NON OEM WINDSHIELDS - Wrist Twisters
post #1 of 65 Old 11-27-2009, 06:41 PM Thread Starter
NON OEM WINDSHIELDS
What do you have? How does it work? Mounting issues? It's getting cold in northern NJ (had to light a coal fire tonight), I need a windshield. Too many postings without much info (no offense), what works well for you?
post #2 of 65 Old 11-27-2009, 07:06 PM
I have the f-18, wife has the f-16. I like them both. They do direct the wind at your face however. Mounting is easy enough.
post #3 of 65 Old 11-27-2009, 07:21 PM
other than a really big screen, I don't think any of them are great on the 919. It's design seems to, no matter what screen you have, direct wind at the head.
Ripper is offline
post #4 of 65 Old 11-27-2009, 07:44 PM
F18 here, and i like the looks, but its not the greatest for wind protection.
The huge shield is the plexifairing and motorcyclesuperstore.com has it. They accidentally sent me one instead of my F18, and that thing is huge.
post #5 of 65 Old 11-27-2009, 09:01 PM
You're always going to have wind on the helmet unless you get a cruiser-style giant screen, and who wants that on a 919? The issue is whether the wind blast on the helmet is "clean" air or buffeting. Most of the smaller screens aren't going to have buffeting issues on the helmet unless you're a really short guy. I have an F-18 also. Like the look, but not sure how much actual wind protection it provides. Think I'm going to pull it off when the weather turns warm in the spring and see whether it really does anything or not. Put it on almost as soon as I got the bike, so can't say for sure right now how much difference it actually made.
jay313 is offline
post #6 of 65 Old 11-27-2009, 10:30 PM
I rode my wifes bike a few times before it had the f-16 shield on. Makes a big difference!
post #7 of 65 Old 11-28-2009, 05:41 AM
This little guy makes a big difference. Doesn't turn your 919 into a Goldwing, but I wouldn't be without it.
post #8 of 65 Old 11-28-2009, 07:43 AM
Givi A305 (made for a 599 Hornet). Its taller than the OEM. Brings the wind up to about neck level (I'm about 6'2")
Wasn't a bolt on. Had to make some custom brackets out of Plexiglas.
post #9 of 65 Old 11-28-2009, 08:16 AM
The f-16 and f-18 mount the same way but I bought the mounting kit. Looks good Mike.
post #10 of 65 Old 11-28-2009, 10:46 AM
national cycles plexifairing 2 is a short full side shield you will be looking over it and it has a sporty look if you adjust it all the way back and down....pops on in less then a minute...once its adjusted..why fool around with something smaller...ride 100 mph all day long with no stress at all on the body..legs dont get tossed around eather
secondchance is offline
post #11 of 65 Old 11-30-2009, 09:23 PM
jeff1250's Avatar
I have this GIVI too.
It gets the wind off my chest.
Also keeps bugs off the instruments and the front of my jacket,except the arms. A bigger screen would be nice when it's cold, but would spoil the looks of the bike ( in my opinion )
jeff1250 is offline
post #12 of 65 Old 12-01-2009, 08:39 AM
2007 919 (Gotta love it)
WIICKED1's Avatar
Monster
I used the Ducati Monster's windshield. Makes a BIG difference. And it looks great.
WIICKED1 is offline
post #13 of 65 Old 12-01-2009, 12:16 PM
BrokeRecord
Last year I put the F-15 on my 919. It is a bit larger then the F16 and F18. Definately not suppossed to fit, but, after about 5 days of assemble, ride, and remove to make another small change. It worked great. I rode about 200 miles that days and was really happy with the protection and quiet. I went thru a curve over my head met an oncoming car, and went out thru a front yard. When I got up, my sheild was in 25 pieces. I'm now using an F18, with my 755 due in tomorrow.
You may think the sheild in not doing any good, but, use it a few times and then take it off and go ride,You'll see right quick a little cold air goes a long way.
I ride because I love to ride, if it doesn't look just right, that means nothing to me.
brokerecord is offline
post #14 of 65 Old 12-01-2009, 02:00 PM
I have the F18 & the F16 Sport shield. I couldn't really tell much difference between the two. Both kept the wind off my chest and did not cause any helmet buffeting although I thought wind noise was more with the F16 and I found the F16 was caused me a lot of front end shaking if I took my hands off the bars.
garyb900 is offline
post #15 of 65 Old 12-01-2009, 04:37 PM
Which Givi is that one? Not bad looking.
jay313 is offline
post #16 of 65 Old 12-01-2009, 05:49 PM Thread Starter
Do you remember the fitting details of the F-15? This looks like it might be what I want. Thanks.
post #17 of 65 Old 12-01-2009, 08:22 PM
I like mine NAKED
post #18 of 65 Old 12-02-2009, 09:40 AM
BrokeRecord
Do you remember
Basically the holes in the glass at the bottom are in the wrong place. I left them alone as to not weaken the sheild. The sides that bolt to the adapter to headlight are wider, so the adapter needs to be made thicker. I put 2 pieces of metal together with 3M doubled sided tape. Then re-drilled the bottom holes in the metal bracket to fit the holes in the sheild. As it was it laid back too much. It needed to stand up a lil straighter. That's why I took it off and on several times to get the angle right.
I'd go for it if you want the bigger size.
I never throw away any type plates and adapters I stop using as I'll mill one to fit something different quite often.
