Newbie to this forum - Wrist Twisters
post #1 of 29 Old 10-03-2008, 08:58 PM Thread Starter
Hello, I just bought a 2007 919 today. I traded in my dead Aprilia Shiver toward it. My wife has a 599, which I talked her into (and she now loves). I talked her into it because the first bike I fell in love with was my dad's Honda 400/4. So, I probably should have bought the 919 instead of the Shiver, live and learn...... My other bike is my "baby", and that is my 2007 ZX10. However, the 10 doesn't make a great running around bike and it isn't all that much fun to ride when my wife is following me. I have ordered up a bunch of little stuff to make modifications to the 919 (rear turn signal eliminator, frame sliders, tank protector, front turn signal, Givi screen....). The bike already had Staintune exhaust, a PCIII, and Renthal bars. So, I look forward to searching this forum for information.
Thanks, Steve
sike is offline
post #2 of 29 Old 10-03-2008, 10:23 PM
Trackday Recognition Veteran
Welcome Steve,
Feel free to ask all the questions you have about how to spend your hard earned cash
Seriously, check out the important topics sticky.
Which sliders are you getting?
Curious about the Shiver and what the autopsy revealed.
It uses the same motor as the Dorsoduro, which I wouldn't mind test riding when they arrive in 09.
Mike
Sokali is offline
post #3 of 29 Old 10-04-2008, 03:13 AM
Ken
Community Admin
Ken's Avatar
Welcome aboard, Steve. Congrats on the new 919! Miles of smiles ahead for you and the Mrs.
2009 Honda Goldwing
Ken is offline
post #4 of 29 Old 10-04-2008, 04:04 AM
Welcome Steve,and congrats on your new bike. I have on 07 9'er and love it. Good luck with your mods. You will a lot of info and help here.
post #5 of 29 Old 10-04-2008, 06:54 AM
Also interested in the demise of your Shiver.
Welcome aboard Steve
post #6 of 29 Old 10-04-2008, 07:03 AM
Welcome to the nest. How about a piture of your bike with the wifes?
post #7 of 29 Old 10-04-2008, 07:31 AM Thread Starter
To answer the Shiver questions... I had to tow it to the shop 4 times in five months, from speedo sensor failing to leaks to recall work (3 separate different engine maps in 5 months) to being completely dead after riding in the rain (a few others had this happen, reportedly due to unsealed or poorly sealed connectors)........... Then, the dealer had some issues too. The Shiver was great to ride and terrible to own (it does use the same engine as the Dorso). Here are a couple of pictures (including the Shiver...).
sike is offline
post #8 of 29 Old 10-04-2008, 07:39 AM
Some states have the so called lemon law. Three strikes and your out! Does Washington have such a law on the books?
Your Shiver definitely qualifies as a LEMON.
post #9 of 29 Old 10-04-2008, 07:46 AM Thread Starter
Some states have the so called lemon law. Three strikes and your out! Does Washington have such a law on the books? You Shiver definately qualifies as a LEMON.
Yes, Washington has Lemon Law laws. However, they require the bike to be 750 CC or larger, the Shiver is 749. As bad as Aprilia has been toward the other folks that I know of who have already gotten rid of their Shivers (note, the Shiver has been in the US for 6 months and I know of 4 people prior to me that have already gotten rid of theirs due to so many problems), I decided to just be done with it and took my lumps (versus seeing whether or not their lawyers would notice).
On a different note, I ordered the LSL slider and Givi 240 screen. Hopefully those are decent, since I have had good luck with them in the past (and I saw your pictures of the Sato slider did, thank you!).
Thanks, Steve
sike is offline
post #10 of 29 Old 10-04-2008, 07:48 AM
What was leaking and where?
Sokali is offline
post #11 of 29 Old 10-04-2008, 07:55 AM
Thanks, Steve
Damn... 1 freekin' cc under; that sucks. Petition your state representatives, get them to change the law. IMO: All new registered motor vehicles no matter what size engines should be covered by the lemon law.
Side note: I assume the sliders are LOS? They are top notch.
post #12 of 29 Old 10-04-2008, 08:04 AM Thread Starter
The sliders are these from Spiegler:
http://spieglerusa.com/cfm/FrameSliders.cfm
They have or three mounting points depending upon the bike. Are these the same ones you are talking about?
