Oil mist on Cylinder head cover gasket - Wrist Twisters
post #1 of 7 Old 07-04-2007, 11:54 AM Thread Starter
I have a 2003 919. Currently it has about 4500 miles. I notice that after every couple of hundred miles of riding, there will be some oil mist forming on the cylinder head cover gasket. The oil is not dripping yet .. it's a thin layer of oil. I don't think this is normal. I am thinking, either the bolts are somehow loose, or the gasket is getting old.
Has anyone experienced similar problem? What would you guys suggest?
If it's not too much work, I think I would try to replace the gasket.
Thanks everyone!
shawnstc is offline
post #2 of 7 Old 07-04-2007, 11:59 AM
Alaska bound
fehren2800's Avatar
Donation Donation Extraordinary Ride
Well I don't think it is age. I have a 96 900rr which is pretty much the same motor and it is still going strong with no leaks. As for changing gasket, if it is just the head cover, that job is pretty simple.
fehren2800 is offline
post #3 of 7 Old 07-04-2007, 01:07 PM
Resident Viper Driver
919jockey's Avatar
Are you able to pinpoint where the oil is coming from?
919jockey is offline
post #4 of 7 Old 07-05-2007, 06:20 AM Thread Starter
not really...the oil mist is on both of the gaskets (the half-moon shape rubber) .. and mostly on the front one ... I really don't know where the oil came from..
shawnstc is offline
post #5 of 7 Old 07-05-2007, 06:50 AM
are you absolutely positive it's oil? Have you checked your radiator fluid level?
post #6 of 7 Old 07-07-2007, 11:15 AM Thread Starter
I am 99.9% sure it's oil. (it smells, feels, looks like oil).
But ... are you suggesting that might be coolant?
shawnstc is offline
post #7 of 7 Old 07-07-2007, 11:27 AM
Yes. Just a thought.