If I can find the plates, I'll let you know. If I find them and you spring for the sheild, I'll mail them to you.
post #19 of 65 Old 12-02-2009, 03:01 PM Thread Starter
Thanks for the offer, I may very well take you up on that. The size of the F15 looks big enough to keep wind and rain off without looking like a bubble. I'll let you know if I order one and of course mail a check for the shipping. Thanks again!
post #20 of 65 Old 12-02-2009, 04:38 PM
jeff1250's Avatar
A240
jeff1250 is offline
post #21 of 65 Old 12-09-2009, 12:20 PM
BrokeRecord
RE:
My Givi 755 and new mirrows. Why did Honda use the reverse thread on the mirrow adapters? So, if they vibrated loose, they would constantly try to tighten back up by wind pressure? Blue locktight works well for that!
post #22 of 65 Old 12-09-2009, 12:25 PM
BrokeRecord
Sorry PC acting up and won't upload.
post #23 of 65 Old 12-10-2009, 06:30 AM
I tried an F18. Only so-so chest protection, but a turbulent blast at my helmet.
I'm 5'10". I got a Honda screen when they became available again. Good chest protection with some wind at the helmet, but not very turbulent. A good compromise for me plus the mounting hardware is first-rate. Years of experience have taught me to be wary of accesory mfg. claims. "universal fit" means it won't fit anything, "custom fit" means it won't fit YOUR bike/car.
robert4 is offline
post #24 of 65 Old 12-10-2009, 11:05 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
Memphis Shades Blade Runner in gradient black. Four point mount and very solid.
Doc
ST-DocLizard1 is offline
post #25 of 65 Old 12-10-2009, 01:24 PM
Brutale Hornet Builder
opper's Avatar
Hmmm my 919 came with this bathtub
-was on the bike for the first 20 minutes in my garage and now in a box
Shown with a friend who helped me pick it up and my to kids Mikkel and Malene
Model is unknown - havent looked at it since
Now running with a Powerbronze F5 in irridium blue, had to fabricate as I was not satisfied with the crapy suplied adapters/fitment
Did some Carbon strips with holes for the screen and a bigger one to get under the headlight bolt, thin enought to be flexible and follow the curve of the screen and strong enought to hold it secure at 150km/h
-just sawed it out of a small carbon sheet from the garage
Very good quality and good protection and looks (is more Shiny/Chrome and allmost the Hornet blue in the Sun)
Lars / Opper
opper is offline
post #26 of 65 Old 12-10-2009, 04:04 PM
BrokeRecord
Re: Opper
That 1st blue sheild looks like the bikini fairing that Chapparell, and some other warehouses used to sell. They had a round and square headlight model.
post #27 of 65 Old 12-13-2009, 04:07 AM Thread Starter
Hey, what kind of mirrors did you get? Are they wider than the oem? This is one of my biggest complaints on the 919, I would love to see something other than my shoulders! I was thinking of getting widening brackets but could probably buy new mirrors for the same $ or less. Any luck uploading the pic? Thanks.
post #28 of 65 Old 12-14-2009, 01:40 PM
BrokeRecord
RE: Mirrors
They are Emde that Honda stocks at a lower price then OEM. Metal not plastic. They are rectangle shaped and not quite as wide as stock. I found some polished alloy extenders That are being shipped from Hong Kong, now to move out 60mm on each side. I never liked the Mickey Mouse ears look of the OEM. I'll try again to make the jpeg of the mirrors smaller.
post #29 of 65 Old 12-14-2009, 01:55 PM
I bought some of those mirror extenders. Made a big diff for me. I can see past my shoulders now.
post #30 of 65 Old 12-14-2009, 01:58 PM
BrokeRecord
RE:
Still hoping it will come thru.
post #31 of 65 Old 12-14-2009, 04:51 PM Thread Starter
How effective is the 755?
post #32 of 65 Old 12-14-2009, 04:53 PM Thread Starter
Which ones did you get?
post #33 of 65 Old 12-14-2009, 05:07 PM
I got them off of eBay, its been awhile, but pretty much like these. Nice quality aluminum with Stainless Hardware
Ebay Auction
post #34 of 65 Old 12-14-2009, 05:27 PM Thread Starter
Ebay Auction
Thanks! I'll buy a pair tomorrow, these are the cheapest I've seen.
post #35 of 65 Old 12-15-2009, 09:01 PM
BrokeRecord
RE: 755 Givi
Not alot different from the National F18. But, looks to be more aero shaped. Probably paint it Candy Glory Red when i decide to turn loose of the $$. That is hi dollar paint. $34 for a spray bomb!
post #36 of 65 Old 12-23-2009, 05:46 PM
just ride it...
cb919er's Avatar
I know a lot of people don't like national cycle, but I have the f-16 tall, and I love it. was easy to put on and take off. Good to tuck down behind, good screen over all. Even helps keep my tankbag dry, as long as I keep moving.
cb919er is offline
post #37 of 65 Old 12-23-2009, 06:04 PM
just ride it...
cb919er's Avatar
my windscreen
cb919er is offline
post #38 of 65 Old 12-23-2009, 06:38 PM
tc919er's Avatar
Good info CB, I can't seem to make up my mind which screen to go for. Everybody has their own opinions on them. I've been leaning towards the N.C. plexifairing GT. I know it's big but I think I'd only use it for cold weather. I'm just afraid to shell out $200 bucks and think it's butt ugly and not like it!
"No freeman shall ever be debarred the use of arms."
---Thomas Jefferson 1776.
tc919er is offline
post #39 of 65 Old 12-23-2009, 06:40 PM
My f-18 is now for sale if anyone's looking. Check the for sale section.
jay313 is offline
post #40 of 65 Old 12-23-2009, 07:13 PM
just ride it...
cb919er's Avatar
I think it was the big GT windshield, my dad bought an old '77 goldwing and it came with it, he hated it and gave it to me, and I mounted it on my Nighthawk 750. It was pretty good, but you're right it was butt ugly. I only had it on when it was really cold. Alas, I sold it with the nighthawk or I'd make you a sweet deal on it...
cb919er is offline
