Paddock Stand Question - Wrist Twisters
post #1 of 28 Old 07-02-2015, 02:47 PM Thread Starter
Gents,
Quick one here - the buyer for my RC51 is also taking my old paddock stands with it (the RC has spools, and the rear stand is made for that). I'll be replacing them, and I'm considering these guys :
Front Fork Rear Paddle Wheel Lift Paddock Stands Universal Motorcycle Combo | eBay
(Compatibility list thingy says it's not compatible with the 919, but I find that excessively hard to believe....)
Anybody have those? From some of the pictures I've seen, looks like some do. My question is thus (and I kinda feel stupid asking it) : how exactly does the front one work? Do the forks rest on the two rubber pins, assuming said pins are placed on a horizontal plane? Or is there something I'm missing?
Cheers!
SilverJS is offline
post #2 of 28 Old 07-02-2015, 03:22 PM
I don't have a front one, but I think the pins are designed to cradle the ends of the forks, under and in front, such that the forks can't slip or move once the weight is on them
K1w1Boy is online now
post #3 of 28 Old 07-02-2015, 03:58 PM
I have a version of those stands; they work like Kiwi says. I got the version that has triple tree lift attachment as well; it comes in handy if you ever need to service the forks and don't have a center stand.
ps. Oh yeah, forgot they are in my avatar
post #4 of 28 Old 07-02-2015, 04:02 PM
Triple tree stands are better, IMO. You can't do much but lift the bike with a front stand that lifts only by the forks. Maybe clean the wheel, but the stand that lifts the lower triple is easy to use, so I don't see the need for just the 'lift by the fork' method.
Someone correct me if I am just not seeing the need...
post #5 of 28 Old 07-02-2015, 04:03 PM
Originally Posted by Superdog View Post
.. I got the version that has triple tree lift attachment as well; it comes in handy if you ever need to service the forks and don't have a center stand...
That'd be a feature worth having, I reckon
post #6 of 28 Old 07-02-2015, 04:19 PM
Re Front Lifts
Triple tree pin lift much better as front end aside from triples and head set can all be removed.
Rear Rear Lifts
I got nice spiffy blocks welded to the swing arm, drilled and tapped to receive lift spools.
Next best for a 919 is stand with sticky grippy lift tabs.
Some have drilled the hollow section and mounted spools that way.
I've never heard of a subsequent problem, but I'd never do that.
post #7 of 28 Old 07-02-2015, 04:38 PM Thread Starter
Whoa! I never even knew those lower-triple front stands even existed!! That's most certainly what I'd like, as replacing the forks is precisely one of the things I was going to do (I was just thinking of using two jacks supporting a 2X4 under the engine or something, with the exhaust of course off). I'll do some research and see if those are also available from eBay - I now know Venom does make a triple tree version, which is most certainly the one I'd get. Thanks for pointing me in this direction!
SilverJS is offline
post #8 of 28 Old 07-02-2015, 05:08 PM Thread Starter
Are there some brands that are supposed to be "better" for stands?
SilverJS is offline
post #9 of 28 Old 07-02-2015, 05:17 PM
Yeah, I did it that way, it was pretty straightforward. It was amongst my few experiences of tapping threads, so I did it slowly and with great care, and haven't had any issues with the spools since. Used lots of Loctite in the assembly, and it has been fit-and-forget.
I'm surprised how much I prefer putting the bike on that stand, actually - because it's so easy to do, I just do it all the time in the garage. A centred, levelled bike is just nicer to work on, somehow.
post #10 of 28 Old 07-02-2015, 07:09 PM
PitBull is good stuff, but more expensive, design fit and finish justifies it.
I have a bunch of Woodcraft fronts and one rear.
The Woodcraft fronts work great.
So do their rears, even if they still make them with bendable tangs for custom fitting of different spool widths as mine is.
I bought 2 Vortex stupid cheap.
They are built like tanks, are adjustable and have wider track for better stability.
BUT their geometry sucks, the leverage ratio is much stiffer.
It takes way less effort to lift the rear heavy and heavy 919 as compared to the GSXR track bike.
post #11 of 28 Old 07-03-2015, 09:54 AM
PHOBMAN's Avatar
PHOBSTAND, NOTHING ELSE NEEDED!
