Noob question! - Wrist Twisters
post #1 of 6 Old 07-22-2008, 02:47 PM Thread Starter
Headcase
Noob question!
Hi everybody! I'd very much like to install a set of bar end mirrors on my 07 919. I took the stock bar end caps off and there's a plug in the bars. Is that removable and if so, how? If I cant make the stock bars work, I guess a set of renthals is in my future. Any help would be appreciated. Thanks, the bean
redbean is offline
post #2 of 6 Old 07-22-2008, 02:50 PM
Hi Bean, there are several threads on here about handlebars and how to remove the stock bar weights, just do a search and you'll find what you need.
post #3 of 6 Old 07-22-2008, 06:21 PM
In case you haven't found what you need yet, here ya go.
The stock bar end weights are retained in the bars by spring clips engaging a pair of holes drilled near the end of the bar. To remove them, thread a long 6mm bolt into the weight, push both tabs inward at the same time and the weights should pull out with the bolt, though they may be a bit reluctant to move initially.
post #4 of 6 Old 07-22-2008, 06:24 PM
Like these?
dhernb11 is offline
post #5 of 6 Old 07-22-2008, 06:34 PM
Also, I have an integrated tail light set if you wanna buy it for your new 9'er
dhernb11 is offline
post #6 of 6 Old 07-23-2008, 05:20 AM
yes, post the light