As far as where it was leaking.... From the water pump housing (new seal took care of that), oil from the rear valve cover (not much, never fixed), and in 2500 ish miles I put a little coolant in it 4 times with nothing ever being seen on the ground (that was a really bad sign, but I never even got a chance to address that problem....).
Thanks, Steve
sike is offline
post #13 of 29 Old 10-04-2008, 08:16 AM
Thanks, Steve
Headgasket? Did you check the oil for discoloration?
Leatherwings has those sliders. One of the mounting points is on the case. I'd return them and get the Motavation or LOS.
Sokali is offline
post #14 of 29 Old 10-04-2008, 08:18 AM
They have or three mounting points depending upon the bike. Are these the same ones you are talking about? Thanks, Steve
Not the same ones Steve.
It appears these LSL sliders use the motor mount and the frame. Let us know when you get them. Might be a potential problem.
post #15 of 29 Old 10-04-2008, 08:24 AM Thread Starter
It might have been a headgasket, and a few other owners were/are having the same issue. I didn't check the oil, was too busy with other breakdowns. I'll check those other sliders.
Thanks, Steve
sike is offline
post #16 of 29 Old 10-04-2008, 08:34 AM Thread Starter
Motavation or LOS.
Are these the Motivation Sliders people are using (and liking)???
http://www.motovationusa.com/mvstore...?idproduct=201
Thanks, Steve
sike is offline
post #17 of 29 Old 10-04-2008, 08:38 AM
Thanks, Steve
Those are the ones, but that's the wrong picture.
Make sure you get the improved version II with the threaded rod, not the weaker all-thread.
Sokali is offline
post #18 of 29 Old 10-04-2008, 08:41 AM
post #19 of 29 Old 10-04-2008, 10:11 AM Thread Starter
welcome glad to see ya
Hola, porque dices que los gringos que hablen espanol son peligroso? Estoy estundiando espanol.
Un Salud, Steve
sike is offline
post #20 of 29 Old 10-04-2008, 10:49 AM
welcome and enjoy!
post #21 of 29 Old 10-04-2008, 11:33 AM
Welcome Steve
Nice mirrors ! How dose your wife like that seat ? Thanks for the pics, Very nice stable.
post #22 of 29 Old 10-04-2008, 11:49 AM Thread Starter
Originally Posted by ideajones View Post
Welcome Steve
Funny thing about the mirrors is the bike doesn't actually have them, they broke one after that picture was taken. I'll eventually replace the mirrors. My wife loves the look of her seat, thinks it is a little hard, but has to have it. At 5'2" (her overestimation) and about 115 lbs, she needed the seat cut down and softer springs.
Thanks, Steve
sike is offline
post #23 of 29 Old 10-04-2008, 12:38 PM
Un Salud, Steve
y un saludo a ti.. mi conpaneros de trabajo creen que soy peligroso porque todos los clientes latino no saben que yo hablo y entiendo espanol por que soy un gringo muy alto con pelo gris y ojos azules y mi acento es de el sur.. entonces los clientes discuten cosas alfrente de mi por que creen que yo no los entiendo.. hasta que ya es demasiado tarde.... jajajajajaa
i don't know how far along you are in the study of spanish but try the launguage cd's of michel thomas they are awesome
post #24 of 29 Old 10-05-2008, 05:29 PM
Hastatus Posterior
Farab's Avatar
Welcome mate!
Glad I went for the 9'er, as I had the Shiver on my list at the time!
Farab is offline
post #25 of 29 Old 10-06-2008, 01:02 PM
Welcome Steve. Sorry to hear about your experience with the Shiver, but thanks for sharing with us. The Shiver was on my short list of bikes after going to the motorcycle show last fall. Glad I decided to get another 919 instead!
Was your dealer Moto International?
post #26 of 29 Old 10-06-2008, 01:32 PM
Praefectus Castrorum
brevity's Avatar
Yo tenia un trabajo con muchos Hispanos. Ellos estaban deciendo las mismas cosas de mi! Yo escuche muchas cosas...
brevity is offline
post #27 of 29 Old 10-06-2008, 02:57 PM
es bueno de conocer un hombre con el mismo nivel de educacion que yo... lol
us spanish speakin gringos are hard to find..... lol
post #28 of 29 Old 10-06-2008, 04:37 PM
post #29 of 29 Old 10-06-2008, 05:08 PM
you found a picture of jennifer lopez's husband.. marc anthony...lol
