Noise at low speeds.. - Wrist Twisters
post #1 of 11 Old 06-30-2008, 11:18 AM Thread Starter
Hey everyone...I've noticed that when I am riding at lower speeds (10-15mph) I can hear this noise from the front. It sounds like maybe the brake pads are still somewhat touching the rotor. It's not constant, but more on off on off on off. It's a friction noise of some kind.
Any ideas as to what it is and how I can fix it?
Thanks,
Cris P.
s2cmpugh is offline
post #2 of 11 Old 06-30-2008, 11:37 AM
Unbannable
Super Sneaky Steve's Avatar
It may just be your pads touching a little. In that case not a problem.
Super Sneaky Steve is offline
post #3 of 11 Old 06-30-2008, 12:42 PM
I hear the same thing. If it's a rotational rubbing sound it is most likely the pads. Mine gets louder when I lean into a corner. Try riding the front brakes a little and see if it goes away. If it does, mystery solved.
2015 Ducati Monster 1200S
FlyCatcher is offline
post #4 of 11 Old 06-30-2008, 01:01 PM Thread Starter
That's EXACTLY what mine is doing. I agree in that more than likely it is the pads slightly rubbing the rotor. Is this something that can be fixed or is it nothing to worry about? (I'm not sure if the 919 has a return spring for the pads.)
Thanks,
Cris P.
s2cmpugh is offline
post #5 of 11 Old 06-30-2008, 06:26 PM
The square section seals that bear against the pistons deform when pressure is applied, and relax when released, retracting the pistons a small amount. The pads, however, are not physically tied to the pistons so will be against the rotors but not firmly -- the normal small amount of rotor runout will knock them back against the pistons, but some residual contact is common, resulting in the noise you hear. If it is excessive the rotors will get hot while riding. To check this, apply the brakes medium hard then release and ride for a couple miles without using the brakes. After this, stop using the rear brake only and feel the rotors, being careful at first, for heat: they shouldn't be much above ambient temperature. If one is hot to the touch there may be a piston hanging up on that side. If both are hot there may be a problem with the master cylinder not returning far enough to uncover the compensating port, thereby constantly applying pressure to the pistons. This is unlikely.
From your description it sounds normal.
post #6 of 11 Old 07-01-2008, 04:05 PM Thread Starter
Sounds good man, thanks for the explanation. I'll try the braking technique and see if I notice, but from what it sounds like I don't have anything to worry about.
Thanks,
Cris P.
s2cmpugh is offline
post #7 of 11 Old 07-01-2008, 05:24 PM
I have the exact same thing. The rubbing sound gets louder when I'm leaning into a turn. Glad to hear it's a common thing and not a problem. Would still rather not have it happen tough.
garyb900 is offline
post #8 of 11 Old 07-01-2008, 05:33 PM
Trackday Recognition Veteran
To eliminate the noise, use a pair of channel locks to pull the pads away from the rotors and quit using your brakes.
Hope this helps.
Sokali is offline
post #9 of 11 Old 07-02-2008, 02:10 PM Thread Starter
Hope this helps.
Hahahaha...I'll just start using my reversers on the HondaJet engines I just installed.
Cris P.
s2cmpugh is offline
post #10 of 11 Old 07-02-2008, 03:08 PM
Franklin McGillacutty
riquefied919's Avatar
I wear skull bucket always .........I could hear that if I wanted to.
riquefied919 is offline
post #11 of 11 Old 07-02-2008, 06:47 PM
boogerface
mikochu's Avatar
I notice this sound...it sounds like a modem communicating...or a turbine whirling idle...or maybe like a ball bearing spinning on the inner side of a pot. I have a friend that had a 919. He has a RC51 now, but he's the one that persuaded me to get a the niner. He told me he didn't notice any abnormal sounds...and what I was hearing was normal.
Michael Reyes
mikochu is offline
