O2 sensor question - Wrist Twisters
post #1 of 8 Old 04-12-2006, 09:24 PM Thread Starter
O2 sensor question
I am about ready to install a Power Commander in my 2002 919. The Power Commander Website shows an O2 sensor eliminator for California bikes.
My bike has an evaporative canister under the bike so I assumed it was a CA bike. However, I can't see an O2 sensor anywhere on the exhaust system.
Does anybody know where an O2 sensor would be if it had one?
A second question: How do I get rid of my evaporative canister?
jratbike is offline
post #2 of 8 Old 04-13-2006, 05:45 AM
Wookie
ragdoll's Avatar
I believe it would be on the header close to where it bolts up to the engine... if it had one.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #3 of 8 Old 04-13-2006, 05:48 AM
BockHawk's Avatar
I know it says it has one on the powercommander website, but I'm not convinced. I didn't disconnect an O2 sensor when I took off the stock header, and I think I'd notice something like that.
2002 919 40,000 miles
BockHawk is offline
post #4 of 8 Old 04-13-2006, 05:49 AM
Welcome aboard...
To the best of my knowledge there is no O2 sensor on the 919, including CA models.
I remember reading about how to eliminate the evap. canister. It might be over at project919.
Looking at the shop manual it appears that you could remove the air vent hose from the canister, remove the larger hose that connects the canister to the purge control valve, unplug the 12v connector from the Evap. Purge control solenoid valve, then remove the evap. canister.
post #5 of 8 Old 04-13-2006, 10:52 AM Thread Starter
Thanks!
Thanks!
Jude
jratbike is offline
post #6 of 8 Old 04-14-2006, 05:13 PM
WestCoastHD
Guest
Posts: n/a
I installed mine a couple of months ago, and did not have to do anything for an 02 sensor. I have a 2005 CA model and I don't have an O2 sensor in the header pipe. If you would like a couple of great usb map for a stock 919 I can email you mine and DK's.
post #7 of 8 Old 04-14-2006, 07:41 PM
I read about a guy trying nitrous and had trouble with the injection cooling off the "ECM sensor in the airbox". Might take a peek there.
post #8 of 8 Old 04-14-2006, 09:08 PM
"Whose ABBA ZABBA?"
My 2001 929rr had an O2 sensor, kinda in the middle of the s pipe. If you have one, its where all the gasses come together. Sounds like you got nada.
General George S. Patton
