Painting the grab bar?? - Wrist Twisters
post #1 of 17 Old 03-26-2009, 10:03 AM Thread Starter
Naked bikes = Perma-grin
Asphalt 919's Avatar
I've seen a couple asphalt black 919 on here with the grab bar painted a flat black. I love the look, and want to do the same to mine. Rather than experiment I thought I'd just ask. What did you use?? Brand?? Ect......
Did you spray clear over it, or just paint?
Thanks,
Luke
Asphalt 919 is offline
post #2 of 17 Old 03-26-2009, 10:09 AM
The best option is to have it powdercoated. I just used rattlecan primer and matte black, and then decided I didn't want it on the bike... it looks good though.
post #3 of 17 Old 03-26-2009, 10:43 AM
Thanks,
Luke
I couldn't find the other thread about this so I don't have my exact paint numbers. I went to Wal-Mart and picked up a can of Krylon Flat Black and a can of Krylon Matte Clear Coat. I also got some prep-all (???) and green scotch brite. It matches my Asphalt very very well.
post #4 of 17 Old 03-26-2009, 12:11 PM Thread Starter
Agreed, powder coating is the most durable, but costs $$$$.
Anyone painted or powdercoated the rear sets flat black??? I got to thinking about doing those too.....thinking that they might look smaller or not stick out if black....thoughts???
post #5 of 17 Old 03-26-2009, 12:14 PM
McCrimmon's Avatar
Powder coating the grab bar wouldn't be much...you might even find that some shops would just toss it in with bigger projects they are doing and charge you very little in the process...
Just my
2008 Yamaha FZ1-Street
2005 Honda CBR 600rr-Track
McCrimmon is offline
post #6 of 17 Old 03-26-2009, 12:19 PM
I have my rearsets powdercoated and after a few months my left heel is already wearing through the powdercoat. You may have a different foot position when you ride and this won't be an issue. I ride with the balls of my feet on the pegs and apparently I press my heel against the passenger portion - paint would have only lasted a couple days.
Also, I would recommend matte black (sometimes called semi-flat) instead of flat black, unless you want the flat black primer look. There's a noticable difference between the two.
post #7 of 17 Old 03-26-2009, 12:22 PM
Flat black is fine as long as you are going to cover it with a matte clear coat. I have some photos. I'll try to dig them out of the forum.
post #8 of 17 Old 03-26-2009, 12:27 PM
Here are some photos I took. I originally thought it was not a good match, but it actually is very, very close. Krylon Flat Black with Krylon Matte Clear on top.
https://www.wristtwisters.com/forum/s...3&postcount=14
post #9 of 17 Old 03-26-2009, 12:34 PM
Praefectus Castrorum
brevity's Avatar
+1
It would take more leg work up front (finding a shop that would do it like McCrimmon suggests), but if they charged you more than $20 to do it, I'd be very surprised. The results will last much longer... Not that the rattle can option would look bad, it just won't last like the powder coat.
No matter which route you travel, be sure to remove the foam-type washers on the bar. Buy a couple of new ones and apply them after you paint/coat. It'll result in a much cleaner job.
brevity is offline
post #10 of 17 Old 03-26-2009, 12:51 PM
The matte clear coat makes all the difference in the world! That looks so much better than straight flat black. Awesome job!!!!
post #11 of 17 Old 03-26-2009, 01:19 PM
Powder coating is preferred however if you care to go the painting route.
Hmmm...
919 Helpful Topics click,
Mr.Mike's 919 click.
Scroll down to read how the gab rail, side covers, and radiator side covers were painted.
A lot of information is a mouse click or two away.
post #12 of 17 Old 03-27-2009, 01:31 AM
i had my grab rail powder coated along with many other things
2003 MATTE BLACK 919,POWDER COATED MUFFLER SHEILDS,BAFFLES REMOVED,GIVI 755 WIND SCREEN
BOUGHT 9/9/2008 395 MILES ,2ND BIKE 1983 V65
ROCK HILL, SC
wicked919 is offline
post #13 of 17 Old 03-27-2009, 07:47 AM Thread Starter
Thanks guys! All good and useful info. I am going to check into the powdercoating. I know a good place that I've taken parts to in the past, like 8yrs ago.
I'll post up pictures so you can all see how it turns out.
post #14 of 17 Old 03-27-2009, 07:49 AM Thread Starter
[QUOTE=mdtoney;292422] I ride with the balls of my feet on the pegs and apparently I press my heel against the passenger portion - paint would have only lasted a couple days.
QUOTE]
MMmmmm, I tend to ride in this position too. Actually I sometimes ride with my heel resting on the top of the passenger rear set...
post #15 of 17 Old 03-27-2009, 08:33 AM
Can you use some tank grip on that spot ? (black rubber)
post #16 of 17 Old 03-27-2009, 09:31 AM Thread Starter
Good thinkin'....cover that spot with something that looks nice......I like it
The asphalt black look is really an addiction. The more of it I get, the more I want!
post #17 of 17 Old 03-27-2009, 09:38 AM
I just noticed it a couple days ago so I'm thinking about what will work best on there. I'll post any ideas I come up with.
