29 Old 12-22-2009, 07:29 PM
Curmudgeon
semi_gray's Avatar
Yeah, I still have some of these available. I'll shoot you a PM with the details.
semi_gray is offline
post #10 of 29 Old 12-23-2009, 04:56 PM
Hornet Grandpa!
I'm wondering what you had trouble with. Mine went on very easily.
O:\General Info\member1804.jpg
support_six is offline
post #11 of 29 Old 12-23-2009, 08:48 PM
how bout instead of buying expensive plates you get 2 rubber caps and cap off the pair covers. Does the same thing as the plates at a fraction of the cost.
post #12 of 29 Old 12-24-2009, 02:35 PM
i bought mine on ebay for a little less than the ones semi-gray has but you have to mess around trying to seal them back up with silicone in a really tight spot,i think his you can leave the old reeds and gasket on the valve cover and know that you have a good seal,im thinking about getting his for peace of mind,live and learn.
fzperk is offline
post #13 of 29 Old 12-25-2009, 06:45 PM
Hornet Grandpa!
Unless you've got a line on two rubber caps that fit exactly, just know that Semi-gray's plates work perfectly, look even better, and are cheap for what you get. Many have looked for the "rubber caps" but to my knowledge, nobody has found something that fits. Anyone out there have good looking rubber caps that work? I thought not.
post #14 of 29 Old 12-25-2009, 09:28 PM
Well, I picked up some rubber caps from autozone, reused the stock clamps, they fit perfectly and work fine. Yes, they aren't as good looking as semi-gray's plates(I know as I had them on my first 919), but they work.
post #15 of 29 Old 12-27-2009, 09:34 AM
Hornet Grandpa!
Boy is my face red!
post #16 of 29 Old 12-28-2009, 06:15 PM
touring919's Avatar
YOu can also put a rubber stoper in the end of the hose. they are tappered so fitment is easy. Is been on my 600 rr for a full season of races with no issues.
02 919 (RIP)
07 600RR
07 CRF450X
81 XS850
09 Versys
post #17 of 29 Old 01-01-2010, 02:34 PM
Greg
May Man's Avatar
Smile
But the plates look better.
May Man is offline
post #18 of 29 Old 01-01-2010, 03:58 PM Thread Starter
semi-gray pm'd me. totally rocks. bought the plates. waiting for shipping : )
post #19 of 29 Old 01-07-2010, 09:04 PM Thread Starter
got the plates the other day. installed em today. gettin the old ones off were a bitch!
will ride tmw morning and see how she does then report back. mainly looking for no popping/decel. : )
post #20 of 29 Old 01-08-2010, 05:32 AM
elacaba's Avatar
that was my problem before. but as soon as i installed the plates the problem is gone.
elacaba is offline
post #21 of 29 Old 01-08-2010, 04:31 PM Thread Starter
PLATES=Pure Genius!
no more mini-explosions from the back of the bike everytime i roll off the throttle for engine braking. lovin it! throttle response is a bit more smooth, but also a tad bit toucher. worth it! thanks semi-gray!
post #22 of 29 Old 01-08-2010, 04:48 PM
Ballaholic
hornet919's Avatar
anyone have a link to an install for these?
hornet919 is offline
post #23 of 29 Old 01-08-2010, 05:15 PM
Tom
Tom's Avatar
Yes: the first post in the following thread:
https://wristtwisters.com/naked-bikes...html#post88587
Tom is offline
post #24 of 29 Old 01-08-2010, 05:27 PM
Ballaholic
hornet919's Avatar
thank you sir. what part of jersey you from?
post #25 of 29 Old 01-08-2010, 05:36 PM
New
post #26 of 29 Old 01-08-2010, 05:57 PM
Tom
Tom's Avatar
hornet919, I live in Madison, in Morris County...this is about 30 miles west of NYC as the coughing sparrow flies.
Tom is offline
post #27 of 29 Old 01-09-2010, 05:14 AM
Ballaholic
hornet919's Avatar
New
lol very nice.
tom,
so you close to highpoint/bear mtn area?
post #28 of 29 Old 01-09-2010, 06:52 AM
Tom
Tom's Avatar
hornet919,
I am 45 miles SE of High Point and 60 miles SSW of Bear Mountain.
Tom is offline
post #29 of 29 Old 01-09-2010, 08:29 AM
Ballaholic
hornet919's Avatar
ah ok. nice area to ride up there. probably my favorite "local" spot
