Paint code? - Wrist Twisters
post #1 of 9 Old 08-16-2008, 09:13 AM Thread Starter
Paint code?
After the last group ride I led, I need a small amount of touch up paint, and looked under the seat for the paint code: NH436 -- Asphalt! Obviously, the previous owner had it repainted after he crashed it, and while it looks like a Honda color, maybe one of the later model Gold Wing colors, I need a code number for the touch up paint. If any of you out there with a Yellow 919 could take a look at the frame under the seat for the color code I'd appreciate it.
post #2 of 9 Old 08-16-2008, 09:28 AM
Rob, is it bright yellow like Gin's 599? I can give you that code if it'll help.
post #3 of 9 Old 08-16-2008, 09:58 AM
Two Wheeled Warlord
Danke's Avatar
http://www.colorrite.com/ seems to have a pretty good handle on OE paint.
Danke is offline
post #4 of 9 Old 08-16-2008, 10:06 AM Thread Starter
The yellow 599's I've seen look like a lighter shade, maybe with a bit less red in the mix, but I'd appreciate the code number anyway. The thing is, if when I first saw what turned out to be my 919 amongst the used bikes at the dealership, if it had been Asphalt color I'd have walked right by it -- something about that color and the way it accentuated the profiles just screamed "BUY ME!!" So I did.
I'm afraid the color may have been mixed by the painter, so I'll have to have it custom matched. Ah well: it's worth it.
post #5 of 9 Old 08-16-2008, 10:06 AM
DaveCB919F4
Fastbackdlm's Avatar
A good automotive paint supplier should be able to match it and provide a touch-up mix. Good luck
Fastbackdlm is offline
post #6 of 9 Old 08-16-2008, 01:34 PM
I'll give you a Hundred bucks if you paint it PINK!
Professional
post #7 of 9 Old 08-16-2008, 03:53 PM
Rob, the code on the '04 599 is Y163P, Pearl Flash Yellow. I had the rear cowl repaired and painted, along with the side panels, and the first paint job by code didn't match perfectly. It was a bit more orange than the original paint, which is a fairly bright yellow. My paint shop then used a paint spectroanalyzer and mixed their own color, which came out perfect. Sounds like that might be your best route, most body shops have that option these days, or can get a loaner from their paint supplier.
post #8 of 9 Old 08-16-2008, 05:10 PM
Tom
Tom's Avatar
The later model Goldwing yellows were "Pearl Hot Rod Yellow": color code Y130P.
Tom is offline
post #9 of 9 Old 08-16-2008, 09:19 PM
Go'n So slow I'm stopped
xrmikey's Avatar
Just paint it canary yellow & splash a little road grime on it.
It will blend in perfectly.
xrmikey is offline
