Oil cap? - Wrist Twisters
post #1 of 13 Old 05-21-2006, 02:32 PM Thread Starter
'02-919
Footastic02's Avatar
Oil cap?
I'm trying to change my oil on an '02 919 for the first time and I have no owners manual. What is the capacity? Thanks
Footastic02 is offline
post #2 of 13 Old 05-21-2006, 02:47 PM
With filter change it is 3.8qt or 3.6liters. Not necessary to measure. Just fill it till it is in the middle of the window, run it for a few minutes, and check/fill again if necessary. That way you make sure you have just what you need.
blackbetty is offline
post #3 of 13 Old 05-21-2006, 02:48 PM Thread Starter
'02-919
many thanks
Beautiful! Short sweet and to the point. Just what I needed.
thanks
post #4 of 13 Old 05-21-2006, 02:51 PM
No prob. Welcome the the group.
post #5 of 13 Old 05-21-2006, 03:09 PM
That 3.8 quarts is with a oil filter replacement.
One thing to keep in mind especially if you have never done this before. Your bike must be on level ground and perfectly upright to get a accurate sight window reading. Tip the bike towards the side stand and the oil level will disappear. You can dump in the whole 4 quarts or if you're anal, decant 190cc (6.4oz.) from a 4 quart container before filling.
post #6 of 13 Old 05-21-2006, 05:23 PM
919 City Pilot
Pegjumpflyer's Avatar
And try not to break off the eng stand fitting by the oil plug....
Pegjumpflyer is offline
post #7 of 13 Old 05-21-2006, 05:34 PM
One more tip, I put a small funnel under the filter between the headers from cylinders 3 and 4 to keep the oil from spilling on the headers when you remove the filter. If you have a large enough oil pan you can have the oil from the oil pan and the filter hole drain into it at the same time. No biggy if you get it messy, but expect some smelly smokey pipes for a short while afterwards.
post #8 of 13 Old 05-21-2006, 07:56 PM
Just use tvetree's fix and put aluminum foil over the pipes in an arrangement where it drains to your pan. No smoke, no mess, nothing melted. Sweet.
post #9 of 13 Old 05-21-2006, 08:07 PM
BockHawk's Avatar
I miss the days when the oil cap listed the capacity of the motor. Aahhh, vintage bikes, those were the days. Waitaminit, I just remembered that I like riding more than wrenching. Nevermind.
2002 919 40,000 miles
BockHawk is offline
post #10 of 13 Old 05-21-2006, 08:09 PM
Wookie
ragdoll's Avatar
Dude, why are you changing your oil? That's soooo 1992.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #11 of 13 Old 05-22-2006, 10:23 AM Thread Starter
'02-919
I wish I had read this before...Because I broke it off. Should I lose any sleep?
post #12 of 13 Old 05-22-2006, 10:32 AM
BockHawk's Avatar
Nah, JB weld it back on.
j/k
BockHawk is offline
post #13 of 13 Old 05-22-2006, 10:37 AM Thread Starter
'02-919
or duct tape.