PHOBMAN is offline
post #12 of 28 Old 07-03-2015, 10:05 PM
Unless you have other bikes
But yes, on the 919, the Phobman does an excellent job!
post #13 of 28 Old 07-03-2015, 10:25 PM
...except for the trolley jack under the headers
post #14 of 28 Old 07-03-2015, 11:49 PM
Nickr919's Avatar
Shameless plug!
Nickr919 is offline
post #15 of 28 Old 07-06-2015, 09:58 AM
Josh
I have two sets of T-Rex stands, front and rear. They are REALLY strong, and I use them to keep the wheels off the ground during the off season. I think the T-Rex rear stands were just on sale for $50 or something silly cheap like that.
jmdavis984 is offline
post #16 of 28 Old 07-06-2015, 10:11 AM Thread Starter
You are most correct - I called them, and they have front and rear silver stands at 45$ a piece. However, this is for non-triple-tree front version, and spooled back. I wanted non-spooled and triple tree. I ended up ordering the generic Venom stuff on eBay - we'll see how that goes.
But, I did look at those T-Rex stands after you mentioned them - quite sexy, and visibly of better quality than what I got. Thanks for mentioning, hopefully someone else can benefit from this.
2006 Honda 919
2003 Honda RC51 (sold)
1989 Yamaha FZR400 w/ stock, YZF600, and 661cc engines (661 = YZF600 bottom end, FZR600 top end) (sold)
1986 Yamaha TZR250 (sold)
1989 Yamaha RZ350 (sold)
SilverJS is offline
post #17 of 28 Old 07-06-2015, 10:33 AM
What are the dimensions of the Phobstand? I wonder if one could be made to work with my VFR1200. Preferably with no modifications...
post #18 of 28 Old 07-06-2015, 02:40 PM
Total Awards: 17
it will cost the same as oem center stand. You should get one if you don't have one yet.
I want a frame stand but can't justify it currently since I got all kinds of stands already
zaq123 is offline
post #19 of 28 Old 07-06-2015, 03:16 PM
BockHawk's Avatar
Part of me thinks it would be awesome to have one, but the other part knows I would trip over one of the casters and kill myself.
2002 919 40,000 miles
BockHawk is offline
post #20 of 28 Old 07-06-2015, 05:53 PM
That doesn't look like a Tuono
post #21 of 28 Old 07-06-2015, 06:07 PM
Total Awards: 17
Abba lifts are pretty sweet as well
zaq123 is offline
post #22 of 28 Old 07-06-2015, 07:23 PM
Josh
That is one incredible lift/stand right there.
post #23 of 28 Old 07-06-2015, 07:42 PM
Wow that abba stand has certainly caught my attention!!!
post #24 of 28 Old 07-06-2015, 07:47 PM Thread Starter
I'd bet it catches the credit card's attention too.
But it is an absolutely gorgeous piece of kit.
2006 Honda 919
SilverJS is offline
post #25 of 28 Old 07-06-2015, 07:59 PM Thread Starter
ABBA Sky Lift CBR VTR VFR Hornet CB1000R RVF Fireblade 400 929 750 SP1 SP2 NC30 | eBay
A pretty penny, but still actually not as bad as I would have originally thought.
2006 Honda 919
SilverJS is offline
post #26 of 28 Old 07-08-2015, 07:02 AM
deandeib's Avatar
Stand for 919
I have a stand similar to the one in post #1 and it works great in lifting front or rear. Note: DO NOT TRY TO LIFT THE FRONT OFF THE GROUND WITHOUT SOLID SUPPORT UNDER THE REAR. Like a dumb ass, I tried and ended up dropping the bike into the dry wall of the garage. I never liked the cradle method of fork support so I remove the screw cap from the right side of the axle and insert one of the prongs of the cradles into the opening on each side. BUT ONLY AFTER HAVING MY PHOBMAN STAND SECURELY UNDER THE BIKE. I wrapped one of the prongs with several wraps of tape to create a more snug fit into the axle but that may not have been necessary. Just paranoid after my first stupid attempt (see above).
deandeib is offline
post #27 of 28 Old 07-14-2015, 01:59 PM
And to think, all these years i have been hanging mine from two big ass eye bolts in my ceiling.
jnich77 is offline
post #28 of 28 Old 07-14-2015, 08:02 PM
CKutz_GO's Avatar
phobman and steps!
CKutz_GO is offline
